Toymods » Tech & Conversions » can 20 v throttles be bored out
CelicaRA45
nth ringwood, Victoria
can 20 v throttles be bored out Tue, 02 March 2004 07:32 Go to next message
just wonting to no if black top throttles can be bored out from 45 to 48mm thanks for any replys
ae86drift
sydney.au
Re: can 20 v throttles be bored out Tue, 02 March 2004 07:33 Go to previous messageGo to next message
as far as i know they are 48mm stock
ae101 is 45mm
ae111 is 48mm
although i may be wrong, this is what ive heard
CelicaRA45
Re: can 20 v throttles be bored out Tue, 02 March 2004 07:56 Go to previous messageGo to next message
silvers are 43mm at butterfly and blacktop are 45at butterfly
ae86drift
sydney.au
Re: can 20 v throttles be bored out Tue, 02 March 2004 09:16 Go to previous messageGo to next message
ah!
at butterfly
my bad Smile
Re: can 20 v throttles be bored out Tue, 02 March 2004 09:30 Go to previous messageGo to next message
Why do you think it can't be done Glenn?
Wouldn't it be a matter of boring it out, slight lengthening of the shaft slit and fitting a bigger butterfly?
IRA11Y
Club Member
Re: can 20 v throttles be bored out Tue, 02 March 2004 10:06 Go to previous messageGo to next message
you may damage some of the idle vacume ports... which will basically mean they will be unuseable in stock setup, you could fix it by reboring your own ports though if you are going to go that far in terms of modifying them... there are easier ways though.
Bill Sherwood
Brisbane / Gold Coast
Re: can 20 v throttles be bored out Tue, 02 March 2004 16:28 Go to previous messageGo to next message
CelicaRA45 wrote on Tue, 02 March 2004 18:32
Not really, the walls are pretty thin.
As mentioned above, the silvertop's are 43mm and the blacktop's are 45mm.
If you want bigger, try Toby Hunt at Meridian Motorsport in Melbourne, he can get them nearly any size made up to order.
._T_.
Re: can 20 v throttles be bored out Tue, 02 March 2004 22:00 Go to previous messageGo to next message
glen,
yes they can be overboored - you can take the silvers out to nearly 46, blacks i'm not sure but probably 48 is a limit (same as beams 3sge kit) main thing if finding a set!!
other thing is the cost - a mounting bracket has to be made to hold the t/b, then it has to be completly stripped then bored. new butterly & shaft has to be made. then reassemble.
bottom line here is it works out comparable to have throttle blocks made as bill suggested. - in most applications they are the better option.
generally the throttle blocks are about $180 ea + linkages
T
ae8620v
Re: can 20 v throttles be bored out Mon, 08 March 2004 09:23 Go to previous messageGo to next message
yeah they can be bored out, silver tops can be bored to 47mm and not sure of the black top i haven't needed to do it to mine yet. If you think you need bigger contact me and i should be able to make some up for you
CelicaRA45
Re: can 20 v throttles be bored out Wed, 10 March 2004 10:10 Go to previous message
well i got them back today 47.5mm like the TRD 1s still used the same shafts and had new butterflys made up 110 per throttle so not 2 bad
Previous Topic:Different Gearbox Ratio
Next Topic:Wolf3D ver 4 MAP for 7MGTE
Current Time: Wed Nov 18 18:52:59 UTC 2026
Total time taken to generate the page: 0.0047190189361572 seconds
