Toymods » Tech & Conversions » TVIS on Turbo conversion?
adamb131
TVIS on Turbo conversion? Tue, 02 March 2004 07:48 Go to next message
I'm gathering parts for a 4AGTE build.
I got a manifold but the TVIS and stuff is missing.
Question is... when I use this manifold in the build-up, can i bolt it straight up to a big-port head on my ZE without having the TVIS plate in there?
Fattony
Re: TVIS on Turbo conversion? Tue, 02 March 2004 08:48 Go to previous messageGo to next message
I have not got TVIS enabled on my car, but the plate is still there.
adamb131
Re: TVIS on Turbo conversion? Tue, 02 March 2004 09:00 Go to previous messageGo to next message
Oh well... looks like it'll go. Guess I'll find out when I get into it.
Have the butterflies been removed from your TVIS or is it just disconnected?
http://members.optusnet.com.au/acuvucep/images/4ag-inlet.jpg
10sec_rx7
Syndey
Re: TVIS on Turbo conversion? Tue, 02 March 2004 11:28 Go to previous messageGo to next message
just remove it,
that is what i did on the last 4age we turboed with tvis, the manafold will bolt straight on with shorter studs
Dale
feral4mr2
Bundaberg, Qld.
Re: TVIS on Turbo conversion? Tue, 02 March 2004 11:36 Go to previous messageGo to next message
Freak 10sec_rx7, you had no air gaps? when i did mine i could see no way the round inlet manifold ports/runners would seal against the head ports because of the way it dipped in at the top of each of the runner/ports on the linet manifold.
10sec_rx7
Syndey
Re: TVIS on Turbo conversion? Tue, 02 March 2004 11:40 Go to previous messageGo to next message
nope no problems at all, the tvis plate was exactly the same shape as the inlet manafold, this was a rwd motor so maybe the fwd are different,
feral4mr2
Bundaberg, Qld.
Re: TVIS on Turbo conversion? Tue, 02 March 2004 12:35 Go to previous messageGo to next message
Freak yes one side of the t-vis plate is exactly the same, but what about the inlet manifold side? the 8 round runners/ports. i held both sides of the t-vis plates gaskets together, didnt look right to me.
anyways, i just used the t-vis plate, but guttered the butterlfies and center rod then sealed the 2 holes up.
adamb131
Re: TVIS on Turbo conversion? Tue, 02 March 2004 12:38 Go to previous messageGo to next message
i aint got no tvis plate so i'm gonna go without it... we'll see.
notice no throttle body and I havent sourced one yet any options or just go the toyota one.
10sec_rx7
Syndey
Re: TVIS on Turbo conversion? Tue, 02 March 2004 22:15 Go to previous message
we had no problems doing it, as the studs are long and go through the tvis plate and into the manafold there should be no problems on even the FWD motors
As for the throttle body, SSS automotive should have a heap of them as we got a bare manafold off them the other week,
Previous Topic:Fuel Station DAMPER ?? !!
Next Topic:Aircon = RPM fluctuation
Current Time: Fri Nov 20 16:11:49 UTC 2026
Total time taken to generate the page: 0.0056378841400146 seconds
