Toymods » Tech & Conversions » Fuel Filter 4AGE in AE82
HighRolla
icon5.gif  Fuel Filter 4AGE in AE82 Tue, 02 March 2004 09:22 Go to next message
I have a new fuel filter for my AE82 twinky. Had a look at the old one today (mounted in engine bay near passenger guard/mould for strut tower). The inlet (bottom) has what looks to be a really #...ed locking nut (almost rounded) unless there is some special monged looking tool for it. Anybody that's done this before have you just used about a 12mm open ender to undo the bottom? If that's screwed then I guess I'll have to trace the fuel line and get it off a wreck (does anyone know if it goes much past the firewall from the fuel filter).
Sorry this is such a stupidly simple one for you guys/girls, not very interesting Embarassed Rolling Eyes
Hoping someone who has done this can help...thanks
[Updated on: Tue, 02 March 2004 10:37]
HighRolla
Re: Fuel Filter 4AGE in AE82 Tue, 02 March 2004 10:48 Go to previous messageGo to next message
somebody with a ge should know right? Maybe I should just leave it alone and not change it? its been in there 3 years and heavens knows how many years before i got the car
tooch
Bulleen, Melbourne
Re: Fuel Filter 4AGE in AE82 Tue, 02 March 2004 11:05 Go to previous messageGo to next message
Mate it's a prick of a job, that same nut was totally stuffed in my car too! I got really pissed off at it and got a mechanic to do it, all he did was use a pair of vice grips! should have tried that myself. Takes a bit of mucking around to get them in there properly, but it should work for you
HighRolla
Re: Fuel Filter 4AGE in AE82 Tue, 02 March 2004 12:18 Go to previous messageGo to next message
Tooch...thanks for that Smile. Did the mechanic just do up the rounded nut with the new filter using the vice grips again (i.e. not replacing the nut or line etc)? Thanks for sharing, glad I asked!
toyoda
Re: Fuel Filter 4AGE in AE82 Wed, 03 March 2004 01:03 Go to previous messageGo to next message
Big problem is that the pipe has a flared end and when the nut is tightened too much it flares the end of the nut.
This then makes the end of the nut too big to unscrew from the filter.
recommend:
1/. Use a Pipe spanner ( it has 6 flats - well 4 and 2 halves) and webbing across the top to stop the spanner opening up.
2/. Try not to overtighten ( can be difficult to seal however).
A lot of the Dealers actually cut off the end and have a new end formed on the pipe and use a new nut.
Toyoda
tooch
Bulleen, Melbourne
Re: Fuel Filter 4AGE in AE82 Wed, 03 March 2004 07:02 Go to previous messageGo to next message
Umm yeah he just tightened the old one back up again, if you could be stuffed you could cut the old one off and chuck a new one back on and flare the end Smile
HighRolla
Re: Fuel Filter 4AGE in AE82 Wed, 03 March 2004 09:06 Go to previous messageGo to next message
Thanks for that tooch and toyoda Very Happy . Here are some pics of mine..showing the line that looks monged (do you think somebody has tried to grip the pipe or overtightened putting a twist in pipe or does everyones look like this?).
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/fuel%20filter%202.JPG
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/fuel%20filter.JPG
How much of a job do you think it would be to cut off the end and put new one on? Flaring end etc? Thanks
toyoda
Re: Fuel Filter 4AGE in AE82 Fri, 05 March 2004 05:35 Go to previous messageGo to next message
He He - If that was a chicken, that amount of wrung neck would kill it.
Definately replace the pipe or cut off the damaged end, even if you have to extend it.
That amount of distortion can only slow down the fuel flow and could eventually fail.
Good luck
Toyoda
HighRolla
Re: Fuel Filter 4AGE in AE82 Fri, 05 March 2004 10:05 Go to previous messageGo to next message
Laughing Laughing Laughing love the chicken analogy. I might try Enzed and see what they have in the way of fittings that might do the trick.
Thanks..bloody mongrel that worked on it before!
MR PLOW
neverland
Re: Fuel Filter 4AGE in AE82 Sat, 06 March 2004 04:23 Go to previous messageGo to next message
ok mate the best advice i can give you coming from a mechanic to save you a bit of money is to..
1. take the old filter ask for Z-200 fuel filter.
2. ask for about 150mm of fuel injection hose 4 hose clamps in case you wreck one.
3. cut the banjo fitting off(where the bolt goes through) and cut off the pipe before the twisted bit of pipe.
4. join it all up. so then next time you go all DIY you can think im saving myself a big headace with the new filter set up and a few dollars as well.
5. away you go
brad
HighRolla
Re: Fuel Filter 4AGE in AE82 Sat, 06 March 2004 12:36 Go to previous messageGo to next message
Brad (Mr Plow) I owe you one Shocked Surprised Very Happy !
That's a great idea. If I chop the top bango fitting, will that thickness of fuel injection hole fit on the outlet of the z200 filter.. I guess it would if you're telling me to do it. The fuel injection hose has a standard inner diameter does it?, or maybe get the filter and check..but I've got to match the hose to the cutoff pipe diameter. I'll manage I think. Thanks Brad..that will save a lot of HASSLE
HighRolla
Re: Fuel Filter 4AGE in AE82 Mon, 08 March 2004 22:43 Go to previous message
Brad,
I swapped the z361 for a z200like you said..it looks the money. I found some fuel line at home (leftovers from what I bought for another car), just need some hose clamps and I'll be in business.
Thanks again Very Happy
Previous Topic:RA28 Project - help a newb :)
Next Topic:what size speakers in front of corolla csi 1992
Current Time: Wed Nov 18 18:53:16 UTC 2026
Total time taken to generate the page: 0.0056209564208984 seconds
