Toymods » Tech & Conversions » Ra celica struts into ke20?
rotorace
Ra celica struts into ke20? Wed, 03 March 2004 11:29 Go to next message
Hi all, just wondering if you can fit RA celica struts into a ke20? if so how did you go about it?
I would like to hear from people who have done it or seen it done.
I think it goes along the lines of ra40 or 60 struts and steering knuckles and ke20 spring seat and top hat must be used? can anyone confirm this?
any help appreciated, cheers
chris philpott
hobart
Re: Ra celica struts into ke20? Wed, 03 March 2004 12:23 Go to previous messageGo to next message
Hi! Rotorace I got your pm, Yes you can use the ke spring seat and have to use the top hat. You will have to shorten the strut length. I'm not using the org. seat but am using coil-overs for height adjustment. Am still exploring the l/c arm and knuckle set up.i think I'm on the right track but someone might be able to enlighten us both.
Good Luck Confused
Cheers Chris
rotorace
Re: Ra celica struts into ke20? Thu, 04 March 2004 06:22 Go to previous messageGo to next message
hey chris, the struts im looking at have been shortened already, but the only thing i need to figure out his how to fit them to my car, eg. l/c arm and knuckle. havent you had any luck using the celica knuckle and ke20 l/c arm?
chris philpott
hobart
Re: Ra celica struts into ke20? Thu, 04 March 2004 09:01 Go to previous message
The KE l/c arm will not take the RA ball joint as it is larger, so you have to use RA l/c arm and lengthen it. I have heard that there are two different length Confused steering knuckles avil. in the RA. The common one appprently is to long and throughs out the steering Confused but haven't investigated any further,shit are you confused because I am.
Again good luck
Cheers Chris
Previous Topic:Ke20 engine help!
Next Topic:crank over 7MGE
Current Time: Fri Nov 20 06:43:59 UTC 2026
Total time taken to generate the page: 0.0045120716094971 seconds
