Toymods » Tech & Conversions » low idle
LOKOSX
low idle Tue, 09 March 2004 11:58 Go to next message
i have a toyota corolla sx ae92
i am experiencing a drop in idle when the car has been running for a while..happens mainly when the air con is on...when i turn air con on, the idle drops really low..sometimes stalls
wat do rollas idle on, in the mornings when you turn on the car??
any help??
HighRolla
Re: low idle Tue, 09 March 2004 12:10 Go to previous messageGo to next message
I had this same prob on an AE82..there is a valve you can adjust for the air con idle up. It will let more air in as you unscrew it to allow the idle speed to increase
Look at this pic..to the right of the wiper motor is the a/c control valve, just where the photo is cut off there is a little spring under an adjustment screw that you can just turn by hand (has phillips head design on top)
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB1.JPG
Here's the original thread where I has the same prob..
http://forums.toymods.org.au/index.php?t=msg&t h=26250&rid=4423&S=5c9148b59b3d69f86236785 9761a1607
My car idles at over 2k when cold! Settles down to just under 1 when warm
LOKOSX
Re: low idle Tue, 09 March 2004 12:36 Go to previous messageGo to next message
my engine bay looks different to that
can u show me which screw u mean plz
HighRolla
Re: low idle Tue, 09 March 2004 23:13 Go to previous message
If yours is located in a different spot then trace it from the throttle body.. the below picture shows the line you should follow to the valve. In the pic from my last post the unit with the adjuster is in the very top right of the photo, you can see 3/4 of it, you should be able to find it. Let us know if you have trouble
Ben
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB2.JPG
Previous Topic:AE86 4AGE 20 value silver top conversion
Next Topic:22RE new cam?
Current Time: Sat Oct 24 04:55:07 UTC 2026
Total time taken to generate the page: 0.0049870014190674 seconds
