Toymods » Tech & Conversions » 3sgte gen 3??
MR. 2
Parramatta
3sgte gen 3?? Sun, 11 August 2002 07:32 Go to next message
I have been told by a few people that the gen 3 3sgte is damn strong and pretty damn quick.... but i can only find info on the first and 2nd gen 3sgte ... i was told that the internals of this gen three motor were and extreamly strong as in all steel crank and rod + forged pistons and they make great hp whithout doing anything to the bottom end. if these engines do exsit can some one enlightn me !!! i have been told they only came out in 97 + models i think its all shit but i hope not! any help would be apprecated!!
._T_.
Re: 3sgte gen 3?? Sun, 11 August 2002 22:31 Go to previous messageGo to next message
they don't have forged pistons. they came out (in aus anyuway) in the post '94 mr2's - very hard to find
T
1UZ FTE
Re: 3sgte gen 3?? Mon, 12 August 2002 02:30 Go to previous messageGo to next message
Here is a list dif between Gen2 & Gen3
MAP sensor instead of AFM
- Bosch D-Jetronic (Gen III) vs. L-Jetronic (relatively primitive) engine management
- CT20b turbo replaces CT26
- Boost raised from 10psi to 13psi
- Fuel cut raised from 12 psi to 18 psi
- Different ECU
- 4 wire O2 sensor
- Shim under bucket valve shims
- slightly more aggressive cams
- Revised internals (pistons, con-rods etc.)
- Revised cylinder head cooling passages/water jackets
- Revised intake manifold (8 'independent long ports' reduced to 4)
- Revised gearbox with close ratio gearing
- lower compression ratio
- stainless steel head gasket
- factory 540cc injectors replace 430cc injectors
- revised fuel rail with bigger bore and relocated pressure regulator
- TVIS eliminated
- EGR eliminated
- LSD in 80% of them
- throttle body increased from 55mm to 60mm
- inlet valve lift increased from 8.2 to 8.7
- intake manifold inlet air temperature sensor added
- Less restrictive exhaust elbow
- Aluminum oil pan
- more rigid alloy sump and additional oil baffles
- Factory Catch can
- Better Oil Cooler and relocated oil filter (bottom)
- 4 Channel ABS coupled with Traction Control available
- No. 1 compression ring described as 'stainless steel' instead of just 'steel'. Oil ring is described as 'stainless steel' instead of 'a combination of steel and stainless steel'.
._T_.
Re: 3sgte gen 3?? Mon, 12 August 2002 05:28 Go to previous messageGo to next message
both gen2 and gen 3 have 4 wire oxy sensors, and both run map sensors. only the gen 1 (n/a & turbo), and the gen2 turbo motors run afm's.
T
MR. 2
Parramatta
Re: 3sgte gen 3?? Mon, 12 August 2002 07:10 Go to previous messageGo to next message
thanx heaps guys helps lots but the question is is it worth the change of motor cause i have done mine in the gen 2 i have ems already so all it would be is just an engine swap no half cuts and i have the lsd box too but is it worth getting that motor and how much power will it support without falling over.. or chould i just spend the money on good rods pistons and crank?
1UZ FTE
Re: 3sgte gen 3?? Mon, 12 August 2002 08:36 Go to previous messageGo to next message
YEP Sorry about that Toby i should of made that clearer that the list that i put up was for the 3sgte Turbo
hmmmm MR.2 try the below site they can help u all u want
http://www.mr2.com/
[Updated on: Mon, 12 August 2002 08:37]
TA22-3SGTE
MACKAY
Re: 3sgte gen 3?? Mon, 12 August 2002 10:31 Go to previous messageGo to next message
MR. 2
I don't know the strength of the gen 3 but I am running a gen 1 in my TA22 and putting out 260 RWKW on 22 psi boost with stock internals and stock gen 1 Group A CT26 .
Trevor
MR. 2
Parramatta
Re: 3sgte gen 3?? Tue, 13 August 2002 06:49 Go to previous messageGo to next message
thanx again for all your replies but im still stuck does anyone have experince with these motors and what sort of power will the put out with out any problems... and also i have been told that the crank and the rods are steel and not cast iron. and the pistons are forged??? thats my main question if someone could answer that i would be thankful.... thanx in advance.
ae102_3sgte
Canada
Re: 3sgte gen 3?? Tue, 13 August 2002 10:45 Go to previous messageGo to next message
(not trying to sound like a flame...)
Does it really matter what the pistons are made from?
Or the rods etc?
Based on the first 2 Gen of 3SGTE, I would say we can be confident that these motors are not weak.
I think fuelling/ign/I.C. to suit the boost is your largest concern as far as keeping the motor intact.
What kind of power do you expect or hope for?
wagonist
Toymods Club Treasurer
Re: 3sgte gen 3?? Wed, 14 August 2002 01:16 Go to previous messageGo to next message
Does anyone know if Toyota changed the 3S GTE when they stopped it in the Celica GT4 & put it in the Caldina GT-T?
Most of the ST215 Caldinas are auto so they were detuned from the ST205 Celica
1UZ FTE
Re: 3sgte gen 3?? Wed, 14 August 2002 22:03 Go to previous messageGo to next message
Hi Steve
I could be corrected here but I beg to differ that the 215 in the Caldina was detunned matti's site rates them at 208kw @ 6000rpm motor & the MR2 boys in America rate them as 265hp - 270hp
I currently have one apart and they come with crank trigger individual coil packs ontop of each plug + the cams have had the base circle reduced to 1/3 width and every bit of weight removed
The ct20b hybrid of something has had the exhaust maniflod turbo housing cast as one and is a very nice job for a production engine, dump pipe is pressed sheet metal and nice and large
I have also been told that the cams have 8.9mm lift as apposed to the 205's 8.7mm lift but i am yet to confirim either of these figures
Wasn't the gearbox on them a full tiptronic 5speed / steering wheel paddle set up ??? as didn't get this with the engine so would like to know more about this
J
Re: 3sgte gen 3?? Thu, 15 August 2002 04:49 Go to previous messageGo to next message
Top engine indeed - hope to shove one into my car after I bust the 4A Evil or Very Mad In my opinion, makes an SR20 look like a model T ford Skull - Blink
wagonist
Re: 3sgte gen 3?? Thu, 15 August 2002 06:17 Go to previous messageGo to next message
The official Toyota figure for the manual ST215 Caldina is 191kW (260ps), while the Jap spec ST205 Celica was on the jap power limit of 208kW (280ps).
The gearboxes available in the Caldina are either 5 speed manual 4wd or 4 speed tipronic (steering wheel buttons) auto.
The Caldina is a bit heavier than a Celica (but not much), & also marketed as a sports wagon rather than an all out performance vehicle, so tuned for more mid range torque than power.
I wanted to get a 210 series Caldina but they're not eligible for grey importing.
ae102_3sgte
Canada
Re: 3sgte gen 3?? Thu, 15 August 2002 10:47 Go to previous message
Re: 'tiptronic'
I have driven a few Lexus with the 'tiptronic' buttons on the steering wheel.
The consensus from myself and others that I have spoken to seems to be "Try it once and forget it". There is a delay, and the sensation is most comparable to shifting an atm at the floor shifter. It just dosent turn out to be useful in practice.
Are you using a M/T?
Previous Topic:Radio Problem
Next Topic:Heat resistant materials ....
Current Time: Thu Nov 19 15:35:46 UTC 2026
Total time taken to generate the page: 0.0069451332092285 seconds
