Toymods » Tech & Conversions » 86 engine info...
rolla kid
Brisbane (AUS)
86 engine info... Sat, 06 March 2004 03:40 Go to next message
Hey i am looking at gettin an AE86 either the trueno or the aus spec model, i am just wondering will the RWD 100kw 4age 16 valve blot straight in to the engine bay and are there any mods that will be needed to be done?
Thanks rolla kid
Callifo
Gawler, SA
Re: 86 engine info... Sat, 06 March 2004 03:46 Go to previous messageGo to next message
Dont believe there is a RWD 100kw 4age. You will have to convert a FWD one to RWD.
ae95
Re: 86 engine info... Sat, 06 March 2004 04:12 Go to previous messageGo to next message
Bigport 86kw is the ONLY RWD 4age
TokenBlackGuy
      wtf is jabber
Re: 86 engine info... Sat, 06 March 2004 04:27 Go to previous messageGo to next message
and i have one if you wanna buy it!! and a 5spd as well Cool
ae86drift
sydney.au
Re: 86 engine info... Sat, 06 March 2004 05:55 Go to previous messageGo to next message
ae95 wrote on Sat, 06 March 2004 15:12
the RWD bigport is a JDM Bigport being 95kw
the FWD bigport is a ADM Bigport being 88kw
also as for your question, you are converting from carby to EFI so you will need to change tanks
also the engine will fit straight in, on the standard mounts, but the throttle intake is facing the wrong way, because the engine was originally in a traverse FWD fitment, so you need to weld the throttle closed on the other end and swap tover top the left side of the throttle body
not a hrad job, just fiddley
also, you will need the whole new loom and computer from the 100kw too
just get an ae92 front cut, you should be right with that
[Updated on: Sat, 06 March 2004 06:18]
Re: 86 engine info... Sat, 06 March 2004 10:28 Go to previous messageGo to next message
Try the search button...
HYP04A
Re: 86 engine info... Sat, 06 March 2004 11:34 Go to previous message
I would go for a levin apex or a trueno gtv, but there hard to find and if you do its alway 12 gran up but you get the twin cam engine, front ventilated disk, rear disk, shorter stering rack and lsd
Previous Topic:Turbo 22RE - Corona
Next Topic:air con probem
Current Time: Sat Nov 21 03:09:40 UTC 2026
Total time taken to generate the page: 0.0051159858703613 seconds
