Toymods » General Car Talk » Fuel Efficiency Between Rotaries and Pistons ..???...
manipulate
Fuel Efficiency Between Rotaries and Pistons ..???... Sun, 11 August 2002 10:40 Go to next message
Hey all
i dunno if this has been covered b4....sorry if it has.
Just wondering which one is more fuel efficient in terms of power output.
Logic would say rotaries are, but ive heard rotaries chugg so i want to clarify this.
ta heaps
Up To Something
[Updated on: Sun, 11 August 2002 10:43]
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Sun, 11 August 2002 11:40 Go to previous messageGo to next message
I've heard rotaries use quite a bit more fuel. Like reading various sites about S6 RX7's and the guys car would average around 20l/100km when being driven around the streets, hard, but not always caning it.
An equivalent piston engine (S15 Silvia Jap Spec) I'd imagine would use much less fuel than that.
Having said that, Mazda are supposed to have gone back to the drawing board and totally changed the ports on the RX8's engine so things could start to even out.
toyrota
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Sun, 11 August 2002 22:18 Go to previous messageGo to next message
Don't be fooled rota's chew the juice when driven hard,and they go through a bit just cruising but I wouldn't go any other way they ROCK
MS-75
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Sun, 11 August 2002 22:59 Go to previous messageGo to next message
Yeah, rotors are less efficient by virtue if their basic design. You can prettymuch equate them with two stroke piston motors. (ie power hit for every rev of the crank/eccentric shaft for each cylinder/chamber) Also, they tend to waste a lot of energy and fuel out the exaust-hence the very hot exhaust on most rotors-however, this drawback is also one of the reasons they respond soooo well to turbos.
Beautiful bit of machinery once you learn to sort out the the bullshit about them from the facts.
Sean
Esteban
Brisbane - Chapel Hill
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Sun, 11 August 2002 23:45 Go to previous messageGo to next message
Yup, that is correct, rotaries to expend a lot of heat energy out through the exhaust.
However, when it comes down to fuel economy, it all comes down to the fuel management system. eg. A badly tuned carby can waste just as much fuel on both design designs.
Also, one must remember, that a rotray is really a performance engine, (Well, at least in my opinion) and as such, is usualy tuned for performance hence trading fuel efficiency for power.
I dont have any figures, but I suspect an economy tuned turbocharged rotary and an economy tuned piston of equivalent capacity (I'm not opening that can of worms) both running a low boost, would achieve very similar fuel economy.
I say low boost, since a lot of vehicles used in the comparisons we see, are running insane boost levels, with huge spool-up time, and extremely rich mixtures to avoid detonation.
Another factor, is driving style with a rotary. They only start to sing above 3-4 grand, and keep on singing until 8+ grand, however dont tend to have as much torque down low (tho this can be fixed by manifold design of course) which shifts the drivers ger changes up higher in the rev-range, requiring more fuel for an equivalent distance.
Still, I know which I'd rather Smile
Re Rensesis: I think it's still a 6-PI N/A with revised port timings, but the major difference is the exhaust is no longer peripheral. Perhaps this will address some of the above-mentioned exhaust heat-loss issues. I cant wait to see one!! Smile
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 12 August 2002 01:34 Go to previous messageGo to next message
Hmm... I can't wait for the Renesis either.
Should be good. Although they're not claiming 206kW any more...
manipulate
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 12 August 2002 07:26 Go to previous messageGo to next message
Hmmm....So what are some more advantages to the rotary engine then....???
cause im contemplatinging of going rotary for my conversion
ta
[Updated on: Mon, 12 August 2002 07:59]
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 12 August 2002 08:45 Go to previous messageGo to next message
It's hard to compare rotary engines to piston engines, since only one major manufacturer actually makes rotary engines! Mazda has always used the rotary engine as its performance flagship, so you wouldn't expect it to be tuned for maximum efficiency. If you think of it as a highly-strung 2.6 litre engine, its fuel economy actually looks pretty much normal.
As for the advantages of a rotary engine - they're very compact and are capable of awesome power output with relatively minor mods. There are lots of people these days who know how to extract BIG numbers out of a 13B.
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 12 August 2002 09:09 Go to previous messageGo to next message
Mazda scrapped the 206kW version of the RENESIS because it was going to be too difficult to mass produce, especially when they are trying to keep the car in the S2000 bracket. Still, I think the 187kW version is still going to be awesome.
SUPRAGTE
North Sydney
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 12 August 2002 10:52 Go to previous messageGo to next message
I think one of the greatest advantages of the RE is the weight of the engine and it's size. Equivalent to a 20 gallon drum in your engine bay which is great for keeping lightweight package.
My best mate had an RX2 with a race-prepped 4port 13B. Removed the engine and sent the car to the panel beater but he went broke and took the car. He still has the awesome engine which has only done 3000kms! Revs to 9&3/4 and has a delorto carby.
We've got sound file of it revving easily over 9 grand.
PM me if your interested in buying it, was built by a guy who races 20b's round oran park and is very reknown.
toyrota
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 12 August 2002 11:18 Go to previous messageGo to next message
When I first got my 23 it was stock and used about 3/4 of a tank to go from inner Sydney to Mudgee.With the 13b in it the first few times driving it easy it used about the same.Now that I know and trust it it gets driven a bit harder and uses a bit more but it's not getting any newer and it was 5 or so years ago that this engine was doing it and it has only ever been serviced in that time NOT rebuilt.
To answer the question better from someone who has been there drive an 18rc or 13b(mildport) steady and they about the same.drive a twin carbed 18rg hard and a 13b(mildport)hard and the 18rg would use more (it did in my brothers Hilux).The piont is that it is hard to say work out what sort of hp you want then work out how you want to get it.
Remember horsepower is not cheap,the rest is up to you
Jonny2TG
Tasmania
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 12 August 2002 12:35 Go to previous messageGo to next message
I think a small engine running at high rpm will use more fuel than a bigger engine running at a slower rpm, both producing the same power. Just my thought.
And a 13B is the equivelent of a 1.3 litre motor right? Often compared to 2 litre motors making the same power at lower revs?
My standard 2TG is getting about 11.7 litres/ 100km at the moment, on carbies. Depends on driving style. And if I drive hard, its not that much different, maybe 12.1 litres. If you drive a rotary hard, it will use double that fuel.
manipulate
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Tue, 13 August 2002 05:52 Go to previous messageGo to next message
Hmmm...interesting
Well so far the only major downfall is chugg factor which is not much of a hassle
ta for the reply's
dorikin
NE Melbourne
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Tue, 13 August 2002 08:08 Go to previous messageGo to next message
sorry to come in with late information... part of the reason for chuggine fuel is the rotary's huge requirement to consume air!!! for a given power output, a same size piston engine will consume less air. so to keep the engine happy, it needs to have an appropriate air/fuel ratio... more air, more fuel!!!
rotaries are often avoided in racing situations where intake restrictors are used. this is simply because fo a given amount of air consumption, a piston engine makes more power!!!
[TOYROTA]
A.C.T
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Thu, 15 August 2002 05:04 Go to previous messageGo to next message
Hey Manipulate, I have 9 words for you mate;
"If It Ain't A Rotor, It Ain't A Motor!" Nod Nod Nod
(of course there are a select few exceptions, but i prefer to keep with the above motto.) Wink
André
ps. If anyone is going to write-in and try to complain about what i have just written, yes your engine is one of the "Select few"
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Thu, 15 August 2002 06:28 Go to previous messageGo to next message
Man, if you are going to make that quote, you have to put it in the dodgy Japanese accent of the dude who first said it Razz
[TOYROTA]
A.C.T
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Thu, 15 August 2002 06:50 Go to previous messageGo to next message
haha, yeah well. It's good to see that no wanker has decided to just jump into this convo and knock rotors. I hate people that just think that thay can say what they want and that their opinion is the be all and end all. Especially cunts that go around knocking rotors. My previous quote was just a saying i like to use because it's pretty hectic, i was obviously joking about the piston thing. There are heaps and heaps of awesome piston engines around, and if for some (highly unlikely) reason i decide that i don't want to put a rotor back in my Celica, my next choice will definately be a piston engine of some decription...lol jokes.
André
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Thu, 15 August 2002 06:53 Go to previous messageGo to next message
Rotors are real cool, no denying that...there is only one thing I've never heard sounding right...the noise No No No
From the mild, to a PP one...all blat blat...
Hopefully the different way Mazda made the RENESIS will change the acoustics Very Happy
[TOYROTA]
A.C.T
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Thu, 15 August 2002 07:33 Go to previous messageGo to next message
I'm assuming you've never heard a 3 rotor 20B then! The 20B is un-denieably the best sounding engine in the world in my books, and i'm sure even some of the most die-hard V8 lovers will agree that they are an awesome sounding engine. I admit that a non-turbo ported 20B can slightly resemble it's twin rotor sisters, however only slightly and this is more than adequately made up for by it's sheer roar from all 3 rotors under full throttle. Twin rotors bark or yell, tripple rotors ROAR! I suggest you seriously try to download some video clips of ROTORMASTER's 20B powered R100 doing a half-track burnout, the sound is unbeleivable! As for the usual twin rotor sound, it's all just personal opinion. Most people say they sound crap simply because they are different. They don't sound conventional so people like to pay them out. "ohh they sound like chickens on steroids" and crap like that. Personally i think the majority of them sound awesome. I used to hate Rotors with a passion when i was younger, but that was because i just went with the flow. But once i came to experience them first hand, i realised how awesome they really were and never looked back, now i can't get enough of them! Yes i agree that some of them really sound sickening, like tired 12A's and little 10A's with bad exhausts and the like. They sound really tinnie and aweful. However i love the deep bruuup bruuup bruuup from a fresh 13B peripheral port running injection and a deep, yet not too obtrusive exhaust. And of course you cant go past the smooth injected turbo 13B's in cars like FREAKY and AXX-13B. The mixture of the turbo spooling up and the Rotarie's exauhst note are simply meant to be!
André
Ps. Make sure you get videos of ROTORMASTER's old R100 at full noise!
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Thu, 15 August 2002 07:39 Go to previous messageGo to next message
Maybe its just the little buggers...I dunno, the 20B's I'd heard hadn't been "that" great...
The only awesome one was the R26B from the 787B Le Mans car...that sounds pretty cool!
[TOYROTA]
A.C.T
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Thu, 15 August 2002 07:59 Go to previous messageGo to next message
go to 3rotor.com and go to the HB audio clips down the left-hand side of the page. Then just click on the first one at the top. It's not the best 20B i've heard, but it sure as hell shows that they are not the same sounding engine as the 2 rotors. Try to find on the site a video clip of the ROTORMASTER R100 doing the burnout.
Also i doubt that the new renesis engine will sound all that much different from the old design. Yes the exhaust is no longer of a peripheral port design, this may make a slight difference, however it is not likely to make all that much difference once you fit a fat exhaust and port the thing!
André
Go the Rotors!
RollaLevin
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Fri, 16 August 2002 00:58 Go to previous messageGo to next message
*WARNING* TRIVIAL INFORMATION POST! *WARNING*
For what it's worth. Norton have made at least 2 different Rotary engined bikes, and nissan(!!?!?!?) apparently did a run of rotary silvias, however these are quite old definitely s10 thru s12 somewhere.
Sam
Sydney, Australia
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Fri, 16 August 2002 01:53 Go to previous messageGo to next message
And Mazda also sold a rotary powered Kingswood in Japan during the 70's... Mazda Roadpacer... TRUE!!!
http://www.holdenhistory.com/images/roadpacer.jpg
[Updated on: Fri, 16 August 2002 01:57]
Pete
gold coast
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 19 August 2002 12:03 Go to previous messageGo to next message
Nice Premmie!! All it needs is a 20B
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Mon, 19 August 2002 15:45 Go to previous messageGo to next message
if you get a 12a, then it doesn't "blat blat" (as someone said) ... it sounds more like a normal engine.
a 13B peripheral port blats with the best of them at idle.... but tends to scream higher up.
I'm with toyrota here though, the 20B is an amazing sounding engine (plus I've seen the vid of a sprinter with a 20B turbo in it... 650bhp.. you'll never bad a rotor again when you see that thing drag from 100km/hr)
AE86
Face down in a ditch
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Tue, 20 August 2002 03:53 Go to previous messageGo to next message
I just thought I'd throw my 2 cents worth into the thread because I've owned a couple of Rotaries.
First of all, the biggest consideration is not the juice they chew, but when they break, you are up for alot of money to get them fixed. Destroy one apex seal and you are up for a $2k+ rebuild. That said, if you use top quality oil, warm the car up completely and let it warm down after being thrashed, you should have no problems.
Dunno if this was mentioned, but the reason they use more petrol when thrashed is because for each turn of the crank (eccentric shaft), they make 6 power strokes. As I'm sure you know a 4 stroke motor only makes 2 power strokes for each turn of the crank.
[TOYROTA]
A.C.T
Re: Fuel Efficiency Between Rotaries and Pistons ..???... Tue, 20 August 2002 04:00 Go to previous message
Yeah thanks Draven, good to see you're on the goodies side! If anyone wants to see that insane 20B powered Trueno then go to http://www.3rotor.com and then go to "3rotor speed kings" on the left hand side menu, then go down to the 20B sprinter bit and load it! Still can't remmember where i got the video of Rotormaster's R100 doing a half-track burnout but when i do i'll let everybody know, it's the best 20B you'll ever hear. Also go to http://www.geocities.com/cd23c/hydrogen.html for some interesting info on the hydrogen adaption to the rotary engine that we were discussing in a previose thread.
André
Previous Topic:Big block Crown out prowling..
Next Topic:For a laugh...
Current Time: Thu Nov 19 14:40:39 UTC 2026
Total time taken to generate the page: 0.091916084289551 seconds
