Toymods » Tech & Conversions » Gearbox Possibilities
DiZ_
The Eastwood MASSIVE !
Gearbox Possibilities Sat, 06 March 2004 08:25 Go to next message
What fits on a 4AFE , seeing as it has the same block as the 4AGE.
c52 from a 100kw 4AGE
c56 close ratio from a 20v
Seriously I need a new GB and a c56 was offerend to me and I'm pretty sure it would go on , the potential seller assured me it did also.
But do both these boxes bolt on the the 4AFE.
Re: Gearbox Possibilities Sat, 06 March 2004 10:50 Go to previous messageGo to next message
Heck, I'd GIVE you either an 86kw or GZE box if you could be buggered coming and getting it Twisted Evil
Scorpion
Menai area of Sydney
Re: Gearbox Possibilities Sun, 07 March 2004 04:00 Go to previous messageGo to next message
Hi Diz,
EvilJack just told me you were looking at this. The C52 and C56 should fit. Just need to check the starter motor as it might sit on the other side of the engine. Talk to Mortus - I think Mark has just put a C56 on his 4AFE.
Phil
DiZ_
Re: Gearbox Possibilities Sun, 07 March 2004 04:12 Go to previous messageGo to next message
Yeah I will ask him , also you have PM
-=NiGz=-
Compton.Sydney
Re: Gearbox Possibilities Mon, 08 March 2004 01:25 Go to previous messageGo to next message
Bit of the topic here, what gear box would be strong and realiable with a 4agze going into a ae92 or 93
c56 close ratio from a 20v???
Re: Gearbox Possibilities Mon, 08 March 2004 04:31 Go to previous messageGo to next message
-=NiGz=- wrote on Mon, 08 March 2004 12:25
NO!
If you are seriously considering a 4A-GZE conversion, then you should have done the research on it and found that the most cost effective way is to BUY A FRONT-CUT. Such a front cut would come with the correct factory gearbox suited to the HIGH TORQUE of the supercharged motor, with gear ratios that suit its power delivery. Also some of the GZE boxes have an LSD.
The GZE type gearboxes are:
E58-474 (non-LSD)
E58-11C (LSD)
E58-*** (if ends in odd number, it is LSD)
-=NiGz=-
Compton.Sydney
Re: Gearbox Possibilities Mon, 08 March 2004 04:41 Go to previous messageGo to next message
Yeah but i want a strong gear box when i turbo it you know dont want to keep it S/C all its life
Re: Gearbox Possibilities Mon, 08 March 2004 05:04 Go to previous messageGo to next message
Well others seem to have proven that the GZE boxes are quite happy to cop a turbo, specially in a FWD.
-=NiGz=-
Compton.Sydney
Re: Gearbox Possibilities Mon, 08 March 2004 05:11 Go to previous messageGo to next message
Do you know how much HP they can hold or should i do a google search? Cool
Singlecam
Blue Mountains
Re: Gearbox Possibilities Mon, 08 March 2004 06:15 Go to previous messageGo to next message
The Rigoli built turbo 20v of Smantha's had an E58(from an AE101 GZE) gearbox that coped fine with the 400 plus horses that the engine made. I should imagine that an E58 will be strong enough for any project you are planning.
-=NiGz=-
Compton.Sydney
Re: Gearbox Possibilities Mon, 08 March 2004 06:47 Go to previous message
Ah ok cool thanks, plannin to run 4gaze in a sx for a bit then turbo it using a t28 what you reckon or what other turbo you think i should use that is better then t28
Previous Topic:Stuck
Next Topic:AE86 4age rwd Thermo Part Number?
Current Time: Wed Nov 18 18:40:04 UTC 2026
Total time taken to generate the page: 0.0057988166809082 seconds
