Toymods » Tech & Conversions » Revs, Revs, I need to see revs!!!!
trev64
icon5.gif  Revs, Revs, I need to see revs!!!! Sun, 11 August 2002 09:05 Go to next message
I think lumpy can help me out on this one.
Just completed my 1j conversion into a 1986.5 MK3 supra.
I have kept my old dash because I think it looks better than the JZA70 one.
But I can't get my tacho to work.
I tried to get the signal from the "IG" terminal on the dianostic block but that dosen't seem to work.
Now I am fresh out of ideas can anyone help?
Also the AC compressor on the 1JZ is a three wire type as opposed to my old sigle wire type, can that still be made to work with the old dash? Or can the old 7M-GE compressor be bolted in?
Thanks. Rolling
celica_freak
newcastle
Re: Revs, Revs, I need to see revs!!!! Sun, 11 August 2002 12:26 Go to previous messageGo to next message
just guessing but usually if its was a 1 wire than that would be a (+wire) or (-wire) depending. this would be easy to find out with voltmeter on the end,turn the ac on and see if u get a reading if so its (+wire) so to work it just needs (+wire)from battery and bolted to the motor to work ,so if the wire from battery has a switch in it the pump can be harnesed so if its a three wire it has a (+wire) (_wire) and a (switchwire),that said it needs a (+wire)from the battery a wire from the (-terminal)or body and a switch wire which can just be a on off type switch or constant (+wire) to turn on or off this im not sure how to check other then circuit wire diagrams or trace the original harness hope this has help thats all i can offer im not an auto elect just a back_yarder trying to help a fellow toyota_freak.
trev64
Re: Revs, Revs, I need to see revs!!!! Sun, 11 August 2002 21:53 Go to previous message
Thanks.
Also is it normal to see 12psi manifold pressure on a 1JZ with just a 3" exhaust and a K&N pod filter.
I also have a balance line running between both turbos for easy boostin' later on. But I haven't touched the boost.
Do I have a leak in the wastegate line?
Previous Topic:wheel offset for ST202 Celica?
Next Topic:can anyone help me?
Current Time: Thu Oct 22 03:56:39 UTC 2026
Total time taken to generate the page: 0.0090188980102539 seconds
