Toymods » Tech & Conversions » Air/Fuel Ratio Gauge connections for AE112 Sportivo Corolla (7A-FE w/ turbo)
RollaTurbo
Carlingford
Air/Fuel Ratio Gauge connections for AE112 Sportivo Corolla (7A-FE w/ turbo) Fri, 27 February 2004 05:23 Go to next message
Hi all, new member, I've got one of the gold Sportivo turbo Corollas, and am trying to hook up my air/fuel ratio gauge atm and not enjoying it at all. I can't seem to find the oxygen sensor on the exhaust manifold (it's very crowded down there), but I believe you're supposed to actually splice it in closer to the actual ECU anyway in case the sensor uses shielded wiring.
My question is, has anyone got any sort of wiring information on these engines, or know where I could get some? I've tried going to a Toyota dealer, but was told that they're not allowed to give out any sort of technical information on the cars, in case I go and blow myself up or something and then sue them.
The actual ECU is a Tom's unit but I would imagine it's the same pinouts as the factory Toyota unit to avoid any problems when the turbo kits were installed.
If anyone has any ideas or leads they would be very much appreciated, cheers
Re: Air/Fuel Ratio Gauge connections for AE112 Sportivo Corolla (7A-FE w/ turbo) Fri, 27 February 2004 12:06 Go to previous message
These were 'supposed' to just have a remapped factory ECU in them, so the pinouts should be the same. Thing is, a normal oxy sensor type mixture gauge isn't exactly accurate anyway, you know...
Previous Topic:need new engine
Next Topic:1G-GTE turbo differences
Current Time: Thu Oct 22 14:54:10 UTC 2026
Total time taken to generate the page: 0.004796028137207 seconds
