Toymods » Tech & Conversions » Electronic Speedo and other questions!
Helmann
Ipswich
Electronic Speedo and other questions! Mon, 12 August 2002 11:22 Go to next message
Does anyone know how i can get my speedo to work if the old one was cable driven and the new engine/gearbox is electronic without a speedo cable???
Can it be adusted to work???
Also what is the fuel cut set at for a 1g-gte.
What size injectors do they have stock?
Will a standard type bov work considering that it is twin turbo?
Helmann
Ipswich
Re: Electronic Speedo and other questions! Mon, 12 August 2002 22:09 Go to previous messageGo to next message
bump
HedgehogSandwich
UK
Re: Electronic Speedo and other questions! Mon, 12 August 2002 22:16 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 12 August 2002 22:17]
Seadog
Re: Electronic Speedo and other questions! Wed, 14 August 2002 06:41 Go to previous messageGo to next message
You can buy aftermarket electronic speedos from Autometer, VDO, Smiths(or maybe it was Pricol). Anyway there are a few out there.
KDog
Re: Electronic Speedo and other questions! Wed, 14 August 2002 07:24 Go to previous message
You could pull apart your speedo and find the part of the circuit where it converts the mechanical signal to an electric signal and wire your speedo wires in their. Usually mechanical speedos use a phototransistor and a chopping wheel to convert it to an electronic signal. It would take a bit of mucking around but I reckon it could be done. Of course your new speedo may put out a different number of pulses than what the old one did so it may not be claibrated very well.
The other option is to pull apart the speedo sensor in the new gearbox and see if you can make the old mechanical one fit instead.
Previous Topic:Crostek ====>
Next Topic:Help with 20V AE86
Current Time: Tue Oct 27 11:33:42 UTC 2026
Total time taken to generate the page: 0.016754865646362 seconds
