Toymods » Tech & Conversions » 2TGEU, starts, won't run.
Azrael
Crapberra
2TGEU, starts, won't run. Wed, 10 March 2004 11:20 Go to next message
After completing the wiring in my 2T --> 2TGEU conversion, the car starts but the engine dies after about 2/3 seconds. I can start it once more with the same result but then on the third attempt the thing just kicks over and won't fire. I've pulled out the (new) spark plugs and they seem pretty dry, and the no. 3 plug is starting to blacken a bit.
Is this a lack of fuel to the injectors or are the injectors blocked?
I've heard you can get a pressure tester for the fuel rail, where are these available from (pref in Canberra)?
Or could it be anything else?
Re: 2TGEU, starts, won't run. Wed, 10 March 2004 11:23 Go to previous messageGo to next message
yep, sounds like fuel
check all your fuel pump connections and relays - this is by far more common than injectors being blocked to the point of the engine not running
Azrael
Crapberra
Re: 2TGEU, starts, won't run. Wed, 10 March 2004 11:43 Go to previous messageGo to next message
Fuel pump definately is running, can hear it chugging away (it's so loud). What would be the best way to check if there is any blockages in the lines (I've replaced all the rubber hoses so only the metal hoses I expect would be blocked)?
T APLUS 22
Re: 2TGEU, starts, won't run. Wed, 10 March 2004 12:47 Go to previous messageGo to next message
hahaha, This sounds very familiar - I said I would never admit to this, however when hooking the pumps up I had the surge tank hoses on the wrong ones. Hence, sucking from an empty surgetank and pumping to the fuel tank.
Could you have done something similar with your main pump?
Re: 2TGEU, starts, won't run. Wed, 10 March 2004 22:01 Go to previous messageGo to next message
Check your injectors are pulsing. It sounds like the engine is starting on the cold start injector, which shuts off after 2-3 seconds leaving you with no fuel at all. A bit of probing with a multimeter should determine if they're doing their thing, but you should also be able to hear them clattering away as the engine turns over.
Azrael
Crapberra
Re: 2TGEU, starts, won't run. Thu, 11 March 2004 01:06 Go to previous messageGo to next message
Thanks heaps for the advice. I'll have a look at the injectors tonight and find out whats going on. I doubt the fuel pump is connected up wrong as I'm not running a surge tank and if the pump was backwards I'd assume there'd be no fuel at all.
ChuckLandwehr
Re: 2TGEU, starts, won't run. Thu, 11 March 2004 08:57 Go to previous message
Check your connections at the airflow meter, and operation, if you are using standard 2TG EFI.
Previous Topic:project car!!!
Next Topic:tps open?
Current Time: Thu Nov 19 06:20:05 UTC 2026
Total time taken to generate the page: 0.0070948600769043 seconds
