Toymods » Tech & Conversions » Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry SV21
Iceman
Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry SV21 Fri, 05 March 2004 00:08 Go to next message
Ok a K&N Pannel Filter will be the best, as the engine bay get quite hot(compaired to other cars) and so a pod filter would not make much difference.
The CAI:
1) Undo the plastic wheel guard on the passanger side.
2) Remove the battery
3) Remove the fuse box next the battery
4) Remove the bottome of the airbox and block off the rectangle end as best you can(air-tight)
5) Undo the bolts under the battery holding the "silencer-box". (the Silencer box is located between the wheel guard and the underside of the engine bay.
6) Remove the silencer box and reattach the plastic wheel guard.
7) Reaplce everything in the revers order.
Now the air will be drawn from the circular hole on the silde of the engine bay, so the air will come from outside. (ei. cold air)
The ECU needs about 500km or one tank to reajust. It makes the air to fuel ratio leaner or richer untill it finds the best ratio for the way you are driving the car. So don't be affraid if the exhaust starts to pop a bit. It's better that you do it all at once, filter CAI and exhaust, but if u can't wait then once they're all installed, disconnect your battery and press the break untill the break-lights don't come on any more.(ei. you have to drain the car of power completely.)
Don't use 2 1/2 if your are getting mandrel bent exhaust, use 2 or 2 1/4. If your just getting normal bends then my advice would be to use 2 1/4. REMEMBER the bigger the LOUDER. Bigger exhausts give better "top-end" (more power at high revs) but less torque at the lower revs.
For extra details go here. http://forums.toymods.org.au/index.php?t=msg&t h=22495&start=0&rid=2025&S=ca74133f2fa ba8ca37ccc76ebcb1a7c0
StuC
Re: Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry Fri, 05 March 2004 02:13 Go to previous messageGo to next message
What about running hose from inside wheel guard to the front bumper after the removal of the resonator box thingy??Does this make much differnce too? Got any pics of urs?
wizzfizz2097
Re: Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry Fri, 05 March 2004 12:15 Go to previous messageGo to next message
this might just be my car but isnt the air taken from behind the headlight anyway? id imagine the air there would be okay anyway...
and i didnt know the ecu was dynamic! guess you learn something every day....
HAPPY BIRTHDAY TO ME!!!!
Iceman
Re: Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry Sat, 06 March 2004 08:48 Go to previous messageGo to next message
the idea of the CAI that i have done is to reduce the intake resistance and get some colder air to the engine.
The stock intake sits behind the headlight but is still in the hot engine bay.
Adding a pipe from the wheel arch to the bumper defeats the whole ides.
RESISTANCE = LENGTH X COSSECTIONAL AREA
by blocking off the end stock piping the air comes in the side which is closer to the airbox and has a larger opening.
IE. less distance to travel and more area = LESS RESISTANCE.
[Updated on: Sat, 06 March 2004 08:49]
Eddo
Re: Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry Sat, 06 March 2004 15:54 Go to previous messageGo to next message
can the same method be used for later models, ie, gen 4 or 4.5 (mcv20)??? coz that sounds real easy to do
crazy_camry
Re: Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry Sun, 07 March 2004 04:00 Go to previous messageGo to next message
that you Aussie Ed? yeah probaably would be similar
Eddo
Re: Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry Sun, 07 March 2004 07:33 Go to previous messageGo to next message
yep its me Very Happy
its been ages since i joined and came back to toymods
jinxinferno
Re: Do It Yourself...............Cold Air Intake...............and Exhaust tips...........for Camry Sun, 07 March 2004 13:30 Go to previous message
i made the original silencer into an air scoop by cutting off its forward facing side, it seems to have made a good difference
Previous Topic:Advice for TA22
Next Topic:4age Part Number Request
Current Time: Thu Nov 19 05:43:35 UTC 2026
Total time taken to generate the page: 0.0067930221557617 seconds
