Toymods » Tech & Conversions » Has anyone got a 1/2JZ MA61 with air con
BlackSupra
Has anyone got a 1/2JZ MA61 with air con Mon, 01 March 2004 06:57 Go to next message
Just wondering if anyone with a JZ motor in an MA61 has got the aircon hooked up and running?
How was it done?
I seem to have a few loose end around the place!
BlackSupra
Re: Has anyone got a 1/2JZ MA61 with air con Mon, 01 March 2004 22:33 Go to previous messageGo to next message
So no one has air con?
Re: Has anyone got a 1/2JZ MA61 with air con Mon, 01 March 2004 22:34 Go to previous messageGo to next message
Not me... I keep meaning to get around to it but I haven't yet. What loose ends are you referring to?
BlackSupra
Re: Has anyone got a 1/2JZ MA61 with air con Mon, 01 March 2004 22:42 Go to previous messageGo to next message
well i have determined the wire from the clutch magnet, but need to figure out the one from the MA61 air con system. And according to the TSRM there is a 'pressure switch' along the way somewhere, on the wire that i beleive is the one we need to hook up to.
But i can't seem to get any continuity in the wiring to the A/C switch and i don't want to bypass the pressure switch if its there for a reason.
You can see the clutch magnet, the a/c switch and the pressure switch, which i have no idea as it its position!
EDIT: http://www.cygnusx1.net/supra/library/TSRM_MKII/e/ E_007.html
[Updated on: Mon, 01 March 2004 22:48]
82MKII
Re: Has anyone got a 1/2JZ MA61 with air con Tue, 02 March 2004 05:29 Go to previous messageGo to next message
BlackSupra,
I've sent you an email with some more detailed schematics attached (with locations of connectors).
Hope it helps.
Regards
Peter
BlackSupra
Re: Has anyone got a 1/2JZ MA61 with air con Tue, 02 March 2004 06:46 Go to previous message
Thanks for that Pete!
it has made it alot clearer what im searching for. The location for the pressure switch doesn't seem to be made very clear though. Hopefully i can find that, then hopefully hook the rest up!
Previous Topic:injector cleaning
Next Topic:4A-GE Head gasket specs
Current Time: Fri Nov 20 22:03:41 UTC 2026
Total time taken to generate the page: 0.004425048828125 seconds
