Toymods » Tech & Conversions » That stuff you spray in your injector/spark holes to clean your pistons
RobST162
That stuff you spray in your injector/spark holes to clean your pistons Thu, 04 March 2004 08:49 Go to next message
I had a friend who works at a Subaru performance place in Sydney get me some of this from his work.
The idea is (for those of you who don't know) that you spray it down into your spark plug holes and let it sit for a while and then fire the old girl up and it basically loosens carbon buildup which then gets ejected as dark smoke Smile
What do you guys reckon about this stuff? Do you think it might hurt the exhaust valves?
My car has been pinging slightly even though I use optimax and dead standard timing (might be my cams..)
But I thought well, carbon on the piston heads can cause detonation so maybe it is a good option
what are your thoughts? Smile
lurve - Rob
[Updated on: Fri, 05 March 2004 00:26]
Re: That stuff you spray in your injector holes to clean your pistons Thu, 04 March 2004 09:31 Go to previous messageGo to next message
well, when cleaning carbon out of the car, i just spray on RP-7, and next day the carbon can easily be wiped off.
if it comes loose in the combustion chamber it will prolly be lown out, BUT, it may get stuck in the spark plugs, may get stuck on the valve seats....
if it doesn't work, pull the head, if you don;t do it, pull the head Wink. if it does work your laughing Smile
i reckon give it a go... it probably won;'t be as bad as the pinging you have now... what cams? why are they causing pinging?
(longer duration generally lowers dynamic CR?)
EVOSTi
cambo
      no
Re: That stuff you spray in your injector holes to clean your pistons Thu, 04 March 2004 10:00 Go to previous messageGo to next message
i wouldnt think carbon build up in your combustion chamber would cause pinging, i would be looking for other causes.
Siktoy ra23
Plumpton/sydney
Re: That stuff you spray in your injector holes to clean your pistons Thu, 04 March 2004 10:09 Go to previous messageGo to next message
What will you do when your cat converter gets blocked up with all the shit out of your engine.
If your car is pinging then it will be burning the carbon of the top of your pistons anyway Laughing
BEN
ChuckLandwehr
Re: That stuff you spray in your injector holes to clean your pistons Thu, 04 March 2004 11:59 Go to previous messageGo to next message
2 thing here guys,
No 1: Carbon build up can cause Pre-Ignition, sounds like pinging, sounds just like detonation., but it is the air fuel mix being ignited by a hot spot within the combustion chamber, prior to the plug firing.
No 2: Throttle body and carby cleaner,(Suby stuff is really good) is an effective maintenance tool. Cleans up idle control valves, pistons and valves, removes the gunk that PCV valves put into the intake system.
Thirty years ago: rev engine to 3,000rpm, and squirt a decent volume of water from the garden hose down the carby. Literallty steam cleans the carbon fron valves and pistons. Get it wrong! too much water, and you end up hydraulic locking the engine, results in bent rods and cost a shit load to fix!
regards Chuck.
Re: That stuff you spray in your injector holes to clean your pistons Thu, 04 March 2004 12:03 Go to previous messageGo to next message
You'd need a pretty fricking huge volume of water to hydraulic lock an engine at 3000rpm!
M.W.P.
Rocky Mountains, Canada
Re: That stuff you spray in your injector holes to clean your pistons Thu, 04 March 2004 14:48 Go to previous messageGo to next message
Try ATF.
Pull the ignition, pour some in the inj/spark-plug holes, turn over for 10sec (not run, since no ign).
After 24hrs, start it up like normal... itll produce a HUGE amount of smoke, so best to do it at night Wink
Ive heard its an old rotary trick...
RobST162
Re: That stuff you spray in your injector holes to clean your pistons Thu, 04 March 2004 22:22 Go to previous messageGo to next message
ok thanks fells this is awesome
well cabon build up DOES cause pre ignition. And I am sure I have lots of carbon in th
My timing is standard, my dizzy straight, I run optimax. My car should not be pinging. 'Cept I know I have a carbon buildup. And I suspect I have non-standard cams, but like you said, generally the don't cause a problem like this.
SO - I was given this stuff, maybe RP-7 not sure. Told to take out my sparkies, drop it in, leave for 15, turn the car on! (is this the procudure?)
I feel like I wanna do a better job than just a spray down the throttle body while running.
But do I stand to wreck anything (other than my cat?)
Grega
melbourne.victoria.austra...
Re: That stuff you spray in your injector holes to clean your pistons Fri, 05 March 2004 00:25 Go to previous messageGo to next message
i'm told diesel will also help clean your engine BUT remember it will also dilute/remove the oil from your bores, so, on starting/rotation you will do damage.
what about a fuel additive to burn the stuff out as you drive NOT something as dramatic as diesel, water, RP7 ect...?
RobST162
Re: That stuff you spray in your injector holes to clean your pistons Fri, 05 March 2004 00:27 Go to previous messageGo to next message
yeah don't wanna use diesel
but dont' know if just "as you drive" stuff would work as good as actually allowing something to "clean" the pistons for a few minutes
RWDboy
Re: That stuff you spray in your injector holes to clean your pistons Fri, 05 March 2004 01:00 Go to previous messageGo to next message
You know rob, in japan the Celica GT (ST162) ran 10.0:1 compression as opposed to aussie spec 9.0:1. Alot of people are under the impression that your engine is not entirely aus-spec (and for dyno suggestive reasons) I may be a bit of a nay-sayer, but it is possible that carbon build up and the higher compression (if you do have the jap spec engine) will cause pre-det. Remember that 100 octane fuel is readily available in japan, and optimax is only 98.
Try bp ultimate 98 as well - I know that they are technically the same RON, but ultimate 98 is a pretty good fuel and very reliable.
If you want to do a better job than spraying something down there (either water or rp7) then you would have to take the head off (like I did) and get it fully cleaned up. You can also get throttle body cleaner which you may use (anyone know any reasons not to?)
If you do spray de-coking atuff down there, try to run your engine without any spark for a bit, it'll just get the oil up and around the place before you start it up and it might help reduce any potential wear issues.
RobST162
Re: That stuff you spray in your injector holes to clean your pistons Fri, 05 March 2004 01:05 Go to previous messageGo to next message
thanks heaps dude
yeah ok well it pre-dets just at lowish revvs under a little bit of load. I want to find the real cause of the issue, because if it is doing it with optimax it will probably do it sooner or later with something else... Sad
So apprecaite your post.
Ok so procedure is:
Sparkies Out
RP-7 in (funnel or something with the awkwardly sloped 3sge)
Wait a few minutes
Sparkies back in (but unplugged from ignitor so no spark)
Few rounds with the starter to get some oil around the pistons
Ignitor Connected
Black smoke out zorsty
Hopefully less/no detonation
Smile sound alright? I may get my cat angry, but I want a high-flow anyway, and I MUST stop this pre-det
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 01:19 Go to previous messageGo to next message
Sounds about right - just be careful with the second step, pouring fluids into an engine can cause 'funky' stuff to happen if too much goes in...the only rp-7 I've played around with has been a spray-can type thingo.
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 01:26 Go to previous messageGo to next message
yeha I will be using a spray can and spraying some straight in..
not exactly sure how much I will need though Neutral
I will see what the can says
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 01:45 Go to previous messageGo to next message
More than likely it will say 'liberally' Smile
Another thing - have you changed your spark plugs at all lately? Because the wrong 'temperature' spark plugs can cause detonation issues - have an acquaintance who had that issue with his 5S-FE. The only other thing I can think of off the top of my head is the exhaust valves getting too hot - but it's hard to say exactly what would cause that to happen.
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 01:47 Go to previous messageGo to next message
well I have been running bosh 4-head things for a while now.. and only really noticed this problem the last few weeks, but have had the sparkies probably over a year.
hmmm but that is something I could double check.
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 01:54 Go to previous messageGo to next message
Yeah when you have the sparkies out, just check their colour and compare it with one of those chart thingos - if you don't have a spark plug chart thingo that will make things trickier to diagnose Smile I've got one or two lying around and I may be able to get one scanned in for ya.
ed_ma61
Lost in the K hole
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 01:56 Go to previous messageGo to next message
a 1L bottle of RedX and a spare vac hose... 3500rpm and a quite street where noone will notice the bushfire-scale smoke column youll produce
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 01:58 Go to previous messageGo to next message
please explain? what do I do with the spare vac hose? quiet street = no problem! Smile is this better than using RP-7 down the hole while switched off?
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 02:01 Go to previous messageGo to next message
Pour the redex down it... (?) Could work. Brake booster hose is prolly the easiest to get to/use for this purpose.
[Updated on: Fri, 05 March 2004 02:02]
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 02:02 Go to previous messageGo to next message
yeah but "spare"? I don't have any "spare" holes for it to connect to on my system.
Redex = repco type purchase?
so many questions I feel like an idiot.. heh
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 02:05 Go to previous messageGo to next message
If I'm right - I think he's saying, disconnect the brake booster vacuum hose from the brake booster, twist it upwards so you can pour the redex decokeing crap down the brake booster vacuum hose (you won't need it while you are parked) while the engine is running and try not to do it while cops are watching Smile
(EDIT) Leave the hose connected to the intake manifold while you are doing this btw.
[Updated on: Fri, 05 March 2004 02:06]
ed_ma61
Lost in the K hole
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 02:07 Go to previous messageGo to next message
no no... i mean get the engine cranking up to 3500-4000rpm... and pull a vac hose off up near the throttle body (so that anything entering the system will be 'evenly' distributed to all 4 cyls).
connect up a long piece of vac hose - one to the nipple on the throttle body (or wherever you pulled the original hose off from) and dunk the other end in the bottle of RedX. pinch or crimp the hose as needed to control the flow rate of the RedX into the engine.
keep the engine revving and watch the smoke begin. does a decent job at cleaning the valves, comb chamber and piston domes.
also, you dont want to blast through the whole 1L too quickly, regulate the flow such that the engines is spluttering and a decent gob a smoke is coming out, but dont let it go too fast. you want the bottle to last as long as possible as youre likely to get a better result the longer you do it
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 02:09 Go to previous messageGo to next message
sounds good ed!
repco here I come! Very Happy I'll let you all know how it goes..
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 02:11 Go to previous messageGo to next message
Well that's probably a better way of doing it, just requires more thought Smile
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 02:12 Go to previous messageGo to next message
and it is quicker and me being lazy as they come.. Smile lol
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 03:59 Go to previous messageGo to next message
hey ed, is that Redex Petrol Treatment? or the Injector Treatment? I reckon the petrol..
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Fri, 05 March 2004 06:04 Go to previous messageGo to next message
I'd say that it is definitely not the injector treatment that stuff seems pretty useless anyway (I once used it, but it didn't even get close to cleaning the injectors). (edit) Having said that though, it's possible that it could clean engines to some extent I s'pose.
[Updated on: Fri, 05 March 2004 06:07]
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Sat, 06 March 2004 12:48 Go to previous messageGo to next message
guys went to several stores looking at Redex products today
I ended up buying the smaller (250ml) container of "REDEX Petrol Treatment". After reading the backs of them this one seems to describe what we are looking for.
It says that it will remove carbon, gum and varnish deposits, reduce cold start engine wear but lubricating upper cylinders, and combats fuel system corrosion.
Then in the "Engine Treatment" section it says, "Warm up engine, remove plugs and pour in 50ml of Redex into each plughole. Allow 30 minutes for Redex to penetrate. Turn over engine for up to 10 seconds, covering plugholes with an absorbent cloth to soak up expelled liquid, to remove dissolved carbo, gum and varnish".
So, naturally allowing it to soak seems a good option so what I will do is the above (with 35-40mls) , followed by ed's suggestion with a vacuum hose with the rest to clean the valve seats.
Will let you all know how it goes tomorrow Smile
Rob
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Sat, 06 March 2004 20:22 Go to previous messageGo to next message
AND THEN I was thinking I better NOT just pour it in because the ol' 3SGE sits on like a 10 degree angle in the bay, so all I would be doing is cleaning one side of the piston heads.
this is ghey - but I really wanted to give the heads a good soak but it seems like I can't, unless I can get the butt of my car hugely off the ground up a hill... Neutral
I can't win!
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Sat, 06 March 2004 23:49 Go to previous messageGo to next message
One solution to your problem would be :
The combustion chamber size would be no more than 56ml (9:1 compression, 500cc per cylinder) so just get the car on TDC, fill up the combustion chamber of 1 & 4 (or 2 & 3 whichever are currently at TDC) with about 55 ml of the stuff and you should be alright, just make sure it doesn't splash everywhere when you turn the engine over.
Then repeat the procedure for the other two pistons...
Afterwards you may want to siphon some of the stuff (10 or 20ml) out of the cylinders just to be sure that you don't lock the engine up when you do go to start it with the sparkies back in etc etc.
[Updated on: Sat, 06 March 2004 23:57]
DiZ_
The Eastwood MASSIVE !
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 07 March 2004 03:38 Go to previous messageGo to next message
Let me know when you do this so I don't report the smoke as a bush fire
Laughing
EVOSTi
cambo
      no
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 07 March 2004 08:13 Go to previous messageGo to next message
cant you just jack up one side of the car to level the engine out? or, just buy more of the stuff so theres enough in each clinder to cover the top of the pistons, then suck some out with a syringe.
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 07 March 2004 11:57 Go to previous messageGo to next message
And the outcome!
LOTS OF WHITE SMOKE. What I did was connected vac hoses to two little nipples Neutral on the intake manifold, one kinda near the throttle, and one closer to the other side. I did about 60% of the bottle on the one near the throttle and some on the other side just to ensure even distribution.
I sucked down the 250mls in about 2 mins I guess regulating the flow by squeezing the hose. SMT_007 kept the revvs at about 3k for me
I did not have quite enough to do the pour in the cylinders and leave trick, but I may do that later and I appreciate all your advice. We will see how we go. Try the easiest thing first I say. Smile
It ran white smoke for maybe 15 minutes
Immediate results: I could not detect the pinging that was irritating me before, BUT, I don't think I have tested it enough yet. More tomorrow.
Will be interested in starting my car tomorrow to see the level of cold start rattle. Will also keep you posted about that.
All for now. Cheers all, appreciate the advice SO MUCH.
Rob Smile
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 07 March 2004 12:07 Go to previous messageGo to next message
That cold start rattle may be the oil filter - I dunno if I told you about this before...but my car rattled like a prick for about 5 or so seconds when I started it, then it would clear up.
All that was needed was an anti-drainback oil filter so that the oil filter didn't need to fill back up when the engine was started after sitting around for a while.
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 07 March 2004 12:10 Go to previous messageGo to next message
yeah it is unpredictable. Some mornings I will get it, others, not.
I think most filters have anti-drainback valves in them anyway don't they?
If it is tappits or something...
anyway, I don't know heaps about the sources of rattles n' stuff Sad I will take my plugs out and inspect my piston heads this week. (loverly tiny mag light I have) Actually, i wish I had a camera, we could do a real good before and after. damm
anyone wanna come take pics? Very Happy lol, well I can always describe it.
RWDboy
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 07 March 2004 12:20 Go to previous messageGo to next message
As it turns out not all of them do, because the one on my car before the one I have now didn't, I can't remember which brand it was though. I'm not sure if they print whether it is anti-drainback on the filter itself or not, but it's worth a quick look.
Also - the 3S-GE doesn't have tappets per-se, they have these fucking bucket shims that you have to replace/machine (I think, I haven't ever operated on them myself) because the cam operates on the valve directly.
HighRolla
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 14 March 2004 02:36 Go to previous messageGo to next message
Hey Rob - are all the signs of pinging gone? Just want to know if it was successful?
RobST162
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 14 March 2004 23:11 Go to previous messageGo to next message
hey dude, I definitely noticed my car has NOT pinged since I ran the cleaner through. was driving up a slight slope at low revvs in 4th yesterday to check it, and no pinging buddy!
I have been wanting to take some photos of my piston tops but havent had a camer to do it with Sad . Just to see if they looked "cleaned".
But yeah, pinging is gone. Obviously you need to check all the obvious stuff first, timing, fuel octane rating.. but this helped me.
HighRolla
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 21 March 2004 05:26 Go to previous messageGo to next message
Hey Rob - could you just unplug the hose taking air from the charcoal cannister and plonk that in the petrol treatment bottle and just pinch the hose to regulate flow? I'm a bit skeptical about doing it because I've heard in old cars the carbon can be helping to stop the car burning oil i.e carbon buildup on piston rings. Just don't want to do it and regret it (ending up with a smoke blower) Mad . Thanks mate
sik sx
Sunshine Coast
Re: That stuff you spray in your injector/spark holes to clean your pistons Sun, 21 March 2004 11:43 Go to previous messageGo to next message
hey..what is pinging?..sorry im a bit of a newb i only got my first car (st162).. i think i have pinging..sometimes when im driving along..i hear like a wierd noise..kind of like a metal ticking noise..kind of like the noise when ur about to stall..except its real quite..and no im not about to stall when i heard it..my car is now fucked but not because of me
StuC
Re: That stuff you spray in your injector/spark holes to clean your pistons Wed, 24 March 2004 00:47 Go to previous message
Picked up a bottle of Redex petrol clean yesterday, but im still unsure of which vaccuum hoses to dunk into the bottle. Do i pull off one of the EPR hoses?Or should it be the ones from under the TB going to the EGR valve? Il see if i can get a pic of the TB up. I just dont wanna suck stuff through the wrong one and stuff my engine or something. Thanx guys
Previous Topic:Weber Carbs and return lines?
Next Topic:.
Current Time: Thu Nov 26 13:07:05 UTC 2026
Total time taken to generate the page: 0.0088272094726562 seconds
