Toymods » Tech & Conversions » Swaaping sincromesh in gearbox
ta2272
Swaaping sincromesh in gearbox Tue, 09 March 2004 02:26 Go to next message
hey, my dad was telling me in his rx2 he swapped the sincromeches around ie swapped 5th gear with first because fisrt was a bit worn.
is this possible in a t50 for my celica and is it a hard procces.
jason
Re: Swaaping sincromesh in gearbox Tue, 09 March 2004 03:12 Go to previous messageGo to next message
well it all depends if the "synchromesh" is different. each forward gear has one, and if they are identical, then yes you can swap them. check on the toyota part numbers fro the mesh.. if it's only 1 part number. all good.
as for hard? not for me. are you comfortable completely disassembling your gearbox AND putting it back together again?
you WILL need a diagram for it (any of the yellow books from T50'd cars) and a few tools (like external circlip pliers)...
and lots of patience.
a large flat area with a clean surface (or an old light coloured sheet) will help immensely.
good luck.
hmm, from my yellow book, 1st and 2nd have "synchroniser ring no.1", 3rd and 4th have "synchroniser ring no.2" (which look larger), and 5th looks like it has "synchroniser ring no.1" as well... maybe it is possible?
Cya,S tewart
ta2272
Re: Swaaping sincromesh in gearbox Tue, 09 March 2004 03:23 Go to previous messageGo to next message
thanks alot this ia a big help, i gues you have to do a complet diasemmble of the box to change the sincros hey.
and the reason why im consiedering puttin another box in is when im in nutral (probly whehn in gear also i get a weird knocking noise when i take my foot of the clutch, then i will put foot on clutch again the back of and it wont do it, same thing in opposite order, there is oil dripping down the side of the bellhousing which doesnt smell like g box oil but i thik it is my mainseal leaking.
any suggestions what thsi could be
thanks heeps stewart big help.
jason
SeptemberSquallIndustries
Re: Swaaping sincromesh in gearbox Tue, 09 March 2004 07:41 Go to previous messageGo to next message
Well, you can't do it through the gearbox lubricant filler cap... =/
Surely a replacement T50 wouldn't be expensive?
ta2272
Re: Swaaping sincromesh in gearbox Tue, 09 March 2004 08:55 Go to previous messageGo to next message
theres not cap just a alan key screw hole.
onejayzed
Re: Swaaping sincromesh in gearbox Tue, 09 March 2004 09:21 Go to previous message
Laughing
Previous Topic:Engineers in Sydney - especially Frank Lohning
Next Topic:4age Exhaust
Current Time: Fri Nov 20 18:13:33 UTC 2026
Total time taken to generate the page: 0.0061559677124023 seconds
