Toymods » Tech & Conversions » Gen2 3sge into 1986 Celica ST162??
smt_007
Gen2 3sge into 1986 Celica ST162?? Sun, 22 February 2004 22:45 Go to next message
I was wondering how difficult it was to put a [MR2] generation 2 3SGE engine into a 1986 SX celica? Would my factory g-box be ok? does the engine just drop straight into the car or would i have to do some modifications to the engine bay? Obviously i would need a heavy duty clutch for the extra power.
Regards, Any Info is appreciated
wiso
Re: Gen2 3sge into 1986 Celica ST162?? Mon, 23 February 2004 02:51 Go to previous messageGo to next message
Nahhh man we were looking at this for a friends car, it a straight swap, just drops in if you want you can even use your original loom and ECU, The only thing I an not sure on (cause we never got round to it) is you may need to use the gen1 intake manifold, someone said they did the swap using the gen2 manifold, but another friend did it and the mechanic who did it used the gen1 intake manifold, may have something to do with the throttle body size. You could use yur original gearbox fine, just note ST162 boxes are pretty weak, they have a habbit of shitting the second gear syncro, I would probably try the other box (i think it's an S54) thats what came with the mr2 (with backward linkages) the ST184 celica and the SV21 Camry. I don't know if youd need a Heavy duty clutch, a standard MR2 clutch would work fine, but that is a chioce you can make.
StuC
Re: Gen2 3sge into 1986 Celica ST162?? Mon, 23 February 2004 08:16 Go to previous messageGo to next message
SMT, were u lookin at buying that gen2 off here for 600bux? i was thinkin the same.If u do, let us know how it all goes and if the imprvovement is worth it.
Good luck mate
smt_007
Re: Gen2 3sge into 1986 Celica ST162?? Mon, 23 February 2004 11:16 Go to previous message
StuC wrote on Mon, 23 February 2004 19:16
Good luck mate
Hi, im not getting the 3sge for 600 i have another one. Going by the specs, the torque increase and power increase makes it a very worthwhile swap, thanx for the help guys Smile.
GEN1 3SGE (Celica st162)= 103kw@6000rpm & 172nm@4800rpm
GEN2 3SGE (MR2 1990-1995)= 117kw@6800rpm & 190nm@4800rpm
Previous Topic:Q auto to manual conversion in a 72 celica
Next Topic:Question on tool purchase??
Current Time: Fri Nov 20 19:43:40 UTC 2026
Total time taken to generate the page: 0.0056631565093994 seconds
