Toymods » Tech & Conversions » 18rgeu timing
people100
Rocklea qld
18rgeu timing Wed, 25 February 2004 09:44 Go to next message
I have built my engine up and have a few questions about the timing setup mainly. I have the crank and number piston on tdc. The keyway in the crank is straight up. The little notches in the cams are straight up. The sprocket on the exhaust cam has the mark straight up but the inlet one doesnt. its about 45 degrees out. Does it matter where the gear is solong as the cam is in the right position. Also should it be hard to turn the motor over with a spanner on the crank. Feels like heaps of compression. Also does anyone in brisbane have a 18rgeu engine that i could get a look at to see where all the hoses and wires go as im having trouble with mine as it came to me in pieces. Thanks
Ben
omegaman
SYDNEY
Re: 18rgeu timing Thu, 26 February 2004 08:19 Go to previous messageGo to next message
Hey,
I believe you have the set up fairy right , the cam sprockets would be the adjustable ones therefor I would say to have the dot on the sprocket in the top position to start. When you get the engine together and running it may pay to adjust the timing i.e advance and retard later.
Check distributor for firing position No. 1
If cams are facing the right way at TDC the engine will turn with a spanner with ease.( Take out the spark plugs to make it easier).
As for the hoses give me yor email and Ill take some photo's of my 18rgeu hoses.
people100
Rocklea qld
Re: 18rgeu timing Thu, 26 February 2004 08:41 Go to previous message
ok my email is strokemegently_69@hotmail.com all help would be great..ill set the sprockets up on the tdc also and see how i go.
Previous Topic:ma61 fuel gauge has shit itself
Next Topic:oil catch can
Current Time: Thu Nov 19 15:31:14 UTC 2026
Total time taken to generate the page: 0.0071899890899658 seconds
