Toymods » Tech & Conversions » Crown Axles
dispatcher
Malaysia,Kuala Lumpur
Crown Axles Tue, 24 February 2004 15:09 Go to next message
Anyone here knows or have pics of Crown series axles with LSD.
This will be fitted onto a GX60 cressida with minor mods
Any websites or personal pics greatly appreciated.
Re: Crown Axles Wed, 25 February 2004 09:24 Go to previous messageGo to next message
Crowns were available with LSDs as an option. I have never seen one in Australia. That said, it's a very easy proposition to fit an LSD from another similarly diffed vehicle into the Crown diff carrier (eg MA61 LSD centres bolt into MS112 carriers - both are F series diffs). In Japan, from MS65 onwards, they are F series diffs, but here in Australia, we had mostly Borg Warner diffs till the end of the MS85, so fitting an LSD was as simple as fitting a Holden centre.
Isn't that model Cressida an E series rear end? If so you might be in the poo - not sure what you'd get an LSD from.....
dispatcher
Re: Crown Axles Wed, 25 February 2004 12:52 Go to previous messageGo to next message
gianttomato, just want the Crown diffs because they're somewhat stronger than what i have on the cress now. Mine's begining to spit some oil from the diff centre.
If i get the the crown disc setup than as you said i could use an MA61 centre. My buddy has blown 6 diffs already.
Don't intend to beat that record.
Re: Crown Axles Wed, 25 February 2004 13:30 Go to previous messageGo to next message
I think that will be easiest.
Not sure if an MS112 disc brake rear end bolts straight into the Cressida GX60 but it would certainly be worth measuring up. Worst case scenario would be that you'd have to weld the Cressida suspension points on to the Crown diff.
dispatcher
Re: Crown Axles Wed, 25 February 2004 13:33 Go to previous messageGo to next message
That's the idea..i know the measure up. identically not sure.
will have to make some adjustments i guess.
Say would you know where i can see some pics of a MS112 crown ??
Re: Crown Axles Wed, 25 February 2004 13:38 Go to previous messageGo to next message
http://www.crown-corona.org/index.php?p=11&s=5
And of course Classicrown, the universe's largest Crown website.
Info and pics.
dispatcher
Re: Crown Axles Wed, 25 February 2004 13:53 Go to previous message
Thanks a million Giant
Previous Topic:stroking a 4agze
Next Topic:off tune twin cam AE82
Current Time: Fri Oct 30 17:48:50 UTC 2026
Total time taken to generate the page: 0.057177066802979 seconds
