Toymods » Tech & Conversions » ra40 engine mounts
Hot Celica
ra40 engine mounts Tue, 09 March 2004 03:29 Go to next message
hey dudes.
i am swapping in an 18rg from an ra40 into my ra65, are the engine mounts going to be ok or should i start looking for another type or 18rg mount ?
Gus
people100
Rocklea qld
Re: ra40 engine mounts Tue, 09 March 2004 10:06 Go to previous messageGo to next message
Should fit straight in. Only difference there will be with the mod is exhaust is on the opposite side from memory and your rad. Other then that should go straight in with same mounts. Also i think sump is different is it. Might wanna check that?????
celicaboy
Re: ra40 engine mounts Sat, 13 March 2004 10:21 Go to previous messageGo to next message
you will haveta make sure it is legal for emissions for that model car and the exhaust is ont he same side
ra23celica
Re: ra40 engine mounts Mon, 15 March 2004 07:56 Go to previous messageGo to next message
Gus,
Silly question time, does the crossmember curve to the rear in a RA65 while the RA40 one curves to the front ? I think this might have a bearing on what mounts you can use.
Mitch.
[Updated on: Mon, 15 March 2004 07:58]
Re: ra40 engine mounts Mon, 15 March 2004 22:52 Go to previous messageGo to next message
The engine mounts shouldn't be a problem, but the sump definitely will!
Hot Celica
Re: ra40 engine mounts Wed, 17 March 2004 01:47 Go to previous message
22r and 18rg share the exhaust on the same side
the mounts i have will not fit the ra65
the sump i have will not fit the ra65 and therefore i also need a proper oil pickup to suit a forward sump
im trying to get some parts through wreckers but its turining up dead ends, i was hoping to have this finished this weeekend coming
i will let you guys know how i go if you want
gus
Previous Topic:3sge (st162) engine problems
Next Topic:18rg alternator
Current Time: Sat Oct 17 03:01:38 UTC 2026
Total time taken to generate the page: 0.0055751800537109 seconds
