Toymods » Tech & Conversions » dexron oils!
V8_MA61
dexron oils! Wed, 25 February 2004 10:18 Go to next message
My a340e is supposed to use dexron 2.
Is dexron 3 the same thing but revised??
Chris Davey
sunny coast, qld
Re: dexron oils! Wed, 25 February 2004 11:03 Go to previous messageGo to next message
I used to use dexron 3 in my gz20 soarer which has an a340e and was recommended dexron 2. No problems but in hindsight i would have used toyota type 4 because of other people's recommendations.
V8_MA61
Re: dexron oils! Wed, 25 February 2004 11:10 Go to previous messageGo to next message
no grinding clunking?
My box is clunking when changing into gears etc, its really pissing me off! i dont know if its rooted, or just needs a service.
Re: dexron oils! Wed, 25 February 2004 11:35 Go to previous messageGo to next message
funny, i was chasing this up last week for a friends merc.
they are recommended a Dexron II type, and it seems that Dexron III 'supersedes' II, kind like the rating of engine oil.. SP-CF?? whatever.
anyhoo, Dexron III should be fine for DEXRON II recommended boxes.
http://www.prilubes.com/product-info-sheets/pdfs/D exron%C2%AEIII_Mercon%C2%AE_ATF_.pdf
http://ri.serveftp.org/ToyMods/Resources/rmm688u%2 0a340e%20reas.pdf
http://www.redlineoil.com/redlineoil/atfpds.pdf
http://www.havoline.com/products/na/trans_md3.html
http://www.valvoline.com/pages/products/product_de tail.asp?product=6
http://agauto.ru/ag_fluid_28.shtml
http://www.gear-boxes.com/transmis/capacity/toyota .htm
http://www.peugeotclub.org/peugeot/archive/General /2002/Feb/0097.html
V8_MA61
Re: dexron oils! Wed, 25 February 2004 11:42 Go to previous messageGo to next message
thats all i needed to know, that dexron 3 would be ok Smile
yeah pretty sure it has superseeded no 2..
funny how a fellow at abc auto pointed me in the way of valvoline type "d" as a dexron 2 oil....weird Confused
ZZT231
melbourne.vic.au
Re: dexron oils! Wed, 25 February 2004 11:58 Go to previous messageGo to next message
I was chasing it up as well for my MA61, Dextron III is the fluid avaliable and is running through my gearbox and power steering for months now with no trouble. Since I could not buy/find the original Toyota fluid that was in there.
Cheers.
Re: dexron oils! Wed, 25 February 2004 14:10 Go to previous messageGo to next message
Use Toyota Type IV as mentioned above.
It is supposed to be far superior, esp for the A43xx boxes
commander
Canada
Re: dexron oils! Wed, 25 February 2004 21:05 Go to previous messageGo to next message
o.k.
now the tougher question
synth
which one , why , if at all.
price is $10-20 per L and you need 5-6 L for a T-50
Pennzoil is $20
and quaker state is $10
Who uses synthetic in their gear box ?
Re: dexron oils! Thu, 26 February 2004 00:38 Go to previous messageGo to next message
I've bought some Redline Lightweight Shockproof for my W57, but only becuase I'm putting uber power/torque through it (well, not as much as some).
I will post results when I finally get to drive her.
Cameron_Datto
Re: dexron oils! Thu, 26 February 2004 09:40 Go to previous message
In some cases Dextron III can wear out your auto transmission clutch packs faster DEPENDING on the Transmission spec.. Castrol make a ATF oil call "Transmax "M" which is the same spec as Dextron II ...
Previous Topic:Extractors
Next Topic:MA61 Heater Not Operating! (VSV valve operation)
Current Time: Thu Nov 19 17:43:10 UTC 2026
Total time taken to generate the page: 0.0056488513946533 seconds
