Toymods » Tech & Conversions » Corona backfiring through exhaust!
Byatch
Corona backfiring through exhaust! Thu, 04 March 2004 00:52 Go to next message
hey all
last night i was up to some hooliganism on a quiet back road at about 1am. anyway, i was holding gears and letting the engine in my rt104 corona rev a bit, nothing extreme, just letting it live a little in 1st and 2nd.
I stopped my car at a car park, and turned it off (i drove normally for about 2 min before turning it off). when i came back out to hop in the car, it had been sitting for a couple of hours, and i then proceded to drive off. when i let the clutch out, it made the weirdest niose i have ever heard. it was clearly an air noise, but i didn't know where from.
I pulled over onto the side of the road, popped the bonnet and listened for any unusual noise from under the bonnet, but it sounded faint. i then went around the back and the sound level grew, it sounded like something was loose in the exhaust system.
My frinds and i piled back into the car and i slowly drove it the 800m to my g/f place, where i got the keys for her car and took my mates home. when i got back (about 2am) i grabbed a torch and had a look under the back of the car. i couldn't hear anything... so i gave it a little rev... nothing in the way of unusual noises... a bigger rev.... nothing!
WTF is going on? any ideas as to what happened and why would be greatly appreciaed
btw, the car runs genie 4-2-1 headers, 2 1/4in exhaust sustem, a sports muffler and a 15in resonator, if that is any help
[Updated on: Fri, 05 March 2004 08:06]
Byatch
Re: Corona exhaust making strange noise Fri, 05 March 2004 00:54 Go to previous messageGo to next message
c'mon, surely it has happened to someone.....
i'm dying over here
boris
On probation
Brisbane, Queensland
Re: Corona exhaust making strange noise Fri, 05 March 2004 01:03 Go to previous messageGo to next message
so the noise only happened once? i wouldn't worry about it than!
Byatch
Re: Corona exhaust making strange noise Fri, 05 March 2004 03:10 Go to previous messageGo to next message
yeah, it only happened once, but i am still worried about it.... don't want it to happen again, and i'd rather know wtf it was
Byatch
Re: Corona exhaust making strange noise Fri, 05 March 2004 08:05 Go to previous messageGo to next message
Update: it has happened again!!
but, this time i have a better idea about wtf is going on!
at idol: no problem
at part throttle: popping sound through exhaust
at moderate throttle: backfire through exhaust
my thoughts: something is up preventing dettonation of the fuel, BUT the timing was set about 1 month ago, the plugs were changed then too. so, any thoughts??
crazedrt104
Darwin
Re: Corona backfiring through exhaust! Fri, 05 March 2004 10:39 Go to previous messageGo to next message
sounds like the timing is out...u mentioned the timing was adjusted a month ago...id be checking to make sure the dizzy is tight...my 2c worth
Byatch
Re: Corona backfiring through exhaust! Sat, 06 March 2004 01:01 Go to previous messageGo to next message
update:
i cracked the mulitmeter out and checked my leads, they all have the same reading of 3500 ohms.
checked fuel filter-no probs.
will be checking timing and plugs later this arvo.
Mr DOHC
Re: Corona backfiring through exhaust! Sat, 06 March 2004 04:09 Go to previous messageGo to next message
check your points too, is it a pop or bang or a deep boom
hemi twofifteen turbo
Re: Corona backfiring through exhaust! Sun, 07 March 2004 01:01 Go to previous messageGo to next message
Does the car miss, as in, is there a sudden drop in power and jolt through the driveline? Or is it a noise that seems to have no ill effect on the engine?
Is this is neutral or in gear (under load)
If there is no ill effect from the noiuse could it be possible you ripped a small hole in the muffler, or rattled the xtractors slightly loose, this will let o^2 into the exhaust and let excess fuel pop and burn..
If you did change the points also a month ago, points need to be adjustst about a week after installing because the fresh rubbing block contact area has to wear in, which it probably has, causeinbg the dwell angle/timing to change. This would also explain a loss in power/missfire.
Does it happen all the time now? When cold? When warm? etc..
Try those out, but otherwise give us some more info!!
Byatch
Re: Corona backfiring through exhaust! Mon, 08 March 2004 00:18 Go to previous message
you know how, sometimes stuff goes wrong, and you are so worried that it is the end of the engine/car/world that you don't even check the simple things....
Embarassed
the spark plug lead to no1 cylinder was broken (where it grips the top of the plug). didn't even think to check that.
Embarassed
ah well, thanks for all your help guys. turns out it wasn't the end of the world anyway.
Previous Topic:ke70 4stud to 5stud how?
Next Topic:Bent front end, how to open the bonnet?
Current Time: Thu Nov 19 00:24:07 UTC 2026
Total time taken to generate the page: 0.0055990219116211 seconds
