Classifieds » Miscellaneous » 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel
ed_ma61
Lost in the K hole
1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Mon, 01 March 2004 02:49 Go to next message
Brand New custom machined lightweight cromolly flywheel. 6.2kg including ring gear.
For use with w58 gearbox mounted to any of the following:
1jz-gte
2jz-gte
2jz-ge
uses 236-240mm clutch, based on standard 2jz-ge pressure plate pattern (ie you can just buy a standard 2jz-ge unit, and it will all bolt up, or you can specify to your clutch place that you want a heavy duty clutch to suit a 2jz-ge. one way or another, its easy to get clutches to fit and work as its all based around the existing 2jz-ge design)
$370 + shipping (about $10-15 depending where you are)
sorry for the following craptacular webcam pics, i have more and will upload them later this eveing.
http://www4.tpg.com.au/users/loats/toymods/2.jpg
http://www4.tpg.com.au/users/loats/toymods/3.jpg
http://www4.tpg.com.au/users/loats/toymods/1.jpg
ed
ed_ma61
Lost in the K hole
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Mon, 01 March 2004 02:50 Go to previous messageGo to next message
PS - it DOES include the ring gear (just not pictured on above photos)
ed
ed_ma61
Lost in the K hole
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Mon, 01 March 2004 11:31 Go to previous messageGo to next message
bump Very Happy
ed_ma61
Lost in the K hole
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Tue, 02 March 2004 10:58 Go to previous messageGo to next message
you know i hate bumping stuff, so someone just buy it!!
7M-Brisbane
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Tue, 02 March 2004 12:41 Go to previous messageGo to next message
This type of thing is pretty hard to come by, worth picking up if you plan on a manual conversion down the track. I had trouble finding the parts and have since gone auto!
quick 6
Brissy
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Thu, 04 March 2004 12:06 Go to previous messageGo to next message
Very Very interested.
i curently have a brass buton clutch in mine but have cracked the stock flywheel. would this be a suitable replacement.
if yes let me know asap.
Roland
www.autostyles.com.au
ed_ma61
Lost in the K hole
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Fri, 05 March 2004 00:23 Go to previous messageGo to next message
roland - assuming youre using a w58 gearbox, this will work perfectly.
ed
Celia-Sue
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Fri, 05 March 2004 05:49 Go to previous messageGo to next message
*Free Bump*
Mr. Ed., I HATE YOU Mad
I paid $250 two weeks ago for a stock JZA80 W58 flywheel. Where were you when I had money????
Smile Justin, JZA61
ed_ma61
Lost in the K hole
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Fri, 05 March 2004 08:14 Go to previous messageGo to next message
hehehe, i actually had this over a month ago, buit got dicked around by ye who was supposed to buy it No No No
ah well
someone lucky chump will get it eventually
ed_ma61
Lost in the K hole
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Sat, 20 March 2004 08:58 Go to previous messageGo to next message
*bump*
Rolling Eyes
Shotgun
Auckland, New Zealand
Re: 1JZ-GTE 2JZ-GTE 2JZ-GE Manual Flywheel Wed, 24 March 2004 23:49 Go to previous message
Yep I'm keen. You have PM.
Previous Topic:AE86 Hatch seal
Next Topic:hks cooler
Current Time: Tue Oct 27 10:05:25 UTC 2026
Total time taken to generate the page: 0.031519889831543 seconds
