Toymods » Tech & Conversions » radiators?
Drift_AE71
adelaide
radiators? Tue, 09 March 2004 02:52 Go to next message
found a small problem with my car last night when i took it out for its 1st hard slide sesion!
all i could smell was coolant,thinking to myself this anit to good so i drove home pull up in my driveway and all i can see is steam Razz
question i ask is i have a ae71 with ca18det and i need a bigger radiator that will be a almost bolt in fit. i.e. i have cooler pipes running either side of the stock one so i cant go much wide maybe 1" each side
is there a old celca or something with a nice chunky radiator that i can find cheap cheap??
rob_RA40
c'town, NSW
Re: radiators? Tue, 09 March 2004 03:36 Go to previous messageGo to next message
did u flush it during the conversion?
talk to a radiator shop they will probably have a triple core that they can weld your tanks onto.
also make sure your thermostat is working as well as the rest of the cooling system.
coronamark2
Re: radiators? Tue, 09 March 2004 03:48 Go to previous messageGo to next message
did it have water in?
could you see any visible leaks/cracks? check hoses / thrmostat
Drift_AE71
adelaide
Re: radiators? Tue, 09 March 2004 03:57 Go to previous messageGo to next message
the radiator has been flushed
its leaking a little bit of water but nothing i would call a huge problem,looks to be from the waterpump regin,
was ok i only got to do about 2-3km of slidng no stop then it was cooked,so yer not to sure what the go is
Drift_AE71
adelaide
Re: radiators? Tue, 09 March 2004 12:26 Go to previous messageGo to next message
anyone please im desprate
Re: radiators? Tue, 09 March 2004 13:13 Go to previous message
measure the core area reasonably accurately then ring a sizable radiator place that repairs and manufactures them - they'll be able to tell you what cars use that size, you then go wreckers, obtain stuffed radiator as advised, and get the above radiator repair place to fit a new core to he wrecker one.
Otherwise you have to remove yours from car to get them to adapt/repair. you also end up with a spare that you canrepair at your leasure.
you may have to make/modify the mounts on the side of the radiator (i had to attach aluminium strip to adapt my 3core to an RA40 celica as i got the wrong radiator from the wrecker (and i couldn't be bothered getting them to attach correct side mounts).
dont piss about trying to use 2nd radiators - they'll be either leaky or full of junk. If you have to drive to the radiator place, loosen radiator cap so it's not under pressure.
btw... if you have a leak that's obvious when cold, then under heat/pressure (which drifting will generate massive amounts of) it'll boil over and piss out the leak with great speed.
if you wanta drift seriously, get as many thermo fans as you can fit infront and behind the radiators. drifting is not condusive to good radiator airflow.
Previous Topic:Compression test
Next Topic:AFM question
Current Time: Thu Oct 22 07:54:09 UTC 2026
Total time taken to generate the page: 0.0045249462127686 seconds
