Toymods » Tech & Conversions » 4AGE Throttle position sensor wiring
TE72_Turbo
4AGE Throttle position sensor wiring Sun, 11 August 2002 10:49 Go to next message
does anyone know what the 4 wires on a 4AGE throttle position sensor are?
are the sensors variable resistance, and therefore able to read all throttle positions, or are they an idle/full throttle switch only?
Phil
Grega
melbourne.victoria.austra...
Re: 4AGE Throttle position sensor wiring Sun, 11 August 2002 11:02 Go to previous messageGo to next message
phil, as follows :
IDL - no idea
VTA - no idea
VCC - Constant Voltage (+5v I think)
E2 - Earth
I know VCC and E2 also goes to the MAP sensor if that helps. they are variable resistance type too.
[Updated on: Sun, 11 August 2002 11:03]
jazae86
Re: 4AGE Throttle position sensor wiring Sun, 11 August 2002 14:52 Go to previous messageGo to next message
With round body to left, connectors right, reading down the wires:
E2
IDL
VTA
Vcc
They are varying resistance: 3 wire TPS is step.
I would write out the resistance between terminals and movement of sensor but I shall just suggest you go buy:
"Max Ellery's Vehicle Repair Manual"
Corolla's/Nova's 1985-1998
Sedan Seca Hatch"
It has AE86 stuff (some) covers bigport 4AG and some small port 4AG.
Order no: EP COR/N
well worth the $40 or so.
Jaz
Grega
Re: 4AGE Throttle position sensor wiring Sun, 11 August 2002 22:08 Go to previous messageGo to next message
This might help too :
http://sprinter.qnix.com.au/docs/wiring/4AGE-100kw
TE72_Turbo
Re: 4AGE Throttle position sensor wiring Mon, 12 August 2002 12:34 Go to previous messageGo to next message
thanks guys, i think i've got it figured now.
VCC: 5V constant
VTA: variable resistance (?)
IDL: Idle switch
E2: Earth
so with the haltech ECU, i should only have to use VCC, VTA & E2.
Phil
Re: 4AGE Throttle position sensor wiring Tue, 13 August 2002 02:43 Go to previous message
What you have got there is correct.
VTA Red Variable Signal
IDL Blue Closed throttle signal
E2 Brown Earth
VCC Yellow (Or Blue/Red) +5 DC
Regards,
Joel
Previous Topic:vaccum lines on a GT????
Next Topic:3TGTE ignition leads
Current Time: Sat Oct 24 03:16:57 UTC 2026
Total time taken to generate the page: 0.0036869049072266 seconds
