Toymods » Tech & Conversions » 1.5JZ
HedgehogSandwich
UK
1.5JZ Wed, 25 February 2004 16:45 Go to next message
Anyone know of anyone who's done this? or knows of any documentation of what it involves?
adi
1JZ.747
Osama's hideout
Re: 1.5JZ Wed, 25 February 2004 22:56 Go to previous messageGo to next message
i too am looking at doing this conversion, and i too would like to speak to anyone who has actually done it or has documentation on it.
hedgehog sandwich
email me at crichtos@anz.com
and i will tell you what i do know so far from my investigations.
RollaGTi
winmalee
Re: 1.5JZ Thu, 26 February 2004 07:21 Go to previous messageGo to next message
if you guys can get a back issue on "SPEED" magazine, it has an article from a year or more ago about a guy who bought a 1.5J soarer import from japan. it had some crazy power output of 300kw standard or something on relatively small boost. it isn't a step by stpe guide on what to do, as the guy bought it as is from japan, but it'll give you a bit more info about the engine.
if you guys didn't already know, the 1.5J is a 1J with a 2J bottom end or something like that... who am i kidding though?
call (02) 9263 9729 for the editorial people of SPEED if you're REALLY interested.
ed_ma61
Lost in the K hole
Re: 1.5JZ Thu, 26 February 2004 07:24 Go to previous messageGo to next message
why?
Chris Davey
sunny coast, qld
Re: 1.5JZ Thu, 26 February 2004 09:25 Go to previous messageGo to next message
because the 1j heads are made by Yamaha and the 2j heads are made by Toyota. People think that the 1j heads flow better. I would have absolutely no idea!
And so jzz30/jzx90 owners can tell the 'toyota' uneducated that they still have a 'stock' 1j Smile
onejayzed
Re: 1.5JZ Thu, 26 February 2004 09:40 Go to previous messageGo to next message
the 2JZ heads flow considerably better than the 1JZ heads. have a look at the exhaust ports for yourself if you don't believe me.
why anyone would put a 1JZ head on a 2JZ bottom end eludes me.
why would you not 'just' slot a whole 2JZ instead?
that's like fitting a 16V head to a 20V bottom end. it doesn't make sense.... Confused
Celia-Sue
Also, if you've already put cams and custom manifold(s) onto your 1JZ, it's going to be cheaper to just put on a 2JZ bottom end - rather than swap motors and get new bolt-ons.
Justin
Now with manual JZA61! Very Happy
ed_ma61
Lost in the K hole
Re: 1.5JZ Thu, 26 February 2004 09:43 Go to previous messageGo to next message
imho the 1.5jz concept is just utter BS
ive never seen a shred of evidence to support what is just another yank wank
my 2c
V8_MA61
Re: 1.5JZ Thu, 26 February 2004 09:46 Go to previous messageGo to next message
2jz heads are yamaha arent they? I read yamaha on norbies 2jz....
onejayzed
Re: 1.5JZ Thu, 26 February 2004 09:51 Go to previous messageGo to next message
Celia-Sue wrote on Thu, 26 February 2004 20:40
Justin
i didn't think of that scenario. you're very right there...
wastegate
Gold Coast
Re: 1.5JZ Thu, 26 February 2004 11:59 Go to previous messageGo to next message
What do you mean? You don't beleive in them or that they are done what?! puzzling.
Yes, They are done my mostly isisting 1JZ owners that already have cams, turbo, computer etc and just want the next step. Stroking it to 3L the easy way.
here is a comparson picture.
http://www.jzgte.com/~nickc/images/general/1jzvs15jz.jpg
drk_awd
Re: 1.5JZ Thu, 26 February 2004 12:10 Go to previous messageGo to next message
ed_ma61 wrote on Thu, 26 February 2004 19:43
my 2c
Your ignorance is showing. They're extremely rare in the States as they never got the 1JZ. It's the Japanese who do it and yes, I have one.
If the concept is difficult for you to grasp just think of it as a stroker kit for a 1JZ.
FKN16V
NSW, East Coast
Re: 1.5JZ Thu, 26 February 2004 12:32 Go to previous messageGo to next message
Try http://planetsoarer.com/
I think you;ll find info there.
Im the same vote as most people, WHY?
7M-Brisbane
Re: 1.5JZ Thu, 26 February 2004 12:40 Go to previous messageGo to next message
I've been reading your posts for a while now and you just lost all credibility.
Who in their right mind would think that adding an extra 500cc capacity to their 1JZ would not be of great benefit?
Manny
Re: 1.5JZ Thu, 26 February 2004 12:42 Go to previous messageGo to next message
At least 3 1.5JZ Soarers on the east coast of Oz that I know of and I've had the pleasure of driving a very well built and Motec run example. Nothing like an extra 500cc capacity to lug around a 1.7 tonne Soarer off boost.
I'm not going to get into the 1J -vs- 2J head debate as it's pointless without putting a pair side by side on a flow bench and seeing the results.
Both heads were designed in conjunction with Yamaha afaik and both share same valve sizes.
If you've ever seen the path of the 2J's rear 2 exhaust ports, you'd agree with me that the 1J has a more direct path for exhaust flow. If you were to go to town on both with a die grinder, I know which one I'd put my money on - you can easily enlarge a port's ID but you can't straighten an s bend cast into the head amongst water/oil galleries.
Adi
Compression ratio is the critical aspect in selecting the head gasket between the 1JZGTE head and 2JZGTE block eg using a 2JZGTE gasket with stock pistons and stock chambers will apparently reault in a 9:1 comp ratio
Track down a guy called Orin Biven from Texas on some Supra lists/forums - he owns a 600HP 1.5JZ JZA70, one of which he's personally built up.
A 1.5JZ should be a certain way of getting those hybrids spooling 1000rpm sooner...
[Updated on: Thu, 26 February 2004 13:01]
ed_ma61
Lost in the K hole
Re: 1.5JZ Thu, 26 February 2004 21:43 Go to previous messageGo to next message
7M-Brisbane wrote on Thu, 26 February 2004 23:40
im thinking of the converse... putting a 1jz head on an existing 2jz - which is what i have read on the topic
the argument for this was that the 1jz head flows better than the 2jz, and was considered an 'upgrade' as such... to which my comment above still stands - i have never seen any convincing evidence to support such a claim. and the way complete BS gets thrown around on the US forums...
and what other posts, exactly, have lost me credability?
[Updated on: Thu, 26 February 2004 22:30]
lumpy
Adelaide, SA
Re: 1.5JZ Thu, 26 February 2004 22:25 Go to previous messageGo to next message
I was under the impression that the 1.5jz started in Japan - after people were wearing out 1jz blocks they found that a new 2jz block/bottom end was the same price from toyota as a new 1jz one. Hence you could "stroke" the 1jz for virtually nothing (if you need a new bottom end anyway).
You'd have to be a bit mad to put a replace your existing 2jz head with a 1j one though!
1JZ.747
Osama's hideout
Re: 1.5JZ Thu, 26 February 2004 22:54 Go to previous messageGo to next message
it amazes me how some one asks for info, then a bunch of gooses get on here and carry on with shit about what they think when they have no acutal testing to back up the crap.
the 1J head is designed by yamaha, the 2j head is designed by toyota, the information i have read reads that the 1j head flows better. why do people think nissan owners put rb25 heads on rb30 blocks, its a cheap stroker, and yes 500cc will make a big difference.
this conversion is common place in japan. why would i spend $8000 to $10000 to completely rebuild my 1J when i can simply spend $2-3000 on my head and just put a bigger bottom end on it which allready has good strong components.
if i stick with a complete 2j i will have to make another manifold, and the engine i am looking at buyin is a VVTI version of the 2j, so i dont want to have to buy a expensive computer to run the vvti. any way say what you will, but i will be doing this within the next year or so.
ed_ma61
Lost in the K hole
Re: 1.5JZ Thu, 26 February 2004 23:10 Go to previous messageGo to next message
1JZ.747 wrote on Fri, 27 February 2004 09:54
care to elaborate...
1JZ.747
Osama's hideout
Re: 1.5JZ Thu, 26 February 2004 23:18 Go to previous messageGo to next message
elaborate
yes i can
i read an information sheet where a person had flow tested both heads and found that the 1j head flowed better than the 2j head. that article i read 2 years ago. where it is now i dont know.
ed_ma61
Lost in the K hole
Re: 1.5JZ Thu, 26 February 2004 23:20 Go to previous messageGo to next message
be interesting to read if you can ever dig it up Smile
1JZ.747
Osama's hideout
Re: 1.5JZ Thu, 26 February 2004 23:24 Go to previous messageGo to next message
from what i have found out so far is the oil galleries and everthing line up, a 2j timing belt has to be used due to the engine being 40mm taller. also a 2j head gasket has to be used.
ed_ma61
Lost in the K hole
Re: 1.5JZ Thu, 26 February 2004 23:39 Go to previous messageGo to next message
hehehe... in my reading up on this, i came across this corker of a comment:
"THe 1jz motor revs faster than the 2j because of the head design.
THe cubic inches stays the same. In Japan all the "big dawgs" are running this 1.5jz setup so they can have the torque of the 2j but the faster revving of the 1j, THe compression again stays the same. You gotta remember in Japan they have a horsepower regulation...that is why the skyline, and the 1j & 2j (mk3 &mk4) all have the same factory horsepower ratings of 280ps. THat is why Toyota did not put the 1jz head on the 2j. Also They did this in order to make more torque down low"
and leigh - i agree that yes, 0.5L capacity increase makes a world of difference (der!). and as an upgrade to the 1jz, yes, great idea, especially (as the japs do) if you have endelss access to 2jz blocks etc.
however, consider ::
a) the fact that when it comes to getting the engine number changed (which is on the block!) its going to be perfectly obvious that the capacity has been increased beyond the 'non engineerable' 15% - thus the 'stealth' justification is void.
b) its a lot of fart assing about putting a 1jz head on the 2jz block, why not just drop a whole engine in (unless, of course youve already done significant mods to the 1jz head - or just happen to have a long block sitting around)
c) if youre planning a berserk build, i fail to see why you choose the 1jz head, even if the 1jz head was mildly advantageous over the 2jz head, if you were truly serious about modifying the engine, any of these 'stock' differences would be lost the second you switched on the die grinder.
HedgehogSandwich
UK
Re: 1.5JZ Fri, 27 February 2004 01:07 Go to previous messageGo to next message
blimey you lot have been busy since i asked this Very Happy
To all the doubters.....
The reason most 1.5JZ's are created is due to the fact that is an easy upgrade/rebuild to a 1JZ with a faulty bottom end (which incidentally, mine is now suspect of this very thing, hence the question).
If your 1JZ bottom end goes, you have two choices.. take the engine out, rebuild the bottom end, and plonk it back in... *OR* for virtually the same money (perhaps less) buy a decent working 2JZ block, and slap your 1J head on it.
You've saved yourself time, money, and you've got another 500cc to play with, you've also got the same wiring loom,ECU (possibly) and lot less hassle than droppping in a 2JZ complete engine and farting around with wiring harnesses, ECU's blah blah..
TThats why people do the 1.5JZ... its an easy cost effective and very worthwhile repair whilst being a fantastic mod.
cheers for the replies..
adi
1JZ.747
Osama's hideout
Re: 1.5JZ Fri, 27 February 2004 01:08 Go to previous messageGo to next message
a, no problem in a cressida
b, not a problem either, have a spare 1j head to get worked and cams put in, drop it onto motor, 16 hours approx to take my engine out drop next one in and change over the turbo manifold etc.
car off the road for say 3 days.
c, cause the 2j is a vvti model and i dont want it, and overall
because i can,
1JZ.747
Osama's hideout
manny thanks for your input there too. thats helpful.
ed_ma61
Lost in the K hole
Re: 1.5JZ Fri, 27 February 2004 01:26 Go to previous messageGo to next message
ok, ill attempt to be constructive
http://forums.toymods.org.au/index.php?t=msg&t h=9588&rid=92&S=a6ede4e494b627b268fba5e92d 060950&pl_view=&start=0
wagonist
Toymods Club Treasurer
Re: 1.5JZ Fri, 27 February 2004 01:55 Go to previous messageGo to next message
Didn't Martin Donnon from HPI do this to his 1J Soarer?
I think there was a whole article on it, but can't remember which issue.
1JZ.747
Osama's hideout
Re: 1.5JZ Fri, 27 February 2004 03:12 Go to previous messageGo to next message
no his was a internally standard 1j
wagonist
Re: 1.5JZ Fri, 27 February 2004 04:27 Go to previous messageGo to next message
It must have been a different car then, but I remember it was in HPI, and it was done in Oz.
speakafreaka
Re: 1.5JZ Mon, 01 March 2004 12:05 Go to previous messageGo to next message
does anyone have any idea how much a 2J short block costs from toyota?
if you were looking into this it might be cheaper buying it brand new rather than getting a whole engine.
Stenno
Re: 1.5JZ Mon, 01 March 2004 12:24 Go to previous messageGo to next message
speakafreaka wrote on Mon, 01 March 2004 23:05
$5400, GST inc.
1JZ.747
Osama's hideout
Re: 1.5JZ Mon, 01 March 2004 22:50 Go to previous messageGo to next message
$5400 inc GST, thats cheap i spoke to a guy last month who paid $9000 for one still in toyota plastic.
onejayzed
Re: 1.5JZ Mon, 01 March 2004 23:52 Go to previous messageGo to next message
ed_ma61 wrote on Fri, 27 February 2004 10:39
my point exactly....? Confused
n2734222
Re: 1.5JZ Tue, 02 March 2004 06:59 Go to previous messageGo to next message
I thought the point of a 1.5JZ was to put the later model 1JZ vvt-i head (which apparently flows better due to improved head design) and throw that onto the 2JZ bottom end?
Re: 1.5JZ Tue, 02 March 2004 08:46 Go to previous messageGo to next message
Nope, someone above hit it on the head, it's for retaining all the bolt-on 1JZ head stuff you've accquired when you need a new engine, gaining 0.5l is just a bonus.
Re: 1.5JZ Tue, 02 March 2004 22:49 Go to previous message
n2734222 wrote on Tue, 02 March 2004 16:59
Someone didn't bother reading the thread before throwing his own two cents in. Rolling Eyes
Previous Topic:Will an RA40 diff fit a TA22
Next Topic:5me injecter size
Current Time: Fri Nov 20 14:37:29 UTC 2026
Total time taken to generate the page: 0.022429943084717 seconds
