Toymods » Tech & Conversions » ST162 TVIS
dar_sbb
ST162 TVIS Wed, 10 March 2004 00:27 Go to next message
I did a search and there is a lot of articles tvis is good/bad... also the 4age is known to rev harder due to no tvis and the later nodel celicas to rev harder due to different port design.
My question is that if the intake manifold is changed to a later celica manifold from japan, would this increase power and revability?
only after doin extractors and hi flow cat i have been able to rev to 6000rpm mark...
Danners
Central Coast, NSW
Re: ST162 TVIS Wed, 10 March 2004 00:30 Go to previous messageGo to next message
What exactly is TVIS?
Dan
RWDboy
Re: ST162 TVIS Wed, 10 March 2004 00:42 Go to previous messageGo to next message
If that's the case then your car is effed - my car is standard and it revs to 7200 no problems.
TVIS is fine, leave it on. Unless you have modified the head and the intake port design then leave the TVIS on. Modifying the exhaust won't change the intake requirements enough to justify taking the TVIS off and/or getting another manifold from japan.
dar_sbb
Re: ST162 TVIS Wed, 10 March 2004 00:57 Go to previous messageGo to next message
dont get me wrong, i can rev to 7200rpm... its just theres no usable power after 6000g range
i dont know ne one with a jap spec celica to see the difference.
TVIS (toyota variable induction system) Its supposed to help the torque curve at all ranges of rpm
FWDCelica
sydney,nsw.oz.
Re: ST162 TVIS Wed, 10 March 2004 01:18 Go to previous messageGo to next message
Hey,
TVIS is supposed to boost low RPM torque.
It does this by blocking off half of the port to each cylinder thereby increasing the speed of the incoming air.
Once the revs get to a preset point, the ECU turns on the TVIS valve which unblocks that half of the port so you get more air coming in at high revs.
The 3SGE (Gen 1) makes maximum torque @ 4800 rpm and max.Power @ 6000rpm so not a lot of point revving past 6000rpm. If it had different cams it would probably make more power at higher revs. But the Gen 1 3SGE is getting old, and new cams would be hard to find.
Better off spending the money on a Gen2 or Gen 3. Gen 2 + 3 do not have TVIS.
My 2c worth!
T.
RWDboy
Re: ST162 TVIS Wed, 10 March 2004 01:27 Go to previous messageGo to next message
I was under the impression that max power comes at 5500 rpm in the st162 3S-GE.
New cams aren't so hard to find they just aren't cheap.
The TVIS restricts the manifold near the port, but it doesn't actually restrict the port itself (take the intake apart one day if you want to see).
There's lots to consider in regards to the first gen 3S-GEs somewhat primitive intake...the throttle area isn't so big, the ports aren't very streetable, whereas the cam is very mild etc etc it all doesn't really match up particularly well.
Gen 2 and Gen 3 etc 3S-GEs are far better by design obviously. Half of that though is in the better ECU (first gen ecu is a piece of shit, trust me) and has nothing to do with better port design and intake manifold design - (edit) but don't get me wrong, the port and manifold design is still far superior on the gen 2 and 3(/edit)
If you grab an Autronic/motec/wolf/whatever ECU and stick it on a first gen 3S-GE you'd be surprised how close you'll get to gen 2 figures straight away - if you install most of it yourself and get the autronic self tune you can pretty much get gen 2 figures for the same cost as sticking a gen 2 is (it's just more work)
Of course, it's still better (and more cost effective) to grab a gen 2 or 3 and then modify those Smile
[Updated on: Wed, 10 March 2004 01:30]
ST162GT-R
QLD, Gold Coast
Re: ST162 TVIS Wed, 10 March 2004 10:04 Go to previous messageGo to next message
Hi
In regards to that jap spec celica, i have a jap spec celica with a 3sge and the t-vis, but i can tell you that after about 4,500 - 5 g rpm mark you can notice the increase in flow/accelation all the way to about 6,500, kinda does nothing after that..i have taken the car up to 8g's before, but that was in wet weather and just letting the wheels spin and the rpm's go all the way up to 8,500, don't think the car liked it though..i try to avoid it.
FWDCelica
sydney,nsw.oz.
Re: ST162 TVIS Sun, 14 March 2004 02:44 Go to previous messageGo to next message
T-VIS
The real explanation
Courtesy of "http://www.dorikaze.ca/"
T-VIS stands for Toyota Variable Induction System. It came on two of Toyota's Sports-type Twin Cam engines, the 4A-GE (Corolla GT-S, MR2) and the 3S-GE (Celica). Here's how it works as described by Toyota*...
>> This system's intake passages are divided in two and a valve is placed in one side. Then, depending on engine rpm speed, the valve is opened or closed, which changes intake efficiency and improves performance across the rpm range. At low-to-mid rpm, the valve is closed. This effectively narrows the intake passage, which increases the speed of the air flow. Greater air flow speed results in greater volumetric efficiency, which boosts torque output at low-to-mid revs considerably. At high rpm, the valve is open, which reduces resistance within the intake passage and allows full development of the high-rev power potential inherent in the 4-valve configuration. <<
*info gathered from "Toyota Engine Technology"
Toyota part# PR-E-8905
printed in Japan 1989
http://www.dorikaze.ca/resources/garage/tech/MigsTVISdiagram.jpg
T-VIS was used only on the first model of the 4A-GE (bluetop), being in all Corolla GT-S' (AE86's) and MR2's (from 85-87), and was then removed when the newer Corolla GT-S (AE92) equipped with a slightly more powerful version of the 4A-GE came into production.
For the 4A-GE's which are T-VIS equipped, the system will open the intake valve at approx. 4400 rpm. A noticeable <glitch> is usually heard when the T-VIS kicks in. It's more noticeable when a free-flowing aftermarket intake is installed.
charliechalk
Re: ST162 TVIS Mon, 15 March 2004 02:42 Go to previous messageGo to next message
GT-R just as a point of interest, I doubt that the 3sge can spin the wheels at an engine speed of 8,000rpm+ as from 7,500 the power curve drops off a cliff. In the dry if you drop the clutch and hold the throttle down all the way, the tacho will happily read out around 6,800 maximum, so the power after there isn't all that good.
And I thought the max power was at 6,000rpm? max torque at 4,800rpm? as tivs swaps at 4,500 isn't it?
RWDboy
Re: ST162 TVIS Mon, 15 March 2004 02:48 Go to previous messageGo to next message
I can't be bothered digging up wheels magazine and finding out where the max power is.
I think T-VIS disengages at around about 4000rpm but I can't remember because it's been so long since I had my st162 on the road Smile
charliechalk
Re: ST162 TVIS Mon, 15 March 2004 02:51 Go to previous messageGo to next message
poor fella, it'll get there haha.. apparently you can get a certain set of cams which moves and almost makes the tvis change unnoticeable....
RWDboy
Re: ST162 TVIS Mon, 15 March 2004 03:01 Go to previous messageGo to next message
Sounds like the VVTi from the beams...and if you had that you probably wouldn't need tvis Smile
dar_sbb
Re: ST162 TVIS Mon, 15 March 2004 06:57 Go to previous messageGo to next message
TVIS kicks in at 4300rpm
I tried to find out bout cams... but the price was goin to b to much to get aftermarket ecu and tune.
Im just goin to settle for reginds
charliechalk
Re: ST162 TVIS Mon, 15 March 2004 08:16 Go to previous messageGo to next message
There's an interesting question, could it be possible to do a beams head swap onto a gen 1 3sge? I'ld say you'ld need to replace all the internals as well but could you keep the block?
and run off the beams ecu obviously. because the beams engine itself is designed for upright usage, would it even be able to run in a 162 leaned back like that?
toof
Re: ST162 TVIS Tue, 16 March 2004 00:20 Go to previous messageGo to next message
cant see why it wouldnt run in the leaned configuration JDM st202's where the beams also comes out of is mounted in a slope jsut like the 16x,18x.
i looked into getting a BEAMS for my st184 but the cost was prohibative. the 3sgte seems much more cost effective.
[Updated on: Tue, 16 March 2004 00:22]
dar_sbb
Re: ST162 TVIS Tue, 16 March 2004 00:33 Go to previous messageGo to next message
True.... the gte is more cost effective..., but to have a high powered non turbo... is a must. Aswell to show what toyota can do up against the type R's and FTO's on the street.
Can teh 162 box fit the beams ge??
Y does the jap spec 162 come with better compression?
RobST162
Re: ST162 TVIS Tue, 16 March 2004 00:36 Go to previous messageGo to next message
better compression because it is designed for a higher octane fuel. Doesn't have to allow for crap ulp Smile
the ecu is also mapped for better (higher octane) fuel.
alliance_22
Re: ST162 TVIS Mon, 22 November 2004 04:16 Go to previous messageGo to next message
Man i have a 2nd GEN 3SGE from MR2
and FWDboy believed it NOT to have TVIS
but !!!
behold the big chunk of metal on top of my 3SGE which has a big 'TVIS' on it.... i'm now trying to figure out how this works?
If 2nd Gen never had TVIS, could this mean:
1/ My Engine is not a 2nd Gen 3SGE
2/ My Engine is 2nd Gen 3SGE but also hooked up to TVIS
3/ My setup is rotted~!
>_<
RobST162
Re: ST162 TVIS Mon, 22 November 2004 05:11 Go to previous messageGo to next message
dude you need to chill Very Happy
1. it is most definitely a 2nd gen
2. YES!
3. and no
your setup is what lots of 162 toymodders wish they had Wink
b1gb3n
south Melbourne/KL
Re: ST162 TVIS Tue, 23 November 2004 01:02 Go to previous message
guy darsbb is having a jap spec 3sge. therefore his red line, max power etc would probably be different than aus spec ones.
keep ur tvis in there. If u want, u can disconnect the tvis and keep it open all the time by removing a few hoses. its somewhere in tech section
as for cams, try www.wadecams.com
give em a call and see if they have it. located in oakleigh melbourne. Reasonable priced cams
Previous Topic:Alternator wiring info reqd please.
Next Topic:TVIS anyone give me more info?
Current Time: Wed Oct 28 23:04:46 UTC 2026
Total time taken to generate the page: 0.015974998474121 seconds
