Toymods » Tech & Conversions » Brake Boosters
vin91
Darwin
Brake Boosters Wed, 03 March 2004 02:35 Go to next message
Anyone Know where to connect your Brake Booster Vacuum Hose on a Turbo Car as I Don't think you can connect to the Intake manifold because you would be running Positive pressure.
Re: Brake Boosters Wed, 03 March 2004 02:43 Go to previous messageGo to next message
Thats what the 1-way valve is for.
Southo
Re: Brake Boosters Wed, 03 March 2004 08:29 Go to previous messageGo to next message
yep,
depending on the booster and the car it was from, it may have a valve built in, otherwise you need one of these......
http://www.pbase.com/image/24037194/medium.jpg
[Updated on: Wed, 03 March 2004 08:29]
Skip
Re: Brake Boosters Wed, 03 March 2004 12:13 Go to previous messageGo to next message
Just a quick question on this issue.
What implications does positive pressure have on your booster? Cause theoretically you only use your brake when your foot is off the accelerator meaning it will always be vacuum, and therefore your brakes should work fine.
Re: Brake Boosters Wed, 03 March 2004 12:23 Go to previous messageGo to next message
Positive pressure will just blow a hole in the diaphragm.
vin91
Darwin
Re: Brake Boosters Wed, 03 March 2004 22:54 Go to previous messageGo to next message
Was just worried thought that it might cause a bit of trouble so i gotta get a valve huh Well thanks for the help and we will see how I go.
Re: Brake Boosters Thu, 04 March 2004 04:00 Go to previous message
Your brake booster almost certainly has a one-way valve in it already. Ever noticed how your brakes are still good for one or two pumps after you shut off the engine before they go rock-hard? That's the valve at work. Adding positive manifold pressure to the equation won't change anything.
Previous Topic:An actual technical discussion!
Next Topic:not toyota, but will ask anyway
Current Time: Fri Nov 20 09:23:22 UTC 2026
Total time taken to generate the page: 0.0059680938720703 seconds
