Toymods » Tech & Conversions » 4A-GE Head gasket specs
takai
4A-GE Head gasket specs Tue, 02 March 2004 03:23 Go to next message
Does anyone know the head gasket specs for the smallport 4A-GE.
Im looking at increasing the compression on the engine, and either a smaller HG or shaving seems the easiest way. Thinner HG of course the easiest.
Anyone know the specs of the stock one.
ae86drift
sydney.au
Re: 4A-GE Head gasket specs Tue, 02 March 2004 05:40 Go to previous messageGo to next message
no idea on OEM
but the TRD ones come in 0.8 and 1.0
so stock would be larger than that i suppose
[Updated on: Tue, 02 March 2004 05:40]
takai
Re: 4A-GE Head gasket specs Tue, 02 March 2004 06:00 Go to previous messageGo to next message
What comp ratio would be produced by the 0.8mm gasket?
ed_ma61
Lost in the K hole
Re: 4A-GE Head gasket specs Tue, 02 March 2004 06:02 Go to previous messageGo to next message
bugger all more compression if you estimate a stock h/g thickness of 1 or 1.2mm
more importantly, have you thought about piston and deck heights, and the squish clearance a thin head gasket is going to give you?
[Updated on: Tue, 02 March 2004 06:03]
takai
Re: 4A-GE Head gasket specs Tue, 02 March 2004 06:10 Go to previous messageGo to next message
Yeah, have thought about it a bit. Kinda almost broke my brain.... but thats probably lack of sleep.
Found a HKS one which at .6mm claims 11.6 comp:
Quote:
HKS Head Gasket: Stopper Type. 0.6 mm. 82.5 mm bore. 11.6 compression ratio
But im not sure about what would happen to interference etc.
takai
Re: 4A-GE Head gasket specs Tue, 02 March 2004 06:18 Go to previous message
Im pretty sure that the CR is a misprint now, seems to not be corroborated by any of the HKS sites.
How else would i increase compression?
Previous Topic:Has anyone got a 1/2JZ MA61 with air con
Next Topic:SV21 auto to manual conversion.
Current Time: Fri Nov 20 22:31:19 UTC 2026
Total time taken to generate the page: 0.0055999755859375 seconds
