Toymods » Tech & Conversions » Oil coming out of cylinder 3
natez
Oil coming out of cylinder 3 Tue, 24 February 2004 01:56 Go to next message
Hey
Just started the engine before, it was running fine, smoke started to pour out of the exhaust..
i took the exhaust manifold off
theres oil in cylinder 3,
what could the causes of this be
have i done a valve, or is the piston ring gone etc...
natez
Re: Oil coming out of cylinder 3 Tue, 24 February 2004 04:03 Go to previous messageGo to next message
looks like i'm running alota compression in this motor, and i needed more breathers for the head, as to much compression is pushing the oil though the seals which resulted in white smoke... hopefully should be okey now
Re: Oil coming out of cylinder 3 Tue, 24 February 2004 07:24 Go to previous messageGo to next message
to much ring blow-by? or blocked breathers? the stock breathers should be fine if the rings are holding compression
Scorpion
Menai area of Sydney
Re: Oil coming out of cylinder 3 Tue, 24 February 2004 12:08 Go to previous messageGo to next message
Sounds silly but check that the spark plug is screwed in properly. Can get oil sucked in through a loose thread.
-=NiGz=-
Compton.Sydney
Re: Oil coming out of cylinder 3 Wed, 25 February 2004 06:46 Go to previous message
Sometimes i find little patches of oil where the spark plugs are screwed into is this normal? theres not alot just small liltle patches
Previous Topic:p/s belt length for 4age 20v?
Next Topic:Steering Box to Rack (power)
Current Time: Thu Oct 29 17:32:22 UTC 2026
Total time taken to generate the page: 0.085718870162964 seconds
