Toymods » Tech & Conversions » almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs)
almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 02:50 Go to next message
http://www.megasquirt2.com/PWC/
the schematics are preliminary, they completed diagrams, and group buys for the boards will be mid to late this year.
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 03:48 Go to previous messageGo to next message
On this topic.. Has anyone had any experience with Techedge's units? Seem well priced, either DIY or prebuilt. Can interface to PDA's/laptops which I think is a great feature and has logging abilities.
http://wbo2.com/
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 04:02 Go to previous messageGo to next message
they look quite good, as does a prebuilt on in the US for about $300 (can't remember where atm Sad ). i have heard mixed feedback about the accuracy, but i thik any accuracy is better than a narrow band Wink
maybe Peter G would like to comment on the drive circuit and how good it is?
i have faith in Bowling and Grippo tho Wink and it's open source, so you will be able to make your own board and program your own processors if you so wish.
[edit] i am in no way trying to take away from the good work by Peter, just spreading some info about how the sensors and drive circuits work. there are no PCB's or software available for Bruces stuff, and will not be for maybe 6 months.
[Updated on: Wed, 03 March 2004 04:04]
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 04:39 Go to previous messageGo to next message
oldcorollas wrote on Wed, 03 March 2004 14:02
<snip>
<snip rest>
and i can vouch for their ease-of-building - my two units both worked first time when plugged into the simulator (recreates outputs from TPS, CLT, IAT, O2 & RPM) and my PC.
if you do go this way, the GB are much cheaper than trying to import everything yourself.
if there's someone in BNE that wants to loan one to try on their Toy, PM me off-list.
ae86drift
sydney.au
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 08:50 Go to previous messageGo to next message
doesnt the motec m880 have this stock?
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 11:43 Go to previous messageGo to next message
motec M880? LOL Laughing
yes, there is an option that yuu can add on from the M4 up to control either the NTK L1H1 and Bosch LSU4 sensors. IF you are already paying the 2.5-3K entry fee Wink
if you have a MoTec, you would not be considering this anywaY Razz
what you seem to fail to recognise is that the L1H1 sensors are around US$300+.
you can get LSU4's from a particular source for US$30.
have a look at the prices on www.CAPA.com.au
the controlling board for this will be under $100 US, rumours of half that (solder yourself of course)
the UMS it will be connected to when it is released will cost between 100-150 US and will have features that currently you can only dream of Wink (how many MoTecs can you cascade together with CANbus?? hmmmm how would you like 48 completely programmable outputs, fuel, ignition, pwm, stepper, slow load etc etc, auto box shifter control, boost control...)
for the unitiated, the info first posted is the tip of the iceberg, which, if they are on the ball, would lead them to more interesting projects Wink
but this was only intended to give some background info on wideband sensors....since many people don't understand how they work or why they need driver hardware.... and it is generally a pretty secretive affair (or how else would BLIT$ charge you a grand or two for a lamda meter?)
[Updated on: Wed, 03 March 2004 12:07]
ae86drift
sydney.au
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 11:50 Go to previous messageGo to next message
it was simply a question, which was answered.
thanks Smile
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 12:13 Go to previous messageGo to next message
no wuckers..
keep in mind that the Bosch LSM-11 that MoTec (and others) call a "wide band" is not actually a wide band.. it's a heated narrow band that is manufactured to higher tolerances, and is factory tested to comply to toleranced response curve. it's better than a normal narrow band, but is not wide band.. more like "wide range" sensor.. it's used for the Silicon Chip O2 meter, and some analytical devices.
the NTK L1H1 and the Boch LSU4 are TRUE "widebands" and can give true lambda output, with the correct nernst cell driver circuitry
anyhoo, have a good long read of Bruces work.... it's abotu time things like this became open source and stuck it to the manufacturers Twisted Evil
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Wed, 03 March 2004 22:56 Go to previous messageGo to next message
I like it... I've been trying to find stuff on wide band sensors for a while now, always been a *little* upset at the idea of paying QUITE so much for what isn't really an overly complex circuit... Evil or Very Mad
Esteban
Brisbane - Chapel Hill
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Thu, 11 March 2004 01:07 Go to previous messageGo to next message
No, its not that complex a circuit, but to test without some not so common tools, is a bit of a bother.
I just ordered the Tech Edge WB02 Kit. I'll report back just how good it is in a few weeks I suppose Smile It uses the Bosch LSU4 True Wide Band Sensor, and im encouraged to see they arent as dear as the NTK sensor. When I originally looked into a WB kit, this was my primary concern, and the fact that a few years ago, it seemed you could only get them from America / Europe.
Esteban
TE72_Turbo
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Sun, 12 September 2004 12:21 Go to previous messageGo to next message
Sorry to drag this up so long after it went quiet, but Esteban: how did you go with the Tech Edge kit? I've been considering purchasing one of these for the last year, but havn't heard any first hand info on them.
Cheers Very Happy
Phil
Esteban
Re: almost evrything you would want to know about how Wideband oxygen sensors work (UEGOs) Sun, 12 September 2004 13:12 Go to previous message
I havent actually finished making proper leads for the power and auxiliary inputs, so the whole unit isnt complete yet, however, it has been used to tune a 12A, an EJ22T, and two SR20Ts by my friends with no hiccups at all.
I can only recommend you get yourself one! Smile
Previous Topic:4age smallport, ISC controller, where is it?
Next Topic:78 corona and rims
Current Time: Fri Nov 20 13:34:29 UTC 2026
Total time taken to generate the page: 0.0069339275360107 seconds
