Toymods » Tech & Conversions » 1jz won't start
supra86
1jz won't start Mon, 01 March 2004 03:48 Go to next message
any tech on how to check the fuel pump working or not on a ma70 with a 1jz. the stock surge tank(if it is one) has no petrol in it and there's no leak along the fuel line.
the car cranks but wont start
any help would be greats
Re: 1jz won't start Mon, 01 March 2004 04:16 Go to previous messageGo to next message
turn the ignition to the on position, and et someone to sit near the back and listen for it
wastegate
Gold Coast
Re: 1jz won't start Mon, 01 March 2004 04:18 Go to previous messageGo to next message
First of all check the EFI Fuse, then the Fuel Pump Fuse then the Fuel Pump relay. Using a multimeter you can use the check connector next to the plenum to check if the pump is getting voltage. Undo the return line and crank with the return line on a container to see if it flowing.
Also check the open circuit relay.
Are you getting spark?
When you say surge tank then you have a aftermarket fuel system? As just about no car has a external surge tank from the factory.
If you have a surge tank then you would have a feed pump to the surge tank then a high pressure pump from the surge to the fuel rail. If the surge is not filling up then I would be looking at the feed pump.
Need more info.
7M-Brisbane
Re: 1jz won't start Mon, 01 March 2004 08:17 Go to previous messageGo to next message
Um.....
Re: 1jz won't start Mon, 01 March 2004 11:54 Go to previous messageGo to next message
Normal way is to squeeze the 'pressure side' (before regulator) fuel hose as hard as you can with your fingers, then turn the key on, you should feel it 'bulge' slightly
If no luck there, pull the hose off, if no pressure built up, then point the end in a tin and see if there's any fuel flow with the key first turned on for a couple of seconds.
Also, are you sure you have spark, the injectors are working, etc.?
sideshow
Re: 1jz won't start Mon, 01 March 2004 11:59 Go to previous messageGo to next message
has the car ran at all
is this a conversion and u r stuck
some 1js have an fuel pump ecu sort off
and u cant use a circuit opening relay properly
so u just run fuel pump off ignition
or try get one of these fuel pump ecus
i think these are jzx30 1js
otherwise find the pump and see if u have 12vs at the blue wire
and an earth on the white/black trace wire
start at the fuel pump then work yr way back to the front
supra86
Re: 1jz won't start Tue, 02 March 2004 07:47 Go to previous messageGo to next message
the car has ran for nearly a year after the conversion
dont i need to jumper the FP and B+ in the diagnosis block to test the pump, i not really sure though. spark and injectors are working. i cant hear anything when the car is on red.
mistake on the surge tank. it is a black rectangula shape, the top hose go back to the throttle (the line is next to the return line). what's that
HedgehogSandwich
UK
Re: 1jz won't start Tue, 02 March 2004 12:57 Go to previous messageGo to next message
yep, jumper the diagnostic... that should make your fuelpump run at full voltage..
Sometimes the fuel pump relay goes, causing the probs you describe.
wastegate
Gold Coast
Re: 1jz won't start Tue, 02 March 2004 22:47 Go to previous messageGo to next message
That or it's a stuffed Fuel Filter Very Happy
Just ask me how I know!
7M-Brisbane
Re: 1jz won't start Tue, 02 March 2004 23:43 Go to previous messageGo to next message
Don't quote me on this, but I am pretty sure that MA70's don't actually build up fuel pressure in the 'on' position. I would guess that JZA70s may be the same...
Stenno
Re: 1jz won't start Wed, 03 March 2004 01:22 Go to previous messageGo to next message
7M-Brisbane wrote on Wed, 03 March 2004 10:43
Correct - fuel pump only runs when the opening circuit is on, which is when the ignition is cranking and once the motor fires, if the motor stalls, the fuel pump will stop - unless you've bypassed that relay Smile
HedgehogSandwich
UK
Re: 1jz won't start Wed, 03 March 2004 12:10 Go to previous message
unless the diagnostic is shorted, in which case the pressure should raise, and return by the return line.
Previous Topic:Exedy Clutches ... Opinions?
Next Topic:Cold air induction
Current Time: Fri Nov 20 14:56:33 UTC 2026
Total time taken to generate the page: 0.074447870254517 seconds
