Toymods » Tech & Conversions » 4age alternator?
cri_ag
northern beaches
4age alternator? Fri, 05 March 2004 09:30 Go to next message
just a quick question regarding a sprinter 4age conversion
can i use my standard 4ac alternator when converting to a 100kw 4age or do i need the 100kw one?
craig.
cri_ag
northern beaches
Re: 4age alternator? Sun, 07 March 2004 09:49 Go to previous messageGo to next message
anyone?
bmak
Re: 4age alternator? Sun, 07 March 2004 10:48 Go to previous messageGo to next message
You could make it fit but the output wouldnt be as high as a 4age 1.
Less problems with the 4age one.
TE72_Turbo
Re: 4age alternator? Sun, 07 March 2004 10:58 Go to previous messageGo to next message
no good. The 4AC is for a single V belt, 4AGE is a 5 row multi-rib belt.
And the issue of lower charge output as already mentioned.
cri_ag
northern beaches
Re: 4age alternator? Mon, 08 March 2004 09:11 Go to previous messageGo to next message
ok thats interesting my 4ac curently in the car runs a multi v belt did all 4ac's come with a single v?
bmak
Re: 4age alternator? Mon, 08 March 2004 10:06 Go to previous messageGo to next message
ive got a FWD 4AC that has multi v pulleys
TE72_Turbo
Re: 4age alternator? Tue, 09 March 2004 07:46 Go to previous messageGo to next message
okay, sorry, I had better re-phrase that, the RWD 4AC's in the sprinter (that I have seen) have had a single V belt.
What year is your sprinter cri_ag?? Maybe I've only seen earlier year models? Confused
cri_ag
northern beaches
Re: 4age alternator? Tue, 09 March 2004 09:50 Go to previous messageGo to next message
its an 83 model, but i think at some stage someone has put airconditioning on it and then taken it off. that may have something to do with it?
Re: 4age alternator? Tue, 09 March 2004 12:16 Go to previous messageGo to next message
it was probably retrofitted from an AE82 or something?
My AE71 had a V belt also...
I would NOT use the 4ac alternator. DEFINITELY go for the 4A-GE for the aforementionied reasons, and becuase it also sits on the other side of the motor!
cri_ag
northern beaches
Re: 4age alternator? Wed, 10 March 2004 07:40 Go to previous messageGo to next message
my alternator is on the left hand side of the engine as you look at it from the front of the car is that not the normal position for 4ac sprinters?, arnt 100kw 4age alternators on the left as well? (when you install them in RWD configuration)
bmak
Re: 4age alternator? Wed, 10 March 2004 10:32 Go to previous message
Its normally on the other side for a RWD setup.
I assume you motor was FWD at tsome stage
Previous Topic:How does a 4AG dizzy pick up crank angle?
Next Topic:Different Gearbox Ratio
Current Time: Wed Nov 18 17:02:23 UTC 2026
Total time taken to generate the page: 0.0054478645324707 seconds
