Toymods » Tech & Conversions » hilux and Hiace axles
QIK 3SGTE
hilux and Hiace axles Thu, 04 March 2004 05:21 Go to next message
are these axles the same?? do they use the same diffs? i need to know if a 1972 hiace has the same diff/axles as a hilux of the same era rn1X or rn2X cos I need the short hilux ones but have had no luck. however have found hiace ones.
Re: hilux and Hiace axles Thu, 04 March 2004 05:32 Go to previous messageGo to next message
I thought a Hiace had an F-series diff Confused
ra23celica
Re: hilux and Hiace axles Thu, 04 March 2004 05:38 Go to previous messageGo to next message
Jack,
Every early Hiace I found in WA ran an F series axle, so while you could use it for the width, its the availability of good ratio LSD's that steered me away from these and onto RN10/13/20/27 Hilux G series units.
Full marks to JCMF as well !
Mitch.
Re: hilux and Hiace axles Thu, 04 March 2004 05:47 Go to previous messageGo to next message
I'm hoping that some Hiaces have G series centers cause I have a center here from one and it fits my hilux diff fine Confused
ra23celica
Re: hilux and Hiace axles Thu, 04 March 2004 05:52 Go to previous messageGo to next message
I don't doubt that some G's found there way onto Hiace's but I have only (personally) seen F's on them. Maybe the LWD diesel Hiace van ran a G series.....I don't know enough about them to say which year/model/series etc.
Like with all old parts, best to eyeball it and satisfy yourself.
You don't find much of a build plate in 1970-74 Toyota commercials....
Mitch.
Re: hilux and Hiace axles Thu, 04 March 2004 06:11 Go to previous messageGo to next message
Late 70's (78-79) onwards Hiaces definitely have G series diffs. The build plate is found below the passenger seat. Peel off the vinyl and there it is.
That said, I can't comment specifically on earlier Hiaces.
ra23celica
Re: hilux and Hiace axles Thu, 04 March 2004 06:18 Go to previous messageGo to next message
I found the late 70's Hiace axles to be too wide to use under the rear of my RA23, so I hunted down a pair of RN25/27 axles.
I looked at 3 early 70's Hiaces and while one (the earliest) had no build plate, the details on the other two showed they were F series. I found that RN10/12 Hilux's don't have much of a build plate at all.
Re: hilux and Hiace axles Thu, 04 March 2004 06:23 Go to previous messageGo to next message
Quite right. The later Hiace diffs (78-79 onwards) are very wide, from memory something like 1570mm hubface to hubface.
Steve_Reynolds
Gold Coast
Re: hilux and Hiace axles Thu, 04 March 2004 23:21 Go to previous messageGo to next message
GT is correct, late 70's onwards have G series in Hiace's, diffs are same as hilux. You may be thinking of LiteAce vans, they have F series and not as wide, great for your application shane.
Steve
Re: hilux and Hiace axles Fri, 05 March 2004 00:38 Go to previous messageGo to next message
My bad, Liteace is what I was thinking about...Confused
Re: hilux and Hiace axles Fri, 05 March 2004 01:18 Go to previous messageGo to next message
I'm almost certain the Liteace has an E series diff, apart from the Liteace 4WD, which I'm led to believe is another source for F series LSDs.
gold28
Madrid - Spain
Re: hilux and Hiace axles Fri, 05 March 2004 02:05 Go to previous messageGo to next message
Hey some of these HiAce diffs have fully floating hubs...Hmmmmmm anyideas if you could get the stud pattern down to a celica size??
Anyone know if the F series HiAce diffs came with a factory LSD???
ra23celica
Re: hilux and Hiace axles Fri, 05 March 2004 03:15 Go to previous messageGo to next message
GT covered it, yes, E series diff's in Liteace's, an F series LSD in the 4WD second hand import Liteace, with a 4.3 ratio BTW, on the one I eyeballed in Perth 18 months ago.
Unless the Hiace was a 4WD or limited edition or diesel turbo or some other oddball combination, you won't find it with an LSD.
All said and done, its easier to hunt down/wait for and buy an RN10/13/25/27 Hilux and use that G series axle, and swap in a later model LSD.
Been there, done that, taken me 3 years and $500 all up, but worth it.
Mitch.
gold28
Madrid - Spain
Re: hilux and Hiace axles Fri, 05 March 2004 03:23 Go to previous messageGo to next message
Just interested in the floating hub idea, LSD's are available so that was just a question.
Floating hubs can be engineered to accept wider wheels than the standard variety. They are also a lot more robust. I am putting in a F series axle in my 28 mainly because I don't want too much extra unsprung weight. Only problem is that the axles aren't all that big in em. Floating hubs also restrain the wheel if you brake an axle.
Re: hilux and Hiace axles Fri, 05 March 2004 05:53 Go to previous messageGo to next message
gold28 wrote on Fri, 05 March 2004 12:05
I've never seen a Hiace with factory LSD apart from late-model stuff which is G-series. I've seen a few 4WD Liteace's with F series LSD's though.
If you want an F series rear end, don't worry about whether or not it comes with an LSD centre, just get one that fits relatively easily; you can always swap in an LSD centre later, which is an easy process with these diffs. Same goes for the G series.
QIK 3SGTE
Re: hilux and Hiace axles (revised) Fri, 05 March 2004 06:16 Go to previous messageGo to next message
just getting back to what I was asking before,
my dilemma is that I cant find any short hilux axles; ie rn1X or rn2X model hilux. I need these axles because I have the 1410mm hilux diff in mycar which is a tad too wide, going to shorten it with the shorter model axles, cos too expensive to use the ones I already have. I have hunted around Sydney and posted on the wanted section and asked friends etc.. so what I needed to know was what my options are.
Are there any other axles I can use that will be the same length as the 1370 mm hilux axles and that will fit into my current diff. It doesnt matter if the axles are even a bit horter that the ones found in a 1370mm diff.
Also can anyone tell me what length axles are out of the 1370mm diff?
Jayem
Finland
Re: hilux and Hiace axles (revised) Fri, 05 March 2004 13:27 Go to previous messageGo to next message
690mm(+/-1mm). From hub face to axle end.
Celica_John
Re: hilux and Hiace axles (revised) Tue, 28 September 2004 08:07 Go to previous messageGo to next message
No Message Body
[Updated on: Tue, 28 September 2004 08:07]
SRacin
Christchurch, New Zealand
Re: hilux and Hiace axles Tue, 28 September 2004 08:32 Go to previous messageGo to next message
trademe NZ, 10bucks. Dont know if they will ship to oz but...
www.trademe.co.nz
serach hilux + axles (axels/?)
1g-gte-ra28
Re: hilux and Hiace axles Tue, 28 September 2004 10:30 Go to previous message
I am in the middle of doing my hilux diff conversion in my RA28 I did alot of searching and found that the diff out of those 4wd hilux surfs (cant remember what exact model some late 80's early 90's 4wd shitheap with no rear doors) is the same width as the standard RA28 diff dont have exact measurements on me but is pretty narrow. The only downside is that they are 6 stud instead of 5 which would have been more preferable to me. Hope this is of some help. Smile
Previous Topic:Power Steering Conversion
Next Topic:Dacken/Exedy clutch
Current Time: Tue Oct 27 11:40:18 UTC 2026
Total time taken to generate the page: 0.0061430931091309 seconds
