Toymods » Tech & Conversions » 7MGE compression figures
drummerboy
7MGE compression figures Sat, 06 March 2004 17:15 Go to next message
Greetings and salutations. I'm doing a compression test on a 7MGE and was wondering if anyone knew the minimum acceptable psi, and the maximum allowable variance between cylinders. Thanks again to you forum junkies, keep on using!!
Re: 7MGE compression figures Sat, 06 March 2004 20:45 Go to previous message
For the 7MGE, dynamic compression should be 156 psi or more. The minimum acceptable is 128 psi, and the maximum acceptable tolerance between cylinders is 14 psi.
http://www.cygnusx1.net/supra/library/TSRM/em/EM_20.gif
Hope this helps.
Cheers Dave.
Previous Topic:Engine Light on JZA70 Appearing ..
Next Topic:building a airbox
Current Time: Sun Oct 18 22:59:36 UTC 2026
Total time taken to generate the page: 0.0044219493865967 seconds
