Toymods » Tech & Conversions » 4age spark plugs
bmak
4age spark plugs Sun, 07 March 2004 05:52 Go to next message
Thought i better check the plugs when i changed my leads and found that it has Denso K20PR-U11 plugs in it.
I dont know much about Denso plugs but cant find them listed for the 4age anywhere.
What plugs do people usually run?
Just wondering why my motor has these.
TE72_Turbo
Re: 4age spark plugs Sun, 07 March 2004 08:58 Go to previous messageGo to next message
Your motor has those because they are the ones that toyota use at service intervals. They actually come in a toyota box, but are manufactured by Denso.
They are quite well priced from toyota for platinum plugs, far better than the price you'll get from the local parts store.
bmak
Re: 4age spark plugs Sun, 07 March 2004 09:52 Go to previous messageGo to next message
Thanx for that
any reason they dont use the ones specified in the manual
HighRolla
Re: 4age spark plugs Sun, 07 March 2004 10:25 Go to previous messageGo to next message
Mine are denso aswell I think. The platinum plugs are pretty expensive. I read somewher that the GEs use platinum whereas the 4AFEs etc use just standard plugs. When I first got my car I took it to a decent mechanic (got timing belt done), he also had a look at the spark plugs while I was there and showed me the electrode. The electrode came to almost a point (like a little cone), he said the platinums last for ages and these don't need replacement. Check yours, if the electrode is rounded then they will need replacement (check for colour and deposits aswell). If they look alright I wouldn't bother replacing (I've done 50 000km on mine and they weren't new when I got the car, and they're still going strong)
At the bottom of this webpage you can see typical electrodes, the platinum is one of the 4 shown:
http://www.densoiridium.com/spconstruction.htm
bmak
Re: 4age spark plugs Sun, 07 March 2004 10:40 Go to previous messageGo to next message
they look like normal plugs i just wondered why they have used this part number & not the one listed for 4age.
The motor runs fine, sparkplugs are a good color & dont look very old
HighRolla
Re: 4age spark plugs Sun, 07 March 2004 10:44 Go to previous messageGo to next message
What they're not platinum plugs? I guess if the gap is correct then they should be fine. I don't think you have to set the gap on platinum plugs, but standard ones you do. Don't quote me.
bmak
Re: 4age spark plugs Sun, 07 March 2004 10:55 Go to previous messageGo to next message
yeah everythings fine i was just curious to see why different plugs were in it.
I couldnt find any specs on denso plugs to see if the are a different heat range or something.
NGK are heaps easier to work out
TE72_Turbo
Re: 4age spark plugs Sun, 07 March 2004 10:59 Go to previous messageGo to next message
My mistake, sorry, I misread the plug code as PK20PR-U11, which would be platinums.
Strange that yours does not have platinums, but I guess its up to the person that replaced them last to choose whatever they want.
Phil
TE72_Turbo
Re: 4age spark plugs Sun, 07 March 2004 11:02 Go to previous messageGo to next message
BTW: What variant of 4AGE do you have? 86kw or 100kw?
bmak
Re: 4age spark plugs Sun, 07 March 2004 11:15 Go to previous messageGo to next message
Its a RWD motor.
Some say 86kw some say more but i dont want to start that argument here:)
TE72_Turbo
Re: 4age spark plugs Sun, 07 March 2004 11:18 Go to previous messageGo to next message
why not? I'm sure we'd love to hear it for the 100th time! Cool
So what does the manual recommend for the RWD motor? I thought they were still platinums.
bmak
Re: 4age spark plugs Sun, 07 March 2004 11:25 Go to previous messageGo to next message
denso Q20R-U11 standard
denso PQ16R platinum
OR
NGK
BCPR6EY11 standard
BCPR5EP11 platinum
HighRolla
Is it a TVIS blue top or a red top TVIS (i.e. writing colour)
I've heard Blue top = 86kw and red is 88.
Not starting anything Very Happy
bmak
Re: 4age spark plugs Sun, 07 March 2004 11:29 Go to previous messageGo to next message
i'd say the paint was gone from the cam covers a long time ago.
Its an original JDM RWD engine, leads say 83
TE72_Turbo
Re: 4age spark plugs Sun, 07 March 2004 11:33 Go to previous messageGo to next message
Q20R-U11 vs K20PR-U11
K & Q plugs are interchangeable, they both have the same thread diameter & reach, so no problem there.
R is a normal resistor plug, PR is a resistor plug with a projected insulator nose, hardly any difference, can cause smoother running at idle with the PR (in theory)
And obviously the gap is the same on both at 1.1mm, and they both have a "U" grooved centre electrode.
So no drama really. Your car has just been fitted with a compatible alternative plug, you shouldn't be able to notice any difference.
But if you're replacing them, i'd highly recommend the PQ16R platinum plugs, they last forever, and are harder to foul.
Phil
bmak
Re: 4age spark plugs Sun, 07 March 2004 11:40 Go to previous message
Thanx
Is there a site that lists the codes for denso plugs?
Previous Topic:4age Part Number Request
Next Topic:20 v
Current Time: Sat Nov 21 09:16:05 UTC 2026
Total time taken to generate the page: 0.0060429573059082 seconds
