Toymods » Tech & Conversions » 1JZGTE serpentine belt question
hayaijza70
California
1JZGTE serpentine belt question Tue, 13 August 2002 07:39 Go to next message
Hello, I am here in the USA and finishing up my 1JZ swap in a MA70. I installed a new 2JZ power steering pump/pulley, and have the OEM elec fan setup (1JZ was from JZX90 chassis). I was told the 2JZGTE belt should fit, but it doesn't. Does anyone know which belt I should be using? Thanks for the info.
Pete
gold coast
Re: 1JZGTE serpentine belt question Tue, 13 August 2002 09:29 Go to previous messageGo to next message
The belts are measured in metric unit's, you yanks would not understand!! Laughing
Compress the tensioner and use a seamstress's tape to measure the length of the belt. If it comes out say 1710mm or 1.71m, go to a car parts supplier an ask for a 6PK 1710.
The 6PK bit is the ammount of ribs.
hayaijza70
California
Re: 1JZGTE serpentine belt question Tue, 13 August 2002 17:02 Go to previous messageGo to next message
Heh, thanks for the info. I will do that today. Rolling
EvilJack
Sutho/Hills NSW
Re: 1JZGTE serpentine belt question Fri, 19 August 2005 10:51 Go to previous messageGo to next message
just after any tips on replacing the 1jz serpentine belt, went to toyota and got the factory belt which is 1940mm im probly atleast 10mm off getting the belt over all pulleys with the tensioner losened all the way. yes i could go back to toyota and ask for a longer belt but its off the car atm and toyota is shut... Wink
can the 1jz alternator be losened or another pump to make up that 10mm to get the belt on?
also what size belts have people purchased to fit over all accessories?
[Updated on: Fri, 19 August 2005 10:52]
wilbo666
Re: 1JZGTE serpentine belt question Fri, 19 August 2005 11:13 Go to previous messageGo to next message
EvilJack wrote on Fri, 19 August 2005 20:51
Nope, it can't. And none of the other's can be either.
Smile
EvilJack
Sutho/Hills NSW
Re: 1JZGTE serpentine belt question Fri, 19 August 2005 11:14 Go to previous messageGo to next message
thanks for that, saves ripn stuff out Wink
JZX-83T
Re: 1JZGTE serpentine belt question Fri, 19 August 2005 11:37 Go to previous messageGo to next message
I just took mine off and went up to repco. They measured it and gave me the closest one they had. i think it was off a comodore but dont quote me on that.
mz21_shiznac
Bunbury, W.A.
January 2005
Re: 1JZGTE serpentine belt question Sat, 20 August 2005 00:51 Go to previous messageGo to next message
I've done mine recently and I actually work at an auto parts store. For the 1JZ from memory we list a 6PK1930 which is what I used and didn't have a problem. Smile
Chris Davey
sunny coast, qld
Re: 1JZGTE serpentine belt question Sat, 20 August 2005 01:35 Go to previous messageGo to next message
wilbo666 wrote on Fri, 19 August 2005 21:13
Smile
Mine can Wink
EvilJack
Sutho/Hills NSW
Re: 1JZGTE serpentine belt question Sat, 20 August 2005 01:47 Go to previous messageGo to next message
the pulleys have got to be different between cars, i got a soarer belt which was 1940 and was too short on my chaser 1jz with all accessories. According to toyota the chaser belt is 1970 and a jza70 is 1955 Rolling Eyes
oh and my old belt measured out to be 1985 but has heaps of cracks in it so i ordered a 1980 belt
[Updated on: Sat, 20 August 2005 01:52]
wilbo666
Re: 1JZGTE serpentine belt question Sat, 20 August 2005 10:27 Go to previous messageGo to next message
EvilJack wrote on Sat, 20 August 2005 11:47
The water pump pulley is different between engines fitted with normal vs hydraulic water pumps Smile
I was under them impression that the size difference was little, and that the same serpentine belt could be used regardless however...perhaps this is wrong?
EvilJack
Sutho/Hills NSW
Re: 1JZGTE serpentine belt question Sat, 20 August 2005 11:59 Go to previous message
well i tried a soarer 1jz belt (1940mm) and with the tensiner all the way off i was still short fitting the belt by atleast 10mm
looking at toyotas listing today the part numbers are different between the models, epc says the same thing
Previous Topic:TA22 Rear Discs
Next Topic:Mr2's + Intercoolers (AFM 3SGTE related question)
Current Time: Sat Oct 17 03:01:47 UTC 2026
Total time taken to generate the page: 0.0066671371459961 seconds
