Classifieds » Miscellaneous » FS: ST185 3SGTE CT26 High Flowed Turbo
CLG
Perth, Western Australia
FS: ST185 3SGTE CT26 High Flowed Turbo Sun, 22 February 2004 16:09
I recently bougth a 3SGTE with what was supposed to be a good high flowed CT26. Following inspection by a trusted local turbo shop, it was found to need a full rebuild. AS a result I'm offering it for sale, either in current condition to suit rebuild, or as a fully rebuilt with warranty unit. Details of the turbo are:
Modified Compressor Snail
T04B Compressor wheel
Cropped steel turbine wheel and shaft (reduces lag through cropping - spools up earlier)
Standard twin entry turbine housing (ST185)
Should you wish to take the turbo as fully rebuilt unit, you will lose the cropped wheel as the shaft has been recommended to be replaced. Looking for $1600 for the warrantied fully rebuilt unit, or serious offers as it is at the moment (bare in mind I was quoted $600 just to modify and highflow a CT26 recently before rebuild, so if you think I'll sell it for $50 cos it's currently stuffed, think again). Will also look at croppinghte new turbine wheel if needed. A reecnt similar turbo buildup pulled 220RWKW I have been told by the turbo shop I'm dealing with.
Previous Topic:expression of interest: worked 2t/3t
Next Topic:FS: Autometer gauges and Monster tacho
Current Time: Sat Oct 24 03:17:02 UTC 2026
Total time taken to generate the page: 0.0044069290161133 seconds
