Toymods » Tech & Conversions » Turbo A supra
JZA70_R
Brunswick, W.A.
Turbo A supra Tue, 09 March 2004 01:57 Go to next message
Just wondering how much faster were these cars and what is different to the normal 7mgte models?
BlackSupra
Re: Turbo A supra Tue, 09 March 2004 04:29 Go to previous messageGo to next message
Big cams
More boost
Different turbo compressor wheel
TRD LSD
Bigger injectors
TRD/Bilstein suspension
Map sensored?
Stenno
Re: Turbo A supra Tue, 09 March 2004 04:43 Go to previous messageGo to next message
Cams have about 5-10 degrees more duration, and the same lift as the standard Anchor M cams.
No idea about boost, but Toyota ran the same headbolt tension as well as the weetbix heatgasket.
It also had a different turbine wheel - 1 more blade and 5mm or so larger than the standard CT26.
LSD is not a TRD item, and runs the same 3.73 ratio as the standard turbo 5 speeders.
No idea with Injectors, but I doubt they'd be different, check the ECP, it tells no lies Smile.
Bilstein dampers.
And yep, it ran a map based ecu.
JZA70_R
Brunswick, W.A.
Re: Turbo A supra Tue, 09 March 2004 06:48 Go to previous messageGo to next message
sounds nice sounds like it could keep up/beat a JZA70...
Ribbo
Northern Beaches
Re: Turbo A supra Tue, 09 March 2004 11:52 Go to previous messageGo to next message
got a mate with one, it fucken hammers
it was on the toymods dyno a while ago and think it beat alot of the 1j's, think it had boost up a bit though.
It was SUPRAMANs car when it ran.
Stenno
Re: Turbo A supra Tue, 09 March 2004 20:32 Go to previous message
JZA70_R wrote on Tue, 09 March 2004 17:48
Turbo A = 204kw @ 5600rpm and 354nm @ 4400rpm
JZA70 = 206kw @ 6200rpm and 365nm @ 4800rpm
I believe they both ran mid to low 14's down the quarter, so much of muchness.
Previous Topic:22RE new cam?
Next Topic:Suggestions - N/A EFI motor for ta22 or maybe ra28
Current Time: Fri Oct 23 16:34:57 UTC 2026
Total time taken to generate the page: 0.0093090534210205 seconds
