Toymods » Tech & Conversions » Attention: Grant(Sixworks)
trev64
icon4.gif  Attention: Grant(Sixworks) Tue, 13 August 2002 08:21 Go to next message
Hey whats up people.
I was looking through some old forums and read that you developed some sort of a converter to run a stock VL Commodore tacho of a 1JZ-GTE. You said you might be selling them.
Anyways I need somehing like that so I can run my stock MA-70 tacho of the 1JZ.
Do you still have these converters?
Would that suit my application?
If you do have one I would be quite happy to buy it off you.
I am not keen on swapping the guts of a JZA-70 tacho into my MA-70 cluster. Freak
Thanks in advance. Grin
Grant
Newcastle, NSW, Australia
Tacho Converter Wed, 14 August 2002 04:51 Go to previous messageGo to next message
Hello Trev,
The tacho converter I first developed was for Skyline and VL tacho's to run off the ecu output of an RB20 Nissan. We are currently in the final stages of developing a similar converter for Australian tacho's to operate from a 5 volt Nissan or 12 volt (1J) signal.
It should only be a few weeks off being finished. I will email you when it is ready if you like.
Regards,
Grant
Grant
Re: Attention: Grant(Sixworks) Thu, 29 August 2002 21:49 Go to previous messageGo to next message
Trev,
I tried emailing you direct but the email bounced.
The tacho converters are now in the build stage. The test unit was trialled on a number of engine/tacho combinations and work without a hitch. Price is still be worked out but will be under $100. The firt few should be available in 2 weeks.
gt20v
Re: Attention: Grant(Sixworks) Fri, 30 August 2002 13:27 Go to previous messageGo to next message
Hi Grant, want to ask if your converter will work with a microtech MTX8 output or the negative output of a 4 coil DLI setup? Running the original AE86 tacho? Thanks..
Grant
Re: Attention: Grant(Sixworks) Sat, 31 August 2002 12:05 Go to previous messageGo to next message
To answer that question you will have to ask microtech what the output is. If it is either a 5 or 12 volt square wave then the converter will work on the AE86 tacho.
gt20v
Re: Attention: Grant(Sixworks) Sat, 31 August 2002 14:57 Go to previous messageGo to next message
it's a 12v signal, but I'm not sure if it's square wave coz I've got no scope, microtech don't seem to have website, so is there a number I ring?
Grant
Microtech Details Sun, 01 September 2002 22:13 Go to previous messageGo to next message
I suspect it would be a square wave.
Microtech details:
Microtech Automotive Systems (02) 9808 5233
[Updated on: Sun, 01 September 2002 22:14]
trev64
Slow tacho Mon, 02 September 2002 07:25 Go to previous messageGo to next message
I just changed the guts of the tacho from the JZA70 but now the tacho seems to lag behind. At 100kph it is 800-900rpm out (shows 2000rpm should show about 2900rpm) and it hit the rev limiter it only shows about 5600rpm when it should be about 7100-7200.
Any ideas?
Thanks. Razz
RA23_Sean
Western Sydney
Re: Slow tacho Mon, 02 September 2002 07:27 Go to previous message
Check your PMs
Previous Topic:what size 17 inch tyre fits a 1990 ae92 corolla sx or seca
Next Topic:tubbed or untubbed
Current Time: Thu Nov 19 04:43:19 UTC 2026
Total time taken to generate the page: 0.0049340724945068 seconds
