Toymods » Tech & Conversions » Aus-spec AE86 calipers with vented Japanese Discs
mumblezzz
Gold Coast
Aus-spec AE86 calipers with vented Japanese Discs Sun, 29 February 2004 11:51 Go to next message
I have a pair of vented AE86 discs lying around and was wondering if it was possible to squeeze the standard non-vented calipers over them?
Any help would be appreciated. Smile
-Paul
Jonny2TG
Tasmania
Re: Aus-spec AE86 calipers with vented Japanese Discs Sun, 29 February 2004 12:09 Go to previous messageGo to next message
Somehow I doubt they would fit. I have not tested, but the vented disk will not fit in the caliper made for solid disks. If you want some brake calibers, use early Tarago ones. They are for 20mm thick disks and look identical to the JDM AE86 ones. You will need to make a adapter plate of some sort. I don't know how thick the vented AE86 disks are, but I am guessing they would be 20mm. The solid disks would be about 11mm thick.
JDM hachi
was adelaide now newcastle
Re: Aus-spec AE86 calipers with vented Japanese Discs Sun, 29 February 2004 12:21 Go to previous messageGo to next message
ive seen this done, but i dont know if the pads had to be slightly worn (ie thiner) to fit on.
Callifo
Gawler, SA
Re: Aus-spec AE86 calipers with vented Japanese Discs Sun, 29 February 2004 13:25 Go to previous messageGo to next message
Japspec disks are supposed to be 17mm minimum if I remember correctly. Ones I have in the shed are down to 15mm so they arent legally allowed to be fitted. Think Ill just wait till I can grab rotors + calipers and do it properly.
JDM hachi
Re: Aus-spec AE86 calipers with vented Japanese Discs Mon, 01 March 2004 06:49 Go to previous message
just go to your nearest autobahn, they sell ebc discs and the jap spec vented ones are easy to get, cost about $200 ish..
matty.
Previous Topic:Gearbox
Next Topic:FWD 4AGE oxy sensor
Current Time: Mon Oct 26 08:42:54 UTC 2026
Total time taken to generate the page: 0.0041871070861816 seconds
