Toymods » Tech & Conversions » 7MGTE water noise
joorsh
7MGTE water noise Mon, 23 February 2004 07:14 Go to next message
I was just wondering if anyone else with a 7M series engine had noticed a noise that I can only describe as a water feature. It sounds exactly like one of those little fountains you can buy for your living room. It's supposed to relax you, but in this case it just makes me nervous Confused
I think it makes the noise constantly (while the engine is running), but it's fairly quiet - so I can only really hear it at idle.
The reason it makes me nervous is that I am familiar with the 7MGTE's appetite for head gasgets, and it sounds to me like a bubble in the coolant system. From inside the cabin, it sounds VERY close to the firewall - my guess would be around 5th or 6th cylinder.
Does anyone else get this noise and is it normal? Is there any way to shut it up!?
-J-
V8_MA61
Re: 7MGTE water noise Mon, 23 February 2004 07:44 Go to previous messageGo to next message
could it be the heater core? Flush it out with a hose...see if its blocked or something?
You'd know if your car was boiling. i.e it wouldnt sit at normal on the temp gauge!
BlackSupra
Re: 7MGTE water noise Mon, 23 February 2004 07:49 Go to previous messageGo to next message
You have ray's red supra don't you!
Make sure you don't blow the HG on that baby!
I would start with a coolant flush tomorrow to get any air out of the cooling system.
V8_MA61
Re: 7MGTE water noise Mon, 23 February 2004 07:50 Go to previous messageGo to next message
in doing that, dont forget to "burp" the cooling system. Ask if you dont know what that means!
joorsh
Re: 7MGTE water noise Mon, 23 February 2004 08:02 Go to previous messageGo to next message
"burping" the cooling system? Is that anything like the Nissan RB series engines, where you have to release the little bolt at the back of the inlet manifold to let the air bubble out?
And it's definitely not boiling. I've heard that before Smile It's a quiet little trickling noise.
And yes, I have Ray's red supra Smile
As for the heater core - is that the one all smooshed up under the dash that's a real nightmare to get to?
-J-
BlackSupra
Re: 7MGTE water noise Mon, 23 February 2004 08:10 Go to previous messageGo to next message
joorsh wrote on Mon, 23 February 2004 19:02
Bitch Very Happy
-J-
Yes Nod
joorsh
Re: 7MGTE water noise Mon, 23 February 2004 08:22 Go to previous messageGo to next message
<SIGH>
I guess I'll go grovelling under the dash then.
And does this mean that no-one else has this noise? That makes me kinda worried... Though I mentioned it to Ray and he said she's always done it. I guess it can't be that bad if it's lasted 3 years.
-J-
V8_MA61
Re: 7MGTE water noise Mon, 23 February 2004 09:44 Go to previous messageGo to next message
nono you dont need to get into the dash.
You need to take the hoses off at the firewall going into the core and stick a hose through them!
If you need a pic of the ones let me know.
joorsh
Re: 7MGTE water noise Mon, 23 February 2004 10:12 Go to previous messageGo to next message
A pick would be great!
-J-
V8_MA61
Re: 7MGTE water noise Mon, 23 February 2004 10:19 Go to previous messageGo to next message
pm me your email address....
7M-Brisbane
Re: 7MGTE water noise Mon, 23 February 2004 10:33 Go to previous messageGo to next message
This is actually quite common, and contrary to popular belief does not always mean the head gasket is toast.
I had gurgling behind the dash on my old 7M... and it sure as shit didn't have a blown head gasket!
joorsh
Re: 7MGTE water noise Mon, 23 February 2004 11:21 Go to previous messageGo to next message
OK, well that's a little reassuring Smile
Re: 7MGTE water noise Tue, 24 February 2004 06:57 Go to previous messageGo to next message
I think it's common with Supras in general; my MA61 used to do this when I got air in the coolant system. The fix was simple, just let the engine warm up with the radiator cap off; as soon as the thermostat opens all the air gets pushed out.
Re: 7MGTE water noise Tue, 24 February 2004 07:00 Go to previous messageGo to next message
ditto that joshy - my mk2 had the same noise
ColMX83
Re: 7MGTE water noise Tue, 24 February 2004 10:07 Go to previous messageGo to next message
Just to throw a spanner in the works, I have a MX83 Cres that did the same with the 7MG. The heater core was leaking and letting air into the system any time that it stood still. (usually over night)
While I was doing my 1JZ conversion, I took the oportunity to remove the dash and core to resolder the end tanks. (they were very average)
The holes were extremely small, so may be hard to detect without pulling the whole thing apart.
It's a fair sized job in the MX but I can't really speak for the Supra.
rvrolla
Central Coast
Re: 7MGTE water noise Wed, 25 February 2004 03:25 Go to previous messageGo to next message
My old MZ20 used to make that noise aswell, I'm sure it wasnt when the HG blew, cause it still did it when the MHG and everything else went in, and the heater never worked.
joorsh
Re: 7MGTE water noise Fri, 27 February 2004 07:39 Go to previous message
Do you guys think it's likely to cause problems if I leave it? If it's a bubble in the heater core for instance - will that be a problem? Of should I bite the bullet and pull the whole damn thing apart?
-J-
Previous Topic:1G-GTE turbo differences
Next Topic:'Dust cap" on TA22 tailshaft screaming....
Current Time: Tue Oct 20 04:55:20 UTC 2026
Total time taken to generate the page: 0.0066540241241455 seconds
