Toymods » Tech & Conversions » AE86 suspension
45aken
NSW.south coast.Drifting
icon14.gif  AE86 suspension Mon, 01 March 2004 15:04 Go to next message
hello i was wondering, as a newcomer to the ae86 scene, what suspension mods provide the best performance for your dollar? what are the main issues that need to be looked at in terms of suspension?
also anyone have an article on an LSD diff in an ae86?
LiL_MiC
Melb
Re: AE86 suspension Mon, 01 March 2004 23:52 Go to previous messageGo to next message
www.club4ag.com have exactly those articles. You could even run a search thru this forum as well.
FKN16V
NSW, East Coast
Re: AE86 suspension Tue, 02 March 2004 23:47 Go to previous messageGo to next message
It all depends on what you want the car to do?
Do you want it drop on its arse for a street look or drift set-up, set-up for track work, set-up for drag
Maybe a combination of all of them.
A search as mentioned before would be a good start.
45aken
Re: AE86 suspension Thu, 04 March 2004 22:01 Go to previous messageGo to next message
drift/track there both nearly the same setup but thats what im going for, mainly drift. what is the basic i could get away with??
i was thinking strut bar@front, antiroll bars front and rear, shocks and lowered springs. most of it being whiteline. any more suggestions?
Re: AE86 suspension Thu, 04 March 2004 22:05 Go to previous messageGo to next message
I gotta disagree with your comment about drift and track setup being similar.
In my limited experience they are VERY different. One is setup for road holding, the other to promote sliding.
Re: AE86 suspension Thu, 04 March 2004 22:13 Go to previous messageGo to next message
45aken wrote on Fri, 05 March 2004 08:01
Bollocks, they're completely different.
45aken
Re: AE86 suspension Fri, 05 March 2004 02:19 Go to previous messageGo to next message
its not the car being set up to slide, its to car being set up to handle smoothly(ie. stable etc) when being pushed to its limit. if you ever go in a drift car you'll notice that they do handle extremely well around a track and it the driver input that creates the slide. also you may notice that the suspension on drift car (parts etc) is very similar if not the same as track cars. sure the setup is a little different but there not as far apart as what you think.
Lachie
Re: AE86 suspension Fri, 05 March 2004 02:39 Go to previous messageGo to next message
I'm with norbie and Turbo RA28 - there completely different setups.
There are even companies in Japan that make parts especially for drift, and they are completely different to parts that you would use a a track car.
ed_ma61
Lost in the K hole
Re: AE86 suspension Fri, 05 March 2004 02:51 Go to previous messageGo to next message
you ever played Need for Speed?
If you have, youd notice that there is 2 entirely different setups for drift and circuit racing! yeash!
45aken
Re: AE86 suspension Fri, 05 March 2004 03:01 Go to previous messageGo to next message
explain to me how they are completly different and i will believe you. and im not talking about angles im talking about hardware. i know many ppl who race cars i even know the alfa club comp champion, and they can drift there cars like pro's. but if someone can actully proove how greatly they differ i might take it into consideration.
Re: AE86 suspension Fri, 05 March 2004 03:06 Go to previous messageGo to next message
Spring rates and sway bar stiffness? I'd say these differ greatly.
It really comes down to what you class as a good handling car also.
[Updated on: Fri, 05 March 2004 03:08]
45aken
Re: AE86 suspension Fri, 05 March 2004 03:09 Go to previous messageGo to next message
as i said either proove it or dont worry. can we please get back to the origional topic?
Re: AE86 suspension Fri, 05 March 2004 03:20 Go to previous messageGo to next message
To answer your question assuming you want a good handling and road holding car and not a drift machine :
This is what I believe to be a fairly good all round setup. But please note this is just my opinion and hold no qualifications to back it up.
Replace ALL bushes & balljoints
KYB shocks / koni if you can afford
25mm lowered front & rear
25mm RCA's
Adjustable front & rear swaybar
275lbs/in front springs
200lbs/in rear springs
Adjustable strut tops - dial in 1 - 1.5 neg camber.
Extras - adjustable panhard rod, traction brackets, strut bar.
[Updated on: Fri, 05 March 2004 03:21]
45aken
Re: AE86 suspension Fri, 05 March 2004 03:26 Go to previous messageGo to next message
thanks for the help. just a few more things.
i would like the car to be low,and i bought the car for the purpose of drifting. so i pretty much want a drift machine. sorry to confuse you
i was thinking:
springs 6kg front and 4kg rear (whats this in pounds? am open to suggestion about rates)
anti roll bars (whiteline front and rear)
front strut brace maybe rear aswell
roll center
shocks (suggestions?)
bushings (urathane)
Re: AE86 suspension Fri, 05 March 2004 03:35 Go to previous messageGo to next message
If you want it to be low .. shorter stroke struts would be a valuable investment.
GT4 items are quite a bit shorter and with those in place you will regain a lot of lost suspension travel from lowering it.
Get coilover hardware and while fitting that chop xx out of your strut housing.
Make sure whatever you lower it by you put the same amount back with roll centre adjusters if not you will have bump steer issues.
Traction brackets as I mentioned before will be even more necessary if you want a super low ride.
Those spring rates sound fine for a drift car, maybe a bit stiffer on the rear to promote oversteer.
Make sure the swaybars are adjustable so you can make the rear super stiff to again promote oversteer.
45aken
Re: AE86 suspension Fri, 05 March 2004 03:45 Go to previous messageGo to next message
thanks for your help man.
do the GT4 struts bolt in? what modifications are necessary and what do they go for 2nd hand?
do the roll center adj. RAISE the car? (thats what it says on the whiteline website)
maybe like 6kg and 5kg?
or 7 and 5 (i think 7 is getting a little stiff though, as you dont always drift on a track Smile )
45aken
Re: AE86 suspension Fri, 05 March 2004 03:46 Go to previous messageGo to next message
Re: AE86 suspension Fri, 05 March 2004 04:17 Go to previous messageGo to next message
Roll centre adjusters do NOT raise the car, the reset the roll centre geometry back to close to factory.
They sit between the steering knuckle and the shock, so they only alter the angle of the control arm and not height of the car.
GT4 inserts fit inside the AE86 strut housing fine, but as I mentioned the housing needs to be shortened as they are a much shorter stock.
With spring rates AE86 seem to respond well to a ratio of the rear being 2/3 the rate of the front. But as you want drift setup I'd guess this might not be the ideal ratio and you'd want to stiffen the rear more.
ae8620v
Re: AE86 suspension Mon, 08 March 2004 09:09 Go to previous message
you first need to work out what you want from the car,to start with i reccomend a good set of springs and adjustable shocks, to go with that check suspension bushes and replace if necessary, and depending on how low you go you may need an adjustable panhard rod. try this first then do other things as you need them. role centre adjusters, traction bars, strut tops etc.. Be prepared to spend money it adds up quick. And just for the record drift and track are different setups.
Previous Topic:Engineers needed? where are they ?
Next Topic:AE86 coil over question
Current Time: Wed Nov 18 14:50:58 UTC 2026
Total time taken to generate the page: 0.065629005432129 seconds
