Toymods » Tech & Conversions » Fuel pump recommendation
Fuel pump recommendation Sat, 28 February 2004 07:33 Go to next message
I am getting my fuel tank modified to take an intank fuel pump. Just wondering if anyone has any recommendations. The only requirement is that it should be able to handle 250-300 hp worth of fuelling.
Thanks in anticipation.
Cheers Dave.
Manny
Re: Fuel pump recommendation Sat, 28 February 2004 07:44 Go to previous messageGo to next message
I'd suggest the 255lph Walbro or the 280lph Denso/USDM Supra intank pumps if you want some headroom.
Below are a few common Soarer upgrade options
http://www.trackdaymedia.com/~manny/Tech%20&%20Diag/fp%20comparo.JPG
Re: Fuel pump recommendation Sat, 28 February 2004 14:14 Go to previous messageGo to next message
Thanks Manny. The 1UZ and 1JZ fuel pumps will be fine in the interim (engine will remain completely standard for at least a year or so) - just wondering if you know roughly what they flow?
Re: Fuel pump recommendation Sun, 29 February 2004 03:08 Go to previous messageGo to next message
Walbro is the way to go, I'm using one in the Supra and it's great. It will easily flow the power you're after.
Re: Fuel pump recommendation Sun, 29 February 2004 03:12 Go to previous messageGo to next message
If you guys don't mind me asking, what is a ball park figure that I'd be look at for a Walbro?
Re: Fuel pump recommendation Sun, 29 February 2004 03:19 Go to previous messageGo to next message
http://www.autoperformanceengineering.com/
That's where I got mine from. I bought the high-pressure 255lph pump, but the "normal" 255lph pump should be plenty for your needs. US$85 plus shipping, which from memory was pretty cheap.
Manny
Re: Fuel pump recommendation Sun, 29 February 2004 06:37 Go to previous messageGo to next message
Not sure of exact flow rates, but the Soarer 1J fuel fuel pump flows enough fuel for 250rwkw at standard 3 bar base rail pressure. Quite a few lying around after upgrades on the ALSC - no one seems to be able to sell them on there as they don't seem to fail.
Re: Fuel pump recommendation Sun, 29 February 2004 07:12 Go to previous message
Bosch make an internal pump that is meant to be good for 550hp and costs around $200. I think it was used in some Merc V8's. K-Jetronic.
But sounds like the Walbro's are cheaper Smile
Previous Topic:VNT turbos! (links to a great picture site)
Next Topic:Water vs Carbon Buildup drama
Current Time: Mon Oct 26 16:19:25 UTC 2026
Total time taken to generate the page: 0.048782110214233 seconds
