Toymods » Tech & Conversions » Why do people want high power car??
cozzb
mel
icon5.gif  Why do people want high power car?? Thu, 11 March 2004 01:15 Go to next message
I have been asking myself this question for so long, but i still couldn't find the answer.
from Physic we have learnt F=ma, therefore a=F/m
troque is not a force but it is 2 equal force acting at opposite direction right?
Power should be the some sort of enrgy right?
For the reson do we actually need a high torque car?
And does a high power car go faster than a high torque car with the same shape , size and mass?
please help!!
[Updated on: Thu, 11 March 2004 01:22]
T APLUS 22
Re: Why do people want high power car?? Thu, 11 March 2004 01:36 Go to previous messageGo to next message
the torque increase is used to overcome forces such as inertia which can be massive in big cars (anythign bigger than a classic celica:) )
From what I know, torque is a result of the power produced. Therefore you'll get more torque with the higher power. This torque is what you want to get those wheels spinning at high speeds sooner. When thinking of f=ma you need to look at the whole system - The car.
remember all the time you have wind and air resistance that grows with the speed of the car.
MrPotatoHead
Re: Why do people want high power car?? Thu, 11 March 2004 02:00 Go to previous messageGo to next message
Power = torque * rpm
basically high torque = high power, depending on where that torque is in the rev range. High torque at high rpm = high power. High torque at low rpm = medium power, low torque at high rpm = medium power.
Power is the number that matters with regards to acceleration and top speed. torque can be created by different gear ratios, sacrificing rpm for torque (revvy engines). The drivability of a car is related to its torque curve. A nice meaty torque curve will result in a decent amount of power anywhere in the rev range, so if you put your foot down at 2000rpm or 8000rpm the car will respond, and go. Some cars (and bikes) have a peaky torque curve, resulting in excellent performance in a certain rev range, but sluggish performance elsewhere in the rev range (race cars are a good example, made to be driven at high revs, therefore all the torque is at high revs)
Intensevil
Re: Why do people want high power car?? Thu, 11 March 2004 02:37 Go to previous messageGo to next message
Just what is the coefficient to get from torque to power?
ie: torque X rpm x Coefficient = power (hp or kw?)
Skip
Re: Why do people want high power car?? Thu, 11 March 2004 05:10 Go to previous messageGo to next message
Torque (Nm) = (Power(W) x 60)/(2xPixN)
N = revolutions (rpm)
Re: Why do people want high power car?? Thu, 11 March 2004 06:27 Go to previous messageGo to next message
Nm = (9402 x kw) / rpm
or
kw = (Nm x rpm) / 9402
to estimate max power/torque, a well sorted engine will make abotu a maximum of 100Nm/L (some high performance bikes and cars get up to 105Nm) for boost, multiply by (1+Boost) (where boost is measured in Bar)
the reason people want more power is gearing.
two cars, with same torque, but one makes that torque at double the rpm, will be going faster in the same gear...
is all about gearing.
ps, search for the "Torque" thread
Fattony
Re: Why do people want high power car?? Thu, 11 March 2004 07:18 Go to previous messageGo to next message
I really could not be bothered with the physics lesson reading the whole thread, but in answer to the question asked, i think you will find that you need a car with power aswell as toruqe, this will become more important when the weight of the car increases, generally you need to develop the power early in the rev range to get the car moving, hence you need more torque and thats generally why larger capacity engines are placed in heavier cars, i think the ultimate goal to acheive high accelaration is a high level of force and a small amount of mass, as the equation a = f/m. So if you would like to GO FAST you would need something with high power, hig torque and low weight.
cozzb
mel
Re: Why do people want high power car?? Thu, 11 March 2004 08:56 Go to previous messageGo to next message
thanks everyone!
Mr DOHC
Re: Why do people want high power car?? Thu, 11 March 2004 09:39 Go to previous messageGo to next message
cozzb wrote on Thu, 11 March 2004 18:56
thanks everyone!
um, yeh thanx, i have no idea what u said but it all looks legit
whats the velocity of the megabyte?????
Layoric
Canberra ACT
Re: Why do people want high power car?? Thu, 11 March 2004 13:34 Go to previous messageGo to next message
oldcorollas wrote on Thu, 11 March 2004 17:27
or
I take it this is an estimate as well?
Re: Why do people want high power car?? Thu, 11 March 2004 13:43 Go to previous messageGo to next message
no, that equation is mathematically EXACT (well to 4 sig figs anyways). you can check if you wish, by just doing the derivation. 1 inch = 2.54cm, 1kg = 2.2lbs,
the estimate is that a piston motor makes 100Nm/L...
for rotors it's capacity (eg 13B=1.3L) x 1.8 x 100Nm...
torque
UK at moment
Re: Why do people want high power car?? Thu, 11 March 2004 16:28 Go to previous messageGo to next message
Torque is the rotational analogue of force.
Fattony
Re: Why do people want high power car?? Fri, 12 March 2004 06:40 Go to previous messageGo to next message
My hooters have a lot of torque
Jonny2TG
Tasmania
Re: Why do people want high power car?? Fri, 12 March 2004 07:09 Go to previous messageGo to next message
Most people want more power from their engine regardless of wether they have a V8, 4 or turbo car.
To have lots of power, you need either lots of torque, OR lots of RPM. You don't realy need both (but it would be nice).
V8's have lots or torque.
Twincams & rotarys have lots of RPM.
A Turbo will add to the torque.
mx83toy
Re: Why do people want high power car?? Fri, 12 March 2004 14:08 Go to previous message
1JZ-GTE
Previous Topic:Charcol canister's
Next Topic:20 valve black top ae86
Current Time: Wed Nov 18 15:44:38 UTC 2026
Total time taken to generate the page: 0.0066769123077393 seconds
