Toymods » Tech & Conversions » MA61 Heater Not Operating! (VSV valve operation)
BlackSupra
MA61 Heater Not Operating! (VSV valve operation) Wed, 25 February 2004 09:49 Go to next message
The saga continues.
We have vacuum up and until the VSV valve before the water valve.
I have tried and tested the VSV as per TSRM specifications and its all good, makes a little click at 12V and changes the air flow path of the valve.
Heres a reference:
www.cygnusx1.net\supra\library\TSRM_MKII\ac\AC_042 .html
I tested the wiring harness, it registers as 10.61V for the positive.
Now basically it has to be a wiring issue for the VSV to not be opening. My question, is the 10.61V not enough (ie need 12V) or is it a bad earth Wink
Ta guys.
sideshow
Re: MA61 Heater Not Operating! (VSV valve operation) Wed, 25 February 2004 11:35 Go to previous messageGo to next message
im pretty sure the 12 volts is always htere at the solenoid when iggnition is on
what happens is when u slide the lever from cold to hot it is suppose to give the solenoid an earth then it will trigger the solenoid then oipen the valve to let hot water thru
thats how 7ms 1js etc work
so u could maybe check yr levers that control hot /cold and the heater flaps
of fit an extra switch to trigger the earth manually
BlackSupra
Re: MA61 Heater Not Operating! (VSV valve operation) Wed, 25 February 2004 11:55 Go to previous messageGo to next message
yeah i checked it
its not earthing
then again i havent checked to see if there is 12v when ignition is on, only tried it with the fan on.
But from the diagram it appears to have a +ive feed from the ignition, so you would be right there.
dammit.....how the hell is it not switching the negitive......im gonna have to pull the whole dash apart!
sideshow
Re: MA61 Heater Not Operating! (VSV valve operation) Wed, 25 February 2004 21:30 Go to previous messageGo to next message
just pull that section out that has the hot cold controls
trace the black wire from the heater solenoid to the controls
if thats ok then check the controls
might be a bad solder inside
lumpy
Adelaide, SA
Re: MA61 Heater Not Operating! (VSV valve operation) Wed, 25 February 2004 22:34 Go to previous messageGo to next message
Same used to happen on my ma70 - the sliding control for the heater wasn't working and thus wasn't turning the solenoid on. We checked everything as per TSRM specs and it all looked ok so we were about to pull the dash out (again) when we tried another heater control box (with the slider etc). It worked fine - so it must have been something funny with the old one.
Dunno if this helps with the ma61 though!
BlackSupra
Re: MA61 Heater Not Operating! (VSV valve operation) Thu, 26 February 2004 06:56 Go to previous messageGo to next message
Ta guys.....gives me something to go on.
ZZT231
melbourne.vic.au
Re: MA61 Heater Not Operating! (VSV valve operation) Thu, 26 February 2004 09:38 Go to previous message
Black, not reading the whole thread here is starters:http://www.celicasupra.com/phpBB2/viewtopic.php?t= 4917&highlight=vsv or ask there as they may be able to help.
Cheers.
Previous Topic:dexron oils!
Next Topic:bigger brakes and 4AGE in AE86
Current Time: Thu Nov 19 17:58:11 UTC 2026
Total time taken to generate the page: 0.0059959888458252 seconds
