Toymods » General Car Talk » Single Spinners and high Hp engines
Jag7799
Single Spinners and high Hp engines Mon, 23 February 2004 07:11 Go to next message
Basically im asking how bad traction loss I would have on start off with a single spinner from standing start and just mashing accelerator
facts will be
1984 gz10
1200kg
1jz gte running 180 rwkw
with IRS suspension with all urethane bushes, low king springs and just pedders shocks
17 inch rims with dunlop fm901's
will I have alot of traction issues?
I only ask as i may have to put up with it until i can track down an lsd out of an ma61
Re: Single Spinners and high Hp engines Mon, 23 February 2004 07:14 Go to previous messageGo to next message
Yes, you will have lots of traction issues Smile
Jag7799
Re: Single Spinners and high Hp engines Mon, 23 February 2004 07:21 Go to previous messageGo to next message
i better find a scrapper ma61 then 'ey
Re: Single Spinners and high Hp engines Mon, 23 February 2004 08:51 Go to previous messageGo to next message
Yes
Danish
Re: Single Spinners and high Hp engines Mon, 23 February 2004 09:20 Go to previous messageGo to next message
Many traction issues, even with an LSD. You could try looser suspension, but it wouldn't be much good other than for drags.
Jag7799
Re: Single Spinners and high Hp engines Mon, 23 February 2004 09:21 Go to previous messageGo to next message
definately want it to be set up as is and be good for taking corners
but i would also like to be able to fry turbocharged bogans
Classique71
Colac, Victoria
Re: Single Spinners and high Hp engines Mon, 23 February 2004 10:00 Go to previous messageGo to next message
if you have a same setup as a ma61 you mgiht wwant to look at a trutrack setup like waht norbie has in his - Costa about a grand to purchase though hes getting excellent results
Jag7799
Re: Single Spinners and high Hp engines Mon, 23 February 2004 10:06 Go to previous messageGo to next message
yeah.. ma61 diff for now and just get everythign running and when i
actually have money again.. then ill get one
its in the plan
im hoping to have 10.5 to spend
torque
UK at moment
Re: Single Spinners and high Hp engines Mon, 23 February 2004 12:47 Go to previous messageGo to next message
I think with 17" rims you will be fine.. lucky.
Jag7799
Re: Single Spinners and high Hp engines Mon, 23 February 2004 12:59 Go to previous messageGo to next message
how does 17 inch rims change anything?
if anything it lessens the grip i would have, i would think.
being less tyre hitting the actual road cause of lower profile
the tyres are 235's with the dunlop fm901's.. so im hoping its not hopeless
torque
UK at moment
Re: Single Spinners and high Hp engines Mon, 23 February 2004 13:55 Go to previous messageGo to next message
that comment was in jest, that's all..
Very Happy
Mr DOHC
Re: Single Spinners and high Hp engines Tue, 24 February 2004 07:32 Go to previous messageGo to next message
actually u would lose traction with the 17s cause the walls will not flex at all, compared to 14's, {not much, but a bit}
torque
UK at moment
Re: Single Spinners and high Hp engines Tue, 24 February 2004 09:51 Go to previous messageGo to next message
Okay, I'll be constructive ..
The highest HP I have had with an open centre diff was about 180 rwHP (so obv less than you're going for) - and the car weighed a little more as well.. I was running 15" 225 or 235 yokohama's.. and yes, major traction issues .. I could light it up at 70-80k's an hour.
This was an NA motor, and you will experience worse problems with a boosted engine's power delivery I would expect..
When the diff was welded (for an intermediate measure) it improved immensly (sp?) ..
Jag7799
Re: Single Spinners and high Hp engines Tue, 24 February 2004 13:02 Go to previous messageGo to next message
but welding the diff would create cornering problems would it not?
Re: Single Spinners and high Hp engines Tue, 24 February 2004 13:16 Go to previous messageGo to next message
Yeah...like mucho understeer followed by mucho oversteer providing you had any power.
torque
UK at moment
Re: Single Spinners and high Hp engines Tue, 24 February 2004 14:07 Go to previous messageGo to next message
... indeed it will!
I was not at all advocating a welded diff, rather illustrating that it made a significant difference when power was delivered to two wheels..
do not weld the diff in a high powered car if you have not experienced the "subtle" nuances involved with this setup before!
my point : 180 rwkw with one wheel being driven will definetly have major traction issues, so be prepared for that! (tyre/wheel combo will have little to do with combating this)
I owned a ta22 with a very well setup rear end with a brand new LSD, and it was infinetly better than the CIG variety .. (except in the fun stakes!) ..
my advice - if you are really going to be making 180rwkw - spend the extra and get the power to the ground (ie; use something other than an open wheel standard diff - I'd be surprised if it lasted very long with that power anyways...) ..
Jag7799
Re: Single Spinners and high Hp engines Wed, 25 February 2004 01:32 Go to previous messageGo to next message
yeah.. i will be.. but i mighjt have to wait a few days/weeks on a single spinner while i hunt around for an ma61 lsd
thats why i ask
my mates vc ran high 12's on a single spinner
Re: Single Spinners and high Hp engines Wed, 25 February 2004 01:46 Go to previous messageGo to next message
Noble M12 GTO has 310bhp with no lsd, and seems to cope pretty well
Re: Single Spinners and high Hp engines Wed, 25 February 2004 01:48 Go to previous messageGo to next message
Although now Noble has seen the light and the current GTO's have an LSD
gold28
Madrid - Spain
Re: Single Spinners and high Hp engines Wed, 25 February 2004 02:24 Go to previous messageGo to next message
IRS open diffs cope with the power a lot better than a live axle open diff. This is because the torque transfer on the casing is reacted by the wheels and suspension, causing the drivers side wheel to lift, reducing traction on that wheel. The torque on IRS diffs is reacted directly by the chassis, no loading up of the suspension except for thrust line moments. (back of the car lifting or dropping).
Having said that, there is no reason why an open IRS can't cope with heaps of power off the mark. Theoretically it wouldn't make any difference wether it is open or locked. The problem is ensuring that you don't have any weight jacking due to porely fitted anti-roll bars or springs of different heights/rates.
Traction will be more of a problem on corner exit though. Your choice should hang on how soon you want to give it a hard time through a corner, not so much dragging at the lights.
Just out of interest, I tried weight jacking on my live axle celica to reduce wheels spin. It got very ugly when I changes into 2nd. with both wheels fighting each other for traction. and kicking the arse all over the place.
Jag7799
Re: Single Spinners and high Hp engines Wed, 25 February 2004 06:41 Go to previous message
hmm.. well hopefully i dont have to find out. i want an lsd.. but we will see how i go
Previous Topic:my pics from drag combat
Next Topic:bling bling
Current Time: Mon Nov 2 11:08:24 UTC 2026
Total time taken to generate the page: 0.0060849189758301 seconds
