Toymods » Tech & Conversions » Aftermarket computer wiring. Igniters.
celicaboy_2000
Lismore, NSW
Aftermarket computer wiring. Igniters. Mon, 01 March 2004 09:54 Go to next message
Hey, Im currantly sorting out my Wolf3D installation and am having troubles with my igniters. Have any of you guys done wiring of igniters for any aftermarket computers? What have you learnt about getting power, grounding and interference? Any help would be appreciated. Oh im using 3 Igniters to fire 3 dual ouput coils.
Thankyou
Matthew
sideshow
Re: Aftermarket computer wiring. Igniters. Mon, 01 March 2004 09:57 Go to previous messageGo to next message
what ignitors are u using
wolfs have a bad prob with interference sometimes
u should be able to use factory ignitor with the 3 outputs
otherwise buy an ems ignitor that does 3 channels all in one unit
theyre cheapest way out
Henn
Rosanna, Melb
Re: Aftermarket computer wiring. Igniters. Mon, 01 March 2004 11:45 Go to previous messageGo to next message
Maybe I was just lucky and missed out on interference problems when I wired my Wolf to igniters. I used Bosch ones out of a Camira (They sit under the coil. 008 model I think) and checked the Motec website to find out how to wire them up. They only needed +12, ground, signal from ECU and signal to coil.
They've worked fine and I didn't need to change any of the dwell times and that crap, which is lucky because I have no idea what it all means.
Best part is those igniters are free from Pick a Part.
Hen
sideshow
Re: Aftermarket computer wiring. Igniters. Mon, 01 March 2004 11:54 Go to previous messageGo to next message
well on a nissan firing order
not to sure if toyota the same
u have ignition output no1 to ignitoer no1 then to coil no1 which runs cyl 1 and 6
then output 2 to ignitor 2 to coil 2 to cyl 2 and 5
the oput 3 to ign 3 to coil 3 to cyl 34
i think thats how i did it last time
on a multi coiled setup
what is yr prob with the ignitors
Grega
melbourne.victoria.austra...
Re: Aftermarket computer wiring. Igniters. Mon, 01 March 2004 18:41 Go to previous messageGo to next message
camira ignitors. 008's - can't be beat. go to wreckers and get for $5 (or free depending on how honest you are) - using with Haltech IG5.
IRA11Y
Club Member
Re: Aftermarket computer wiring. Igniters. Tue, 02 March 2004 03:30 Go to previous messageGo to next message
sent you a PM
you can see how i mounted my ignitors in this pic, the alloy seat acts as a very big heat sink Smile
http://ira11y.qnix.com.au/enginecomplete002.jpg
[Updated on: Tue, 02 March 2004 07:32]
akmehd
carlingford
February 2005
Re: Aftermarket computer wiring. Igniters. Wed, 17 August 2005 02:28 Go to previous message
link doesnt work mate
Previous Topic:ae82 brake conversion into sprinter?
Next Topic:W58 and R154 speedo cables
Current Time: Sat Oct 24 12:51:43 UTC 2026
Total time taken to generate the page: 0.0051400661468506 seconds
