Toymods » Tech & Conversions » Rt104 Radiator Questions
BlackieWolfie
Melbourne,Victoria
icon5.gif  Rt104 Radiator Questions Thu, 26 February 2004 07:20 Go to next message
Hi People,
I am considering buying a Rt104 Auto Corona.
The guy reckons the Radiator redlines it,but stays at the same position sort of quickly-ish.
Any idea's as to the problem & I need some answers in regards to this problem.
Also,what else do I need to check out on this car.
All seem's well,But some fairly common problems to watch for & how to fix them would be greatly appreciated.
Steve
Mr DOHC
Re: Rt104 Radiator Questions Thu, 26 February 2004 10:29 Go to previous messageGo to next message
that makes absolutely no sense,
make sure the bailer channel are all there and so are the door rubbers,
clancey
Re: Rt104 Radiator Questions Thu, 26 February 2004 12:01 Go to previous messageGo to next message
Watch for rust, most of them are full of it.
And yes, most of what you just said makes no sense.
M.W.P.
Rocky Mountains, Canada
Re: Rt104 Radiator Questions Thu, 26 February 2004 16:05 Go to previous messageGo to next message
Hi Steve.
Rust... everywhere.
Door corners, under the front & rear windows, sill just behind the front wheels, body just behind rear wheels.
Same spots for all 70's toyotas Sad
BlackieWolfie
Melbourne,Victoria
Re: Rt104 Radiator Questions Fri, 27 February 2004 02:29 Go to previous messageGo to next message
In regards to the radiator,I'll try & clarify the problem.
From what the guy told me,but don't quote me on this,is that the radiator gets up to the red line fairly quickly,but then it stays in the same position.
Doe's this make it any clearer for people?
That's from what I can make out from what the guy told me.
Doe's anybody have any thought's on what the problem could be then & a possible answer?
Steve.
M.W.P.
Re: Rt104 Radiator Questions Fri, 27 February 2004 04:03 Go to previous messageGo to next message
Goes to red then stays could be:
Bad thermostat.
Bad temp sensor.
Bad temp gague.
people100
Rocklea qld
Re: Rt104 Radiator Questions Sat, 28 February 2004 22:37 Go to previous messageGo to next message
I bet my money its 1 of two things. Its either only running water which in a old car like that is likely and it turns to mud and blocks the radiator. Very common as i see it every day or he has let it get hot to many times and has cooked the head. Also see that very often. Get someone to dump the water and high pressure flush it and do a head test on it before buying if possible. Or just offer him a smaller amount to leave yaself some money for the obvious repairs it will need. But start with a radiator cleanout and high pressure flush.
Re: Rt104 Radiator Questions Sat, 28 February 2004 23:13 Go to previous message
Seriously dude, RT104s are everywhere and cost nothing. Find another that is mechanically sound - this one sounds like headaches and money.
Previous Topic:LSD in an AE86
Next Topic:3A/4A and 4AG Blocks?
Current Time: Sat Oct 24 09:11:00 UTC 2026
Total time taken to generate the page: 0.0057442188262939 seconds
